Finally Did It ...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PiPLosAngeles, Aug 16, 2013.
  1. jnet
    jnet Member
    196
    32
    If you would like to exaggerate the EV range to 20 miles, then the MPGe is 200. We all know that it's not easy to get 20 mile range all the time.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I think you meant MPGe only for the electric miles. If PiP gets 14 miles per charge, that's 149 MPGe with 15% charging loss included. Regardless of the price of electricity, PiP tracks the kWh it consumed.
    Gas miles are the other half that should be considered. We add both fuels and come up with the composite MPGe for the overall efficiency. See the thread below.
    Top 10 MPGe | PriusChat
  3. jnet
    jnet Member
    196
    32
    Yes, that's exactly what I meant. Only the EV miles. The OP said he is getting 500 mpg without using the gas engine too much. I was just saying there is no way he could get 500 mpg unless he is getting free electricity.
  4. shiranpuri
    shiranpuri Junior Member
    65
    Well... miles per unit of currency, maybe. MPGe is a measure of efficiency that normalizes various types of energy with the amount of energy in a gallon of gas (1 gallon = 33.7 kWh). Meaning, it has nothing to do with cost, only efficiency. Free (for you) electricity doesn't change the efficiency, only the cost in your pocketbook.
    There's also their new eGallon scheme, but that one compares cost, not efficiency. (What I'm saying here is MPGe is not miles per e-gallon, it's miles per gallon equivalent)
  5. jnet
    jnet Member
    196
    32
    Thanks for clearing that up. If MPGe has nothing to do with cost, then definitely there is no way the OP could get 500 mpge from a PiP.
  6. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    The OP did not claim to get 500 MPGe. He said that usually on this commute (with ICE starting) he is getting 500 MPG which is just miles driven divided by actual gallons consumed (without counting the electricity used).
    In the particular trip of the first post he was doing about 222 MPGe (21.1 miles for about 3.2 kWh from wall).
    Drake and lensovet like this.
  7. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    He said 500 MPG, not MPGe.
    If he used 0.0422 gallons on his 21.1 miles commute, he would get 500 MPG. Of course, that's with a full charge boosted.
    The correct way to calculate his efficiency is to get the equivalent gallon of a full charge. 3.2 kWh / 33.7 kWh = 0.095 gallons.
    21.1 miles / 0.137 gallon(e) = 154 MPGe. This figure takes account of energy in both gas and electric. I am assuming that he used up all EV miles. If he does not, it should be higher.
    500 MPG takes account of only the gasoline. This is what Volt likes to display for the "feel good" purpose. When a Volt owner brags about his triple digits MPG, it is likely this figure. I think is misleading and there is nothing to feel good about.
    jnet likes this.
  8. PiPLosAngeles
    PiPLosAngeles Senior Member
    1,551
    724
    Whether or not "only" accounting for gasoline usage is something to feel good about depends on your source of electricity. Since my electricity is purely sources from wind and solar it is something to feel good about. Every mile I travel without burning gas is about 1/4-pound of CO2 emissions averted.
  9. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I understand and get the point. Using 0.0422 gallons in 21.1 miles commute with a plugin hybrid is excellent.
    If you get 50 MPG during the gas engine warmup, 0.0422 gallon would cover 2.1 miles. You still cover 19 miles in EV.
    Perfect is not the enemy of excellent.
  10. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Your personal feeling good is well understood.
    However, I assume your your electricity is not isolated from your local grid. So, on a national basis as long as the majority of electricity comes from non-renewable sources - it is only wise to use some gasoline in order to improve the efficiency of a plug-in vehicle.
    usbseawolf2000 likes this.
  11. lensovet
    2,615
    496
    Burlington, NJ
    can we please not have this discussion again. the cleanliness or not of the national grid is irrelevant to me when the cleanliness of the electricity that i use at my home and the charging stations in my area is leaps and bounds better.
    iplug and drinnovation like this.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    There are two sources of emission. 1) From manufacturing the vehicle and 2) from the fuel to operate.
    Even with cleaner California electricity, Leaf will take 205k miles to pay back the carbon footprint debt from manufacturing big battery and motor. Smaller battery is better for the entire life cycle emission and efficiency.
    A very heavy compact plugin like Volt will never break even with a comparable hybrid.
    Gas engine needs regular excercise. Gas tank needs regular replenishment. Cold weather demands cabin heat and the best way is from the onboard gas. A well designed hybrid (also plugin) takes advantage of both power sources.
  13. PiPLosAngeles
    1,551
    724
    Where can we access some data to support this? It seems like the footprint of manufacturing a larger gasoline engine and the additional maintenance required on a gasoline engine would offset this difference.
    lensovet likes this.
  14. 3PriusMike
    3,101
    2,420
    Silicon Valley
    That's easy...just find your way to Escherville.
    Mike
    iplug likes this.
  15. PiPLosAngeles
    1,551
    724
    It isn't wise when your electricity sources are cleaner than burning gasoline.
  16. markabele
    5,084
    1,782
    Nebraska
    That's true...there has to be quite a bit of waste from making a ICE.
  17. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Plug in Prius - Most Environmentally Friendly Vehicle in Study | PriusChat
    I just read it again, 205k miles break even is using the average electric mix. Using the California mix, Leaf surpasses a regular Prius at 100k miles. See page 13 in the report.
    At 100k miles, PiP is the cleanest plugin in CA. Fit EV is 2nd and Leaf 3rd. It is not clear if Leaf will surpass or break even with PiP with additional miles. Leaf's battery warranty is 100k miles -- that was extended from 60k miles.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    A bigger waste if ICE is rarely used. 50% EV and 50% Gas is ideal for a vehicle that has both power source onboard.
  19. markabele
    5,084
    1,782
    Nebraska
    So you are saying the closer you get to 100% EV the more waste a plug in hybrid becomes when you could probably get by with just an EV, such as a Leaf? But if you are getting closer to 0% EV than it obviously makes more sense to go with a regular hybrid? Am I understanding you right?
  20. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Your clean electricity source is interconnected to your local grid, I suppose, if you are using less of it then your neighbor will use more. If your (clean) local grid has excess it will transfer it to neighbor grids making them a bit cleaner. Same for your state. It's all interconnected, so national average is relevant. That the point I tried to make.
