Finally happened (Check Hybrid System)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by visionseeming, Oct 31, 2025.
  1. visionseeming
    visionseeming Junior Member
    Southern California
    2013 Toyota Prius c Three w/ just under 182k miles on it. Got the dreaded "Check Hybrid System" on my way home from work yesterday, along with triangle, check engine and other lights. :( Luckily was able to drive home without issue.
    Checked the error code with ScanGauge II this afternoon and saw the P0A80 code (replace hybrid battery).
    So what is the best course of action? I know I can either replace failed modules (least expensive), replace the entire pack with a rebuilt one, or (most expensive) purchase a new pack from Toyota and have it replaced. Seems like the least expensive option would also last the least amount of time, as if some modules have failed, it seems likely others will too in the future.
    I recently put in a decent amount of money into the car (replaced transmission fluid, engine and inverter coolant, engine water pump, spark plugs, etc.) Given how expensive the used car market is these days, not sure if it makes sense to even consider finding a replacement car altogether. Seems like either way I'd need to fix the traction battery even if I'd want to sell the car. In the immediate short term, I might be able to borrow a car from family members just to get to/from work as needed.
    52,524
    is it original? if so, you got a great ride from it.
    it's really a personal decision. in this case, you get what you pay for couldn't be more true.
    but it is also about longevity and convenience. rebuilding/reconditioning/replacing cells will work for an unknown amount of time, and you have to repeat.
    buying a reconditioned battery is only as good as the warranty and the company standing behind it.
    when it fails under warranty, you still have the downtime to put up with, or even an argument about whether it's the battery's fault or something else.
  3. visionseeming
    Southern California
    As far as I know (and have records for): yes, it is original. I bought it from a re-seller who got it from a Toyota dealer trade-in. Original (single) owner had ~140k miles on it. Given the warranty is 150k miles / 10 years, I guess it's overdue. :) I did keep the battery fan clean, etc. to try to get the most life out of it. Original owner's miles were also mostly highway which maybe helped as well.
    Makes sense. I know I definitely wasn't planning a car purchase this year, given I recently bought a very distressed home I'm still in the process of fixing up. But the extra miles and uphill/downhill of getting to said home from where I currently reside, might have been part of what pushed the Prius c past the edge. :oops: Otherwise, the ICE still seems in good shape, and with the recent water pump and coolant change was hoping to avoid any premature head-gasket failures (EGR Cleaning was also on my to-do list).
    I've had my eye on the 2022 Prius L Eco for a while, or maybe Hyundai Ioniq Blue. They are still quite pricey and especially the Ioniq's long term reliability is still unproven. Probably best to wait a few years (and save up more cash) before moving forward with either of those...
    52,524
    if you diy it, you get better and better at removing, replacing cells and tossing it back together with little downtime.
    but it takes your time, especially with proper reconditioning/balancing
    visionseeming likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,195
    5,340
    Pacific Northwest, USA
    Prius C only have 20 modules, whereas standard Prius have 28 modules and other Toyotas have 34 modules... Because you have the least number of 8V modules your pack doesn't last as long and produces less power.
    Good news is your price to replace the pack is lower because you don't have to buy as many modules. Even better news is Sodium battery packs are back in stock next week and lots of vendors like Green Bean and Hybrid Geek have tested these packs so much that they're going all in on a long term investment to sell these packs instead of other after market packs.
    Click the link in my signature to saltyhybrids website and I think you'll not only be pleased by the price, but impressed by the performance. You'll feel like you upgraded your car in lots of different ways as well as be ahead of curve as EV makers shift from Lithium to Sodium!
  6. Leadfoot J. McCoalroller
    8,168
    7,674
    Pennsylvania
    2018 Prius c
    If it were our car, I'd get a new Toyota battery and keep going. I'd be thrilled if we got 12 years out of a battery that was built to last "about 10" years.
    PriusCamper and visionseeming like this.
  7. visionseeming
    Southern California
    So I called around a few local shops (not dealers) for estimates. I got verbal estimates ranging from $1.4k to $1.6k for a "refurbished (used)" battery pack (with warranties ranging from 6-24 months, 10k-24k miles), and $2.9k to $3.2k for a brand-new (OEM Toyota) battery pack. I heard the new pack should have 5 year (100k miles?) warranty, but not clear to me if that is honored by Toyota or the installer (who may "disappear" by 5 years).
    Doing more research on the DIY route, but need to understand the procedure to identify which cells are "bad" and how to rebalance/recondition them.
  8. PriusCamper
    13,195
    5,340
    My understanding of Toyota's warranty policy is that its 3 years if you get ripped off for a near $1K installation fee from the the dealer and only a one year warranty if you or a 3rd party shop install it, which is super easy on a Prius C. I'd charge you $150 to install if you lived near me. And I'm a certified installer for sodiumhybrid.com You mentioned your thoughts on the other options, but not on the sodium option? I'd be curious to know what you think about that one?
  9. visionseeming
    Southern California
    Yes, thanks for the info, I did check out your website. If I understand correctly you're asking ~$1400 for the replacement sodium-ion pack, which will be restocked next week. Prius C, Fielder hybrid battery pack - 10 blocks– NexPower Energy.
    It mentions "10 reversed blades", do you know what that's for? Does it have the same connections as the stock battery?
    Also, just general questions (as I'm trying to understand how aftermarket batteries work), does the battery control unit (computer and firmware) need to learn/adapt to the higher capacity and amperage of the sodium ion battery? Otherwise, it's unclear to me how it would take advantage of the extra specs vs the stock battery pack.
