Feels like bump start when ice kicks in
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tiff, Jan 19, 2019.
  1. bisco
    52,875
    how can revs be higher when slowing to a stop?
  2. Tiff
    Tiff Junior Member
    86
    Crawley
    As in when in power mode ice runs slightly higher in revs when charging
  3. Tiff
    Tiff Junior Member
    86
    Crawley
    Where are the main vac pipes? Might as well check them over. The only vac pipes i disconnected where the ones at side of intake that go to under the throttle body.
    Its only doing it at 2 bars when ice kicks in.
  4. Mendel Leisk
    42,361
    Some other suspects:
    Intake manifold gasket
    Snorkel connecting to throttle body
    Throttle body gasket
    Tiff likes this.
  5. Tiff
    Tiff Junior Member
    86
    Crawley
    Ok so new info.
    It seems i need to simplify this. Therefore ignore previous posts.
    Ok so i do have a hesitation in the engine starting when im lightfooted around town.
    Normally because of speedand traffic i seem to be always bang on middle on tbe bar between battery and engine on therefore i get a hesitation feel as tho i bump started car.
    Engine clatter and roughness is intermittent. It starts when battery level drops to 2 bars battery starts to charge with the engine making a clatter every 2 3 seconds as though something jnside engine is loose.
    Then all of a sudden display will not show if engine is running ir inverter is doing anything. At this point whatever has caused this the engine wont turn off automatically. It will just carry on running. So it seems something freezes. Whatever tells car to charge.
    Intermittentley it will try to turn of but sort of stall and go again and then just keep doing that.
  6. Mendel Leisk
    42,361
    I wonder if it's all accommodations for a failing hybrid battery? :eek:
    Grit and Tiff like this.
  7. Tiff
    Tiff Junior Member
    86
    Crawley
    M
    Mmmh. Well at least we would have eliminated everything else
  8. bisco
    52,875
    tl;dr did we already discuss the 12v?
    Tiff likes this.
  9. Tiff
    Tiff Junior Member
    86
    Crawley
    Battery volts on a voltmeter showing at 12.55.
  10. bisco
    52,875
    if that is with the car off, and after it has been off at least several hours, it's fine
    Tiff likes this.
  11. Tiff
    Tiff Junior Member
    86
    Crawley
    Yes thats the worrying thing. As all today ive been convincing myself the battery is a possibility. The strange thing is that its intermittent but no codes. 70% of the time its fine. When its not it just wont turn of at standstill, it will groan and whine and then go into stall start stall start mode and then sometimes just sort itself out or stay stuck In that mode. So im thinking maybe aling lines of fuel cut off valve or whatever starts and switches ice off. Because it still has hesitation at midway point where ice kicks in. Its always when im at standstill or city traffic for example. If im driving around it will be fine.
    Been struggling with torque pro app all day. Paid and downloaded pro version my predefined pids show battery voltages in blocks to show, but they dont give any data.
  12. bisco
    52,875
    i don't see how a 12v can affect an operating prius, other than cause the engine to run a bit more. i still think it is an engine or hybrid battery issue
  13. Tiff
    Tiff Junior Member
    86
    Crawley
    Bisco that was off after a few hours. But i reckon battery is faulty. Halfirds tested it a week or so ago and claimed it was overcharged in fact as it was supposed to have 325cca but was showing 385cca. Ice is kicking in a lot
  14. Tiff
    Tiff Junior Member
    86
    Crawley
    So annoyed i couldnt read voltages today. If i can just confirm readouts, order cells stick them in and be done with it
  15. bisco
    52,875
    i'm not familiar with cca. didn't know it would increase when the battery was going south
  16. Tiff
    Tiff Junior Member
    86
    Crawley
    Cold cranking amps. His words were battery was very good. I personally think its not that good but playing games atm. Someone mentioned toyota do a check for £39 might just do it
  17. Mendel Leisk
    42,361
    It's not uncommon for a 12 volt in good shape to show higher than spec CCA. In fact it's pretty much typical.
    For 39 pounds you should be able to buy something like Solar BA5 tester and see for yourself. Now, and down the road.
  18. bisco
    52,875
    can you borrow a battery from anyone to try?
  19. Tiff
    Tiff Junior Member
    86
    Crawley
    Yes... Do you know if battery has to be agm.
    Online shows non agm fit at under £50
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Bet the fella who ran the battery test set the test setting incorrectly. Some of them will purposely select a higher rated CCA value on the test than the battery's CCA value so it magnifies that you battery CCA is way low to trick you to buying a new battery. In this case, the fella may have input the CCA value tester lower than the battery's CCA thus the higher CCA from battery than sticker rating.
    #60 Grit, Feb 1, 2019
    SFO, mjoo and Tiff like this.
