Finally found a salvage yard 2005 battery to rebuild
Discussion in 'Gen 2 Prius Technical Discussion' started by alftoy, Jul 4, 2022.
  1. alftoy
    alftoy Senior Member
    1,132
    520
    Saskatchewan, Canada
    Finally found a salvage yard battery to rebuild. Difficult to find salvage yard batteries at a reasonable price in this neck of the woods. Been watching for a couple of years. The only other yard that had one wanted $1000. Lots of HV batteries in Winnipeg MB 5 hours from me, but mostly from taxis.
    Concerned about the age of the battery, will have to do, wasn't a huge expense, relatively inexpensive for the experience to be gained.
    Battery from a 2005 Prius, mileage unknown, $350/270usd. The Prius has been sitting in the yard for at least a year, so insurance salvage probably also had it for 6 months, maybe longer before they release the car on bid, so maybe sitting for 18 months. Reading so many posts on rebuilding batteries without having a battery to rebuild tends to get confusing. Battery was still intact in the vehicle so had a video on my phone to follow along how to remove the battery. Wasn’t sure how to test the pack voltage, removed the orange plug, removed the wires to the car from the battery and tested under the white plastic caps, showed 0, reinserted the orange plug and showed 201 volts. Finally able to wrestle it out of the Prius with help from the yard attendant.
    Hauled it 4 hours back home, set it on the bench and measured voltages, first column on the attached pic. Some posts suggest discharging it then testing the voltages. Wasn’t sure how to proceed, decided to record voltages as it sat then to charge all modules to 8 volts. Wired the modules in blocks of 2 as suggested by dolj
    Colorado Springs guy looking for Prolong reconditioning help | PriusChat
    1. Charge up (@325 mA) until the block voltage stabilizes (at ~16.8–17.4) then charge for a further 4–6 hours;
    2. Discharge at 325 mA until the voltage reaches 9.6 V;
    3. Charge back up to 16.8–17.4 V;
    4. Discharge at 325 mA until the voltage reaches 7.2 V;
    5. Charge back up to 16.88 V;
    6. Discharge at 325 mA until the voltage reaches 6.0 V
    7. Charge up (@325 mA) until the block voltage stabilizes (at ~16.8–17.4) then charge for a further 4–6 hours.
    Just curious regards the discharge voltages, first discharge is 9.6 volts so 4.8 volts per module. Some posts recommend discharging single module to 6 volts. Anyways I charged blocks of 2 to 16.8 volts. This is where I sit for the time being.
    Module 6, 16, and 19 suspect, after charging, 6 definitely junk, 16 probably, 19 came back, will load test, then discharge.
    I also grabbed as many other parts as I could, fan, inverter pump, 3 way valve, rubber covers from the back of the halogens, ABS resistor from another Prius in the yard.
    #1 alftoy, Jul 4, 2022
    dolj and PriusCamper like this.
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    Congrats... Once you get that first spare battery pack it tends to attract other packs... It's that first one on the parts rack that's hard to get.
  3. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    I spotted a mistake or maybe it is a typo in the above step 5. Just like steps 1 and 3, it should be:
    5. Charge back up to 16.8–17.4 V;
    There is nothing magical about 16.88 V LOL.
    Keep up the good work.
  4. alftoy
    1,132
    520
    I did a load test on the modules then wired modules in blocks, discharged the first 4 blocks to 5.8 volts then charged at .5 amp, 7500mAH cutoff. I charged for approx 13 hours and wasn't sure when they stabilized, was doing other chores. I notice others charge in stages 3-4000mAH, 5000mAH the 6000mAH. Did I let it run too long to 6400mAH?
    Now realizing its the discharge mAH shows true capacity of the modules.
    Also struggled with navigating the nested menus of the charger, finally figured out how to use the bluetooth app, much more convenient.
    #4 alftoy, Jul 7, 2022
  5. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    Well if anyone's around Central North Carolina Orange county I've got two sitting out here that need to go I don't generally fool with rebuilding batteries. I just don't feel I have the time to mess with it the guy from Dr Prius was supposed to come get them but I guess he's overloaded with things to do but I've got two sitting right here up off the ground on wood under a carport ready to go
