Feels like bump start when ice kicks in
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tiff, Jan 19, 2019.
  1. Tiff
    Tiff Junior Member
    86
    Crawley
    Thanks for your reply.
    I have gone over everything again thinking maybe i missed something but i cant trace it. When its ok it runs so smooth but im noticing that its mainly at a stop or standstill where my issues arise.
    I can smell fumes as well at standstill. The charging indicator will just stop the car wont show as charging then although it might be 60%. Therefore engine wont turn off and i will switch it off manually. I that time the engine will make strange clattering noises. Last few days its been getting to 2 bars engine kicks in but then with 5 seconds it charges a bar and switches off. So charging real quick. And then sometimes it will switch off engine but still be going up in charge on the battery.
    No codes apart from P0A80 and c1657 which is hybrid powertrain control module hybrid control system
  2. Tiff
    Tiff Junior Member
    86
    Crawley
    I still have this annoying hesitation when the engine should kick in while driving along. The car sort of dips then comes to life almost like a bump start
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    While you still are getting the replace hybrid battery code (indicating there is a problem there which will have other codes associated to tell you where to look), if you have an exhaust odor, something is either not tight or a gasket isn’t seated properly. I would check all gasketry again for the nuts being tight as well as the gasket being there. The hesitation you’re experiencing is due to imbalance in the air to fuel, causing the computer to not know exactly what that is. When it can’t figure it out and you are moving, it’ll be lethargic.
    But there are hybrid battery issues to, which will cause poor charging behavior. Have you tried force charging the battery? What happens when you do that?
    Good luck and keep us posted (y).
    Tiff likes this.
  4. Tiff
    Tiff Junior Member
    86
    Crawley
    Wow good info. How do u force charge?
    Raytheeagle likes this.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    While the car is “ready” and in drive, foot on the brake (parking brake can also be set for safety) apply your foot to the accelerator pedal and see the battery behavior.
    Once fully charged, see how long it takes to drain or if it fluctuates;).
  6. Mendel Leisk
    42,361
    @Raytheeagle can this be with gear shifter in Park, or does it need to be in Drive?
  7. Tiff
    Tiff Junior Member
    86
    Crawley
    Ok so i just changed front discs and pads and thought id have a probe around. On the rear side of the engine to the right of the manifold and just below it above the oil filter looking to the front of the car from underneath there is a group of sensors which were covered in oil/grease. I dont think its a leak but there was oil there.
    Is there a correct way to put egr solenoid on. I opened that and noticed that had tightened up and was sticking. But when you loosen it or take it off the egr is nice and springy and should be as i spent a long time cleaning it. So when you put solenoid on should you turn it all the way to stuck or leave it loose. Took airboxout and cgecked all vac hoses and sensors and all looks good. But so far the last 2 miles went well fingers crossed.
  8. Tiff
    Tiff Junior Member
    86
    Crawley
    I remember someone mentioning degreasing or greasing the solenoid. Anyone which it should be
  9. Mendel Leisk
    42,361
    Oil pressure sensor leaking?
  10. Tiff
    Tiff Junior Member
    86
    Crawley
    And secondly this force charge thing starts the engine but shuts engine down when i let go of accelerator. If i have the car display on which shows engine inverter and battery sometimes the engine will be running but it only shows the engine running intermittentley
  11. bisco
    52,874
    you can't trust that screen, you need instrumentation for accurate data
  12. Tiff
    Tiff Junior Member
    86
    Crawley
    Im still sitting in the car now and it charges fine but engine is rough and noisy when charging. Holds charge as well. If anything im noticing its charging a lot quicker than b
    Before. Its so intermittent. I just drove 5-6 miles and it didnt do the bump start feel thing
  13. bisco
    52,874
    charging and discharging quickly are bad battery signs
    engine roughness is probably a separate issue
    Raytheeagle and Tiff like this.
  14. Tiff
    Tiff Junior Member
    86
    Crawley
    When i unplugged egr it didnt run any better or worse either it did put the eml light on as expected
  15. Tiff
    Tiff Junior Member
    86
    Crawley
    Are the busbars easy to do with pulling battery out, or is it a battery out job
  16. bisco
    52,874
  17. Tiff
    Tiff Junior Member
    86
    Crawley
    Thank you to all who helped massively especially bisco and mendel Leisk.
    What a lemon!! I didnt do up the bolts after detatching egr from cooler. So all sortednow running so smooth EXCEPT for some reason it has an intermittent stutter and clatter at standstill. Ive noticed if i switch heating off it normalises and now ive unplugged egr connection it made no difference?
    Have i got an egr solenoid problem??
    Or possible battery problem if heating off helps??
  18. Tiff
    Tiff Junior Member
    86
    Crawley
    Deffo running bad at a stop or standstill. Sounds like a misfire engine clatters.So just took of coils 1by1 and they all seem ok. They all made engine revs drop.
    Now im really confused.
    No codes either. So all in drives and sounds lovely. Just when pulling to a stop or at a standstill intermittenley sounds horrible and feels horrible
  19. Mendel Leisk
    42,361
    EGR tends to operate at mid-throttle? Maybe your poor idle condition is a vacuum leak, something not put together right? Up the page you also mentioned smelling fumes at idle. Hmmm.
    Tiff and bisco like this.
  20. Tiff
    Tiff Junior Member
    86
    Crawley
    Yes i sorted that. It was the egr loose from cooler. All tight now.
    I have noticed its only doing this intermittentley also not doing it as bad when in power mode. It tries to as you slow to a stop but because revs are higher in power mode it doesnt do it. If in nirmal mode when its charging at 2 bars if you switch heating off it helps as well.
    So now no smell smooth as new when it behaves just the roughness in charging and delay in starting ice
