Finally! How to program a non-SKS key/fob. Detailed!
Discussion in 'Knowledge Base Articles Discussion' started by amethystjw, Mar 1, 2008.
  1. patsparks
    10,664
    567
    Adelaide South Australia
    You can use an SKS fob in a non SKS but that wont give you SKS.
    The instructions may not work in an SKS car.
  2. spitinuri
    spitinuri Member
    317
    Does this work for all 04-09's? I have an 04 with only one SmartKey. I can add a black label FOB myself. I did talk to the service tech. at the local Toyota Dealership. He told me I could bring in a new Silver Label SmartKey and they would program it for me for the price of 30 minutes of labor. I have read other nightmare post about this subject. It seems like a fair deal. Thoughts!
  3. happycamper
    happycamper New Member
    Los Angeles
    How many times can you open and close a car door in an hour? That's how many times I did. (my dog gave up her confusion and went back into the house after a few minutes) It still doesn't work. I can't find anyone with instructions for the SKS system, which is what I have, so I tried your instructions, because a non-SKS is better than nothing.
    Four years ago, my husband was hit by a drunk driver in our new '05 prius. Thank goodness he was in the new car. Airbags did what they were supposed to do and saved his life. The car was totaled. We replaced it with another '05 prius.
    Fast forward 3 years. Husband lost his keys, including prius fob, house alarms, etc. So we have been sharing my prius fob. (I know we are living on borrowed time, before he loses mine too)
    A few days ago on his way home he pulled over to check something in the back. Got back in the car and drove home. When he got home he discovered that the no-key dash light was lit. He had put the keys in his lap and when he got out of the car they fell out on to the street. Close enough (on the ground) for the computer to think that he had them so it let him drive away. It was midnight and when he went back, in the dark, he couldn't find them.
    Panic set in when I looked online and discovered that without any working fobs we were doomed to $$$$$$pending lots of money.
    After the sun came up we drove back to the spot (10 miles away) again and thank you, thank you, thank you, we found them.
    That little experience screamed to us, get a back up fob NOW, not later.
    So thanks to this site I learned that old fobs can be reprogrammed. I took the one that I still had from the old totalled car and using your instructions went to work on the old fob. I was able to get it to work for only starting the engine while placed in the dash. That's fine, no SKS, I can deal with that. But, I can't get the unlock/lock buttons to work though.
    When I go through the routine, the locks only open and close once, NOT twice, like you say to be in the setup mode and after pressing both buttons at the same time, then the lock, it does the dredded double open and close, which mean I failed. over and over again!! Anyone have any idea what I am doing wrong? I don't mind having to push the buttons. But I really don't want to have to take the little key out to unlock every time. Pleeeeeeese help. not-so-happycamper (P.S.-thanks for letting me vent)
  4. RobH
    RobH Senior Member
    2,369
    987
    70
    Sunnyvale, California
    I've come to the conclusion that the car can only be programmed to use keyfobs that have not been used more than 128 times. It's all part of the design of the keyfob, and has nothing to do with the keyfob being defective. There is a counter in the keyfob, and once it reaches 128, the keyfob will no longer send the information required for the car to recognize it.
    The keyfob in the dash function is an entirely different set of electronics. Just about any keyfob (black logo, silver logo, 2004, 2005+) can be made to work when plugged into the dash. The car can be programmed to accept up to 5 different keyfobs.
    So a used keyfob is useful as a backup, but you generally can't make the smart/keypress functions work with anything but the original car.
    For the technical hard core, I recommend reading the data sheet for a Microchip HCS362. It is used in the black logo (non-SKS) keyfob, and the silver logo keyfob may be similar.
    Reverse Engineer and April&Daisy like this.
  5. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    RobH,
    I'm not sure that I understand the possible implications of the underlined
    above -- it is early, and I have had a first cuppa' joe, still...
    Does this affect the usefulness of the fob for unlocking the door(s)?
    I suppose in the normal run of things the 128-count would be reached in two
    or three months of regular use. But in the year+ that I've had my '08, I have
    used the fob buttons only a handful of times. Is this good, bad, not
    meaningful?
  6. RobH
    RobH Senior Member
    2,369
    987
    70
    The 128 limit applies to the ability to add a keyfob to the car's list of acceptable keyfobs. After that, the keyfob will continue to work with its original car, but assigning it to another car isn't going to work.
    This understanding is dependent upon a number of things that are possible, but not verifiable with the public information currently available. So take it as an informed guess, nothing more...
    The Microchip HCS362 chip in the black logo keyfob (non-SKS) has a mode called "Limited Seed". In the HCS362 datasheet, section 3.3.1, example B is the following statement:
    The silver logo (SKS) keyfob uses a different chip, but may follow similar logic.
    So, IF the keyfob is initialized at the factory to use the Limited Seed mode, AND the seed information that it transmits is required to add a keyfob to the car's list, THEN there is the 128 usage limit.
    The implication of all this is very similar to what people have experienced. New from the parts department keyfobs generally work. New from aftermarket keyfob vendors sometimes work, used (eBay, etc.) keyfobs generally don't work.
    But it's the usage count that is important, not the age. Since there are two keyfobs that come with each car, it is entirely possible that only one is used regularly. The other one could be stored unused for years, and eventually end up on eBay. As long as the old but unused keyfob has a counter value less than 128, it could be added to the car's list.
  7. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    RobH,
    Thanks for the comeback.
    Executive summary:
    * Brand spanking new fobs should be able to be reprogrammed.
    * Used keys, such as off eBay, are a crap shoot... buyers beware!
  8. Scott121
    Scott121 New Member
    Southern CA
    About two hours ago I was able to program a non-sks key fob (Black Logo) from Remotez4less.com for my 2007 Prius. Strongly recommend anyone attempting this read all of the following at least twice before starting. Timing and sequence are critical.
    Programming to use the fob for starting the car was much easier than programming for the door locks, but I was able to do both. I may know why I had problems with the door locks (see below). Following are the directions that worked for me both for "Starting" and for "Door Locks".
    Following are directions to program the fob for STARTING the car (only confirmed for Black Logo fob for non-smartkey operation, which means that you have to put the fob in the slot on the dash).
    1. Insert old fob into slot and remove it 4 times in a row, then insert it a fifth time and leave it in.
    2. Open and close driver door 6 times.
    3. Remove old fob from slot. Car is in fob programming mode at this point.
    4. Insert new fob and leave in the slot for a full minute. Watch the blinking red anti-theft light on the dashboard. When it stops flashing and goes dark, your new fob is all set.
    5. Remove the new fob and you're done. You should test both fobs to be sure they work properly.
    Now on to the tough one (Door Locks):
    Following are Directions that worked for me for programming for DOOR LOCKS (it was only when I followed steps 1-4 that I was able to get the car in programming mode for the Door Locks; Steps 1-11 are for "putting the vehicle in programming mode" and you use your old (working fob) for those steps. New fob is not used until step 12):
    1. Sitting in car with all doors locked I manually unlocked the driver side door (do not open door until step 3).
    2. Put Original/Old fob (the one that works) in ignition slot (do not push start)
    3. Open driver door
    4. Remove fob from slot
    5. Insert and remove the fob from the ignition switch twice within 5 seconds (door is still open).
    6. Within 40 seconds: Close and open driver's door twice.
    7. Insert and remove the fob from the ignition slot (let beep twice before removing).
    8. Within 40 seconds: Close and open driver's door twice.
    9. Insert the fob into the ignition slot and close the driver's door.
    10. Push Power button 3 times (Do NOT depress brake pedal)
    11. Remove fob from ignition slot.
    NOTE: System should now lock and unlock vehicle once, twice or five times to confirm that the system is in "Programming Mode". If locks do not cycle (lock/unlock) at least once, you need to start over.
    12. Within 40 seconds, Press and hold both the LOCK and UNLOCK buttons simultaneously on the NEW fob for 2 seconds.
    13. Within 3 seconds: Press remote transmitter LOCK button.
    NOTE: System should now lock and unlock vehicle once to confirm registration:
    A. If it does, just sit tight for 40 seconds, or open the driver door.
    B. If it does not, try pressing and holding the Lock and Unlock buttons simultaneously for approx 1 second and then pressing the Lock Button within 2 seconds. You have roughly 40 seconds to re-try this final step by holding the two buttons for different amounts of time, as long as you were successful at getting the system into Programming Mode (locks cycled at end of step 11).
    My experience was that the most time sensitive part of the process was the amount of time I that held the Lock and Unlock buttons down. When I held the two buttons down for 2 seconds it did not program; However when I immediately tried holding the two buttons down for 1 second (or less) it worked fine and the locks cycled when I pushed the lock button.
    To exit programming mode, open driver's door.
    There are some good directions at the following:
    forums.genvibe.com/zerothread?id=36249&postid+441745
    Just pretend that the key shown in the pictures is the fob for the Prius.
    Genvibe is having server problems at the moment, but it seems as though the programming is the same for a Pont Vibe (aka Toyota Matrix). Coincidentally, I was also just programmed a new fob for my Vibe and when I compared with the Prius directions for the Door Locks I found them to be almost identical. Not much of a surprise since the Vibe is really a Matrix in disguise. It was these directions that mentioned steps 2 and 3 above, which seemed to make all the difference for programming the locks (at least for me). Prior to following those steps I was unable to get the system into Programming Mode despite numerous (at least 15) attempts and despite the fact that the fob programmed for starting the car on the first try.
    Advice is to be patient and read the directions several times before even starting. Also, if you don't get the lock cycling at the end of step 11 you should restart, but be sure the reset the system before restarting. Reset is done by starting the car and then stoping it and then removing the fob before starting with step 1 again.
    Anyway, good luck to all.
  9. jackman
    jackman New Member
    I had the same result as you. Only ignition fuction - no doorlocks
  10. patsparks
    10,664
    567
    Never give up, it will work but it isn't easy to get it dead right.
  11. Squalled
    Squalled New Member
    First time poster with a couple of questions.....
    From what I understand from reading this topic, it is possible to make an additional Fob work for starting the car and remote unlock function buttons on the device without dealing with Toyota.
    Will this method work on a prius that has the SKS in it? (I don't want the SKS enabled on the FOB) I am aware that I would need a silver emblem for SKS anyway.
    Does this work on 2009's?
    From what I have read I think it will, but I just want to know from someone who knows a little bit more about this so I can save whatever the programming fee is going to be from my dealer.
  12. IndySteve
    IndySteve New Member
    It works on silver SKS systems. I got the ignition function to work but not the lock/unlock buttons. The smart system, of course, doesn't work. You have to put it into the ignition slot. Don't know if works on 09 models.
    Sure would like to hear from someone who got the locks to work on a silver key fob....how do you do it? Maybe it is related to the limit on the key fob itself.
  13. GaryGarland
    GaryGarland New Member
    46
    New Jersey
    Hi sorry to rehash this over and over - what i'd like to do is add a key to my SKS system - even if i add a non-smart key - then my plan would be to stash the metal key "somewhere" - probably with a magnet under the car - and then stash the spare key inside the car - in case i need roadside assistance to get in, i could then still use the key by putting the non-smart key in the slot. Does anyone know if this is viable? and does anyone have recommendations of where/how to mount the metal key outside the car? many thanks!
    (for what it's worth, 2009 package 6) - thanks!
  14. echase
    echase New Member
    227
    I took a spare key from my totaled non-sks '06 and used it in my SKS-enabled '08. Fob works in the slot, must use the metal key for entry. ($7 at the dealer). Took me about 5 tries to make it work using these instructions.
  15. GaryGarland
    46
    New Jersey
    Thanks for the reply - did the FOB also work remotely (via buttons, not SKS?)
    Many thanks!!!!
  16. echase
    echase New Member
    227
    Mine did not, but someone else here had success doing that with a slightly altered method I have not tried.
  17. EV Driver
    EV Driver New Member
    Atlanta
    :rockon:
    I just bought a 2008 Pruis that only came with one key. I successfully used the programming method above on a used 2006 key and have the door locks working and the car starting.
    Also, I checked with my local Toyota dealer. They have the metal key blanks for $10, which includes cutting it. I will probably get one tomorrow.
  18. GaryGarland
    46
    New Jersey
    that's great news! have both of my sks keys - i bought a used sks key on ebay (gulp) and a used non-sks key from ebay as well - i plan to take a hike to my place of purchase (about 35 miles away) and get my free oil change and car wash, but i'll also see about having them program that third key for sks, and the 4th key for non-sks use (with the intention that would probalby be the "valet key" or else i'd velcro it to a hidden place in the car so if i somehow lost the key, AAA could get me in, and then the key would be usable...
  19. RobH
    RobH Senior Member
    2,369
    987
    70
    Gary: Save some money by registering the keyslot function yourself (only) for both keyfobs. I've heard way too many stories about how the SKS (remote/proximity) function cannot be registered with a used SKS keyfob. Note that EV_Driver has the base package which uses a non-SKS keyfob.
  20. GaryGarland
    46
    New Jersey
    thanks Rob - i'm trying not to be too stupid about this - i "jumped the gun" when i ordered both keys on ebay the same day that i read posts about bricking the car without having a single key available (and before i saw the post about the scantool or whatever toyota does for the master clear/reprogram)
    as far as i understand, i can have a total of 4 keys at the same time? i'm fine if 2 are sks and the others are not, even if one of them has the silver - there are worse things in life than pressing the unlock button - as long as the thing works.
    however, if there's a chance the dealer can do some voodoo and make my used silver key SKS, that would be a nice bonus (to me)
    i'd be interested to learn if anyone has had success in having the dealer reprogram a used sks key - thanks!
