Filler/Drain outlets for Transaxleoil
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by andyprius, Dec 4, 2008.
  1. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Since I just did it, I'm quite sure I had a washer on each. Actually both look like special machined surfaces, as the inside base is wider than your common variety Home Depot or Lowes hardware. Also have a better finish to insure conformity to washer and matching surface. Don't know what the hell I'm talking about, " but I write real pretty, don't I"
  2. OrlandoGuy
    OrlandoGuy Junior Member
    98
    Orlando, FL
    I have had dealers charge for services and then after I arrived back home, found they 'forgot' to do something I was charged for. They always were very helpful when I returned, but typically blamed the service guy in the back for not reading the service order.
    The issue with marking the bolts on the transaxle is that this is a fluid you can not easily verify. You can look at the dipstick and see new clean oil to the full mark. You can look at the inverter/engine coolant tanks and verify clean pink fluid..that kind of thing you can see..but since the transaxle can not be easily verified, I think if they disturb the seal on the drain and fill plugs, the most likely did to the servcice. Did they do it right? That is a different question.
  3. andyprius
    2,212
    188
    Agree on all points. Especially in the case of 35 other checks or services we perform while changing oil. They pretend to do them. They do consistently change your tire pressure tho!
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I stopped by Camelback Toyota today, and they were willing to sell it to me. They had the single quarts of WS fluid (part number 00289-ATFWS) for $7.78, and the washers for $1.31 each.
  5. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
    That's some pricey fluid, though not as bad as $23 for a gallon of pre-diluted Toyota SLLC. I wish I had known about parts.com before I paid the local Totota dealer prices for some plastic wheel center caps ($32 each) and the small plastic air dam under the right front wheel ($56).
  6. philmcneal
    philmcneal Taxi!
    332
    Simcoe Ontario
    we charge 84.99 for the drain and fill type WS for 04+ priuses same price for the classic too, parts and labor plus your taxes (close to 100)
    Toyota recommends every 96,000 km or 72 months, whatever comes first
    I've always reused my washers ( I think 3rd type WS now), btw the drain plug is 28ft/lbs and the fill plug is 22 ft/lbs. Oil drain plug pan is 28 ft/lbs as well.
  7. Patrick Wong
    18,210
    6,526
    Hi Phil,
    My repair manual shows 29 ft.-lb for both the transaxle drain and fill plugs, see attached files. As you pointed out, Toyota Canada publishes a specific service interval for transaxle fluid vs. the TMS USA scheduled maintenance guide which is silent on that point.
    For $85 I hope your dealer's techs will replace the drain/fill plug washers for their customers. It's OK if you make the decision not to replace the washers when doing a DIY project on your personal vehicle, but not OK to make the same decision for paying customers since the Toyota repair manual makes it clear that the washers are not reusable...
  8. rollingm
    rollingm Junior Member
    Many thanks for the nice photo of the transaxle oil drain and level plugs. I was able to change mine using a small peristaltic pump to inject the oil. I have a question though about the maintenance guide that came with the car which requires a transmission fluid check and differential oil check first at 60K miles then at 90K. Is this a separate check or what? Thanks again Mike
  9. Patrick Wong
    18,210
    6,526
    Hi Mike,
    Since the Prius has a transaxle, the transmission fluid and the differential oil are one and the same. Therefore the transaxle fluid should be checked at 30K mile intervals per the Toyota maintenance guide (and I choose to replace the fluid at that interval.)
  10. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Mike
    The differential and the transmission share the same fluid
    I've seen "suggested" service guides that imply the Prius requires regular chassis lubrication. I've searched 5 years, and have yet to find a grease tit* on a Prius, or a rear axle to change the fluid in
    *Hobbit coined the term, I just have the lack of class to mention it
