Filled tank full morning, afternoon "Add Fuel", one bar blinking?
Discussion in 'Gen 2 Prius Main Forum' started by sachminu, Mar 22, 2017.
  1. sachminu
    sachminu Junior Member
    32
    western ny
    I have a 2009 Toyota prius and gas tank had 3 bars, so I filled gas till tank full. All the bars lit up, then went home. Later in the afternoon when I started the car, only one bar left which is blinking and a message came up which says "Add Fuel".
    I then drove the car to the gas station, tried to add fuel, but the tank is full and it wont take any more gas, so there is gas in the tank. The car has around 65,000 miles on it.
    Whats wrong? Anyone else had this experience? I tried to reset the fuel gauge using the ODI /power button, but doesnt work.
    I have scheduled an appointment with the service center for tomorrow afternoon. But can I use the car still, I need to drop off/pick up kids from school/classes etc. Is it risky to drive the car?
    Any other solutions I can try myself to fix this problem, at this moment I really cant have an added expense.
    thanks,
    Cooks
  2. Stevewoods
    Stevewoods Senior Member
    647
    983
    Seattle, WA
    #2 Stevewoods, Mar 22, 2017
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I would try parking it on level ground, disconnecting the negative battery cable (the black one ) from the 12 volt battery for a few mins and see if it resets to full after a few miles of driving..
  4. sachminu
    32
    western ny
    Hi thanks, yeah I already did that. I saw the six numbers (actually 5 numbers, the last was a letter which kept changing from E to F), then 5 numbers came up, also saw the 3rd digit show 1.
    Nothing changed after I released ODO button and power off/on, still same. The last bar is still blinking.
    Maybe will try again.
    ok will try the battery thing, lets see.
  5. Stevewoods
    647
    983
    Seattle, WA
    I would try it several times. It sounds like a sometimes it could take a couple tries.
    And, as mentioned, never hurts to pull the battery cable.
  6. Mendel Leisk
    38,252
    What did the pump and/or your receipt say: how much gas went in?
  7. Beachbummm
    1,160
    392
    the sending unit in the gas tank might be bad... I haven't had this problem (yet) so Im not 100% sure ..let us know what you find out
