Filter wrench for oil change. Help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenalik2000, Nov 19, 2009.
  1. El Dobro
    El Dobro A Member
    7,106
    3,282
  2. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
  3. shagaman
    shagaman New Member
    Maryland
    I just did my first oil change. I used an AmPro 65/14. I bought it in 2000, probably from Advance Auto. It fit perfectly. TIP: I coated the inside of the wrench with grease. By doing this, it slipped on and off very smoothly. Then I wiped the (little amount of) grease off the filter cover when I was done. But what a hassle the whole thing is compared to every other vehicle I've owned...
  4. El Dobro
    El Dobro A Member
    7,106
    3,282
    I used one like in the link I provided above and it worked just fine.
