Finally replaced EGR valve/cooler today
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kc410, Oct 17, 2017.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Chlorinated compounds were fantastic solvents, but had environmental and personal impacts:(.
    Brakleen is now made in non-chlorinated form (use acetone as a base). But I used that on our egr cooler and it worked well;).
    Just not a potent(y).
    amos likes this.
  2. JDZILL
    JDZILL Junior Member
    28
    apple valley, ca
    Ha ha yes, that wonderful 12 mm nut that almost take two people to R&R, one with long socket and swivel, and one with a magnet to guide socket. I reinstalled that nut on my first cooler job, this last one, that nut is still in my magnetic tray lol.
    Raytheeagle likes this.
  3. JDZILL
    28
    apple valley, ca
    After a good soak in super clean, or purple power, I plug end of cooler and spray PB blaster bolt loosening penetrating oil and fill cooler, that stuff melts the carbon to a runny goo. The piano wires a great idea, I used a large paper clip straitened out, finish with brake cleaner.
    amos likes this.
  4. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    I never had an issue with that nut, however I do wonder if the right hand drive set up makes it slightly easier to access that nut?
    iPad ?
  5. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    Sorry to dig up old post but I took my 2010 apart do clean out TB and EGR cooler. I did get a spare EGR cooler from ebay and cleaned it out beforehand. The one I took out of my car was completely clogged and have been reading other post to try to clean it out to prep for next swap out.
    Just a thought about that hidden bolt below the cooler. I have one of these rotator ratchet which can operates with miminal space.
    https://tinyurl.com/yxt2bh9t
    ratchet action happens by just twisting the handle. one i was able to thread the bolt onto the stud, i was able to tighten the bolt down.
  6. JC91006
    16,939
    8,647
    The hidden bolt is not hard to get to, just use a socket with a small extension.
