Finally A New Car
Discussion in 'Prius v Main Forum' started by wheaten lover gal, Apr 1, 2012.
  1. wheaten lover gal
    wheaten lover gal Junior Member
    S.W. VA
    Haven't bought a new car since 1974! We are trying to sell a 1990 Toyota Corolla we've used all these years,such wonderful cars!! I really need to read manual. Got the car on Fri 3/30,model 3, and still need to figure the sequence of shutting off. OK,everyone stop laughing! When do you press "P"? I stop w/break,press start button,press P button and put on break with my foot. I really thing I've got something wrong??? Does the 3 have the mirrors that fold in? Setting up the radio should be fun---NOT! So many bells and whistles.:eek:
  2. Mike500
    Mike500 Senior Member
    2,593
    767
    No need to press the "P" button.
    Just hold down the brake and press the blue start-stop button to both start and stop.
  3. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    P button is only after you have stopped where you need to be and want to put the car in Park. When starting, you just need to undo the Emergency Brake if you have it on, hold down the brake pedal so you can start the car like you normally would and then shift into Drive or Reverse.
    To my knowledge, the cars do not have folding side mirrors. I have the v 5 model and it does not. The car should not be as crazy big as some of the trucks out their that should require folding mirrors.
  4. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    Congrats on your new car!
  5. Priuswagon
    112
    Kingston Washington
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard and enjoy the new ride! I do not recommend the break procedure as that can be costly. ;)
  7. wheaten lover gal
    S.W. VA
    Thank you all for the help:). I'll just use the "P" when idleing car/not getting out,otherwise I don't use it to shut-off car completely.
  8. wheaten lover gal
    S.W. VA
    The car does have htd folding ext mirrors(looked at manual) and some one said"using brakes will be costly in the end" or something like that---what does that mean?
  9. wheaten lover gal
    S.W. VA
    What is a "valet" key for my 2012 Prius V model 3?
  10. fuzzy1
    10,724
    That referred to breaking the car, as in your original post, not braking the car.
    Probably a generic owners manual item held over from Toyota's non-smartkey cars. My 2010 manual also mentions this key, but I cannot remember any Prius owner ever mentioning getting one. Due to the electronics, it would be just as bulky and expensive as a regular key.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Wouldn't the "valet" key be the mechanical key in the FOB?
  12. fuzzy1
    10,724
    That door key won't let the valet start to the car to drive it back to the customer.
  13. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes... duh, didn't think of that. <embarrassed>
