Final Purchase Decision Tires
Discussion in 'Gen 2 Prius Fuel Economy' started by Angelo, Aug 13, 2017.
  1. Angelo
    Angelo Junior Member
    16
    Hey guys, my Goodyear integritys have served their purpose, time to replace all four.
    I live in Seattle (coming from SoCal) and am looking to replace all 4 tires that give me the best mpg possible while considering wet weather half the year.
    I've seen a lot of the older threads but was just checking in to make sure nothing new or better has come along.
    What tires would you recommend, I can go tire rack, side of the road shops or whichever. I just want to get the best tire for the car since I do about 400 miles per week, stretching the tank is my ultimate goal.
    Thanks everyone
  2. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    My suggestion would be to forget about stretching the tank and get the best LRR tire that will handle your expected driving conditions. To put your gas mileage over safety will be very unproductive and possible be dangerous. Assuming gas prices at $2.75 around the Seattle area the difference between 50 mpg and 45 mpg is about $10 a month. Give up one Starbucks coffee or one fast food lunch per week and stay safe.
    Data Daedalus and bisco like this.
  3. Angelo
    16
    Okay solid plan, what is the most desirable LRR tire?
    52,767
    see if they make the michelin energy savers in your size. they had gen 3 when i purchased, but not sure about gen 2.
    Data Daedalus likes this.
  5. srellim234
    1,201
    1,694
    Laughlin, Nevada
    I'll have to leave it to more knowledgeable people to help with that. There is also help available at places like Discount Tire/America's Tire and Tirerack.com.
    I wouldn't recommend the the Pirelli Cintarauto P7 A/S for your conditions. I've had them on our Prius for the last 25k miles and I won't hesitate to buy them again but I bought them knowing they would be primarily on dry roads. They only see wet pavement occasionally and that's usually while driving conservatively on interstate highways. While they are all-season, they're not particularly recommended for the constant wet weather you'll be seeing.
  6. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Michelin defender, quiet, long lasting, not a replacement for something better, it's the best
  7. Angelo
    16
    Went with the Michelin Energy Saver A/S 195/65R/15. OEM wheel is 185 but actually have heard ride and traction improvements by upping the width. Can't wait to get em! $116 per tire too!
    Data Daedalus, bisco and srellim234 like this.
  8. bisco
    52,767
    great price! i love mine, all the best!(y)
  9. Angelo
    16
    Is the recommended psi for these tires still 42 front 40 rear? Slightly higher than the recommended 35 psi or whatever was on the door frame?
  10. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Yes, you generally need to go 2-3 PSI higher than the door placard.
    You need to evaluate after 2000 miles to ensure you get even wear across the whole tread.
    I recently dropped mine to 39/37 from 42/40 after the tires showed signs of over-inflation at the higher pressure.
    I did not find any difference in MPG after dropping from 42/40 to 39/37.
    There was an improvement in MPG going up from 35/33.
    Just my data points, YMMV.
  11. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    I have a Gen II shod with Michelin Energy Savers, though I do have the 16 inch tyres (Touring equivalent model) - I'd wager they should be available for the 15 inch wheels too - kind of their target clients, methinks.
    iPhone ?
  12. bisco
    52,767
    i also have 15", but gen 3 went to 195. iirc, people have put them on gen 2 wheels, as we see in post #7.
  13. Data Daedalus
    1,025
    1,185
    Wembley, London
    I've got mine pumped up to 40/38 at the moment. This does help with my MPG and produces a smooth enough quiet ride on a good surface without being too hard over the odd bump. The nicest bit is the vehicle develops an enthusiastic penchant for long gliding distances when the conditions present themselves.
    This tyre seems to handle the relatively perpetual damp of the UK pretty well too.
    iPhone ?
    srellim234 and bisco like this.
