Feels like parking brake engaged
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by lilikoi1, Dec 30, 2013.
  1. lilikoi1
    lilikoi1 New Member
    My 2008 Prius has been sitting for about 25 days while I've been out of town. I just tried to drive it, but it feels like the parking brake is engaged even though I've pushed it off (and the lights are showing it is off).
    A bit more detail: Car has been parked on a relatively steep incline (maybe 35 degrees) for about 25 days (this is its normal parking spot). Parking brake was engaged during this time. Weather is mild to warm (it's Hawaii). When I try to back up it feels like there is something behind the one of the rear tires, and the car almost starts to lift up a bit. (But there's nothing there that I can see.) I might have been able to push the gas a bit more, but was afraid of damaging something. When I put the car in drive and take my foot off the brake it rolls slightly (and very slowly forward), but not nearly what it should (I'm afraid to push the gas at all because there is a wall very close to the front of my car).
    Any advice? Seems like maybe the brake is stuck or something of the sort...
  2. Patrick Wong
    18,210
    6,517
    Maybe the parking brake is stuck. Regardless, you should try to move the car in reverse gear and see what happens.
  3. lilikoi1
    lilikoi1 New Member
    I've tried. There's a lot of resistance and it feels like the car is lifting up. How hard should I push against this?
  4. Patrick Wong
    18,210
    6,517
    Full throttle, to the extent it is safe to do so.
    Or, if you judge that to be unsafe, you can give up and call a tow truck for assistance. Good luck.
  5. bisco
    52,855
    keep your left foot on the brake and ready to hit it if the parking brake releases.
  6. lilikoi1
    lilikoi1 New Member
    Well, I got the car to "move" but the rear driver's side tire isn't actually spinning. I drove it back and forth in the driveway hoping it might loosen a bit, but nothing. Just skidding along the concrete. Which I'm sure isn't great for the tire. Talked to service guy who said this happens sometimes when the brake is engaged while car is wet (and since my wipers came on when I started the car I'm guessing that it was raining last time I drove). I don't think it's going to loosen enough to be drivable.
  7. JC91006
    16,936
    8,647
    you can jack up that tire and see if you can free it. I don't think there's anything that drives the rear wheels, it's just there to move forward and backwards.
    you can try and engaging and disengaging the parking brake a few times, see if it'll disengage.
    Lots of 2008 and 2009 problems today........
  8. 00-00
    00-00 Member
    115
    68
    s/e idaho
    2015 Prius c
    To possibly free the brake shoes, you could try hitting the backing plate of the frozen wheel, carefully and with a decent sized hammer. (I'd jack it up with jack stands first.)
    Also, the emergency brake cable for that side may be frozen somewhere in it's shielding.
  9. bisco
    52,855
    if that doesn't work, get a larger hammer.:p
  10. lilikoi1
    lilikoi1 New Member
    That's the solution to everything, isn't it? Or, as my dad used to say (which was rather apt in this situation), "when in doubt, gun it."
    I managed to turn the car around so that it's now facing the other way, up the hill. Gonna let it sit overnight and maybe having gravity pushing it the the reverse direction will loosen something. I've tried engaging/disengaging the brake with no results, but I may go out a few times tonight and mess with it. Will revisit tomorrow...
  11. bisco
    52,855
    it's probably going to come down to someone disassembling the emergency brake at the wheel.
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    And almost impossible to get the hub off with the e brake engaged. Thats going to take a beating.
  13. bisco
    52,855
    i was wondering about that. kind of makes a case for emergency disk instead of drum. i wonder if there is a way to get some wd40 in there?
  14. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Removing the wheel and hitting the brake drum on it's outside diameter with a copper, rubber,leather, or wooden mallet "do not use a hammer" will usually free the brake shoes. If you then wish to check out the brakes before removing the brake drum disconnect the 12 volt battery.
    John (Britprius)
    Data Daedalus likes this.
  15. Patrick Wong
    18,210
    6,517
    I would try loosening the toothed star wheel which adjusts the drum brake. Maybe that can be loosened sufficiently so that the brake drum can be removed. Also note that the brake drum has two threaded holes through which 6 mm bolts can be inserted, to help pull the drum off.
  16. lilikoi1
    lilikoi1 New Member
    Just thought I'd post to say thanks and to provide an update.
    As I stated above, I managed to turn the car around (just skidding the locked wheel). I left it parked overnight with gravity pushing on it the opposite way from how it had sat for the 25 days. The next morning it still was stuck. I tried to engage and disengage the brake a few times, and tried driving back and forth, but with no improvement.
    So the car continued to sit for at least another 24 hours (between the holiday and the fact that I'm battling the flu I just couldn't deal with it). This morning I called local auto repair who said that they might be able to send some one to look at it, but to call back in about an hour when the rest of their staff was in (they are pretty small and said they didn't even have room at the shop for it to be towed in). So I decided to go out and check it again. I put in neutral and it rolled slightly back (but no more than normal), and then put it in drive and got the same resistance that I'd been getting.
    And then, suddenly, it released! Much rejoicing. I drove it around the neighbourhood and there seemed to be a few extra noises, so I was a bit cautious, but they seemed to go away and I think were just the normal, been sitting for a month, noises.
    Drove today to run errands and things seem fine. Still a bit afraid to set the parking brake, and will definitely not leave it sitting with the brake engaged for that long again, but things seem good.
    So, just wanted to say thanks for the advice and (mostly) the assurance that pushing hard on the gas was okay. Not really sure how much it was helped by letting the car sit for so long with the pressure going the other way, or if it was just time and multiple attempts at getting it unfrozen by giving it some gas.
    koolingit likes this.
  17. Patrick Wong
    18,210
    6,517
    Well, if you need to park on a steep incline all the time, it is not safe to rely solely on the parking pawl in the transaxle. The parking brake should be engaged as an additional safety measure.
    Hence, I suggest you take your car in for service so that the parking brake cable can be examined and lubricated as needed. Explain to the technician what had happened, and which rear wheel had been locked. Good luck.
    lilikoi1 likes this.
