Finally replaced my 8.5 year old 12V battery! Non AGM???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by uart, Jun 15, 2013.
  1. sambojoho
    sambojoho Proud conservative
    92
    23
    Ohio
    Wow, if my battery lasted 8.5 years, the same one would be going back in!
    iPhone ?
  2. Jon Hagen
    Jon Hagen Active Member
    336
    136
    North Dakota
    What is more important than AGM VS flooded cell battery, is that the Prius should have a deep cycle type battery.
    The deep cycle type can stand more deep discharge cycles and will last much longer than a starting battery in this application.
    Fostel and Epiphany2000 like this.
  3. Andy Dates
    Andy Dates New Member
    Pasadena, CA
    Reviving this thread a few years old. On the picture of the AC Delco battery, it shows model # S40B20R but someone else mentioned model # S40B20L. Is it interchangeable? Secondly, what does "R/H" stand for in the description "R/H vent hole" on the picture of the installation?
    Thanks.
  4. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    The difference is in the position of the battery terminals. The "R" stands for negative terminal on the right with the terminals closest to you.
    This is the correct layout for the Prius from 2004 on-wards. The Prius up to 2003 used the battery with the opposite "L" configuration.
    John
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I think the Prius uses the left hand vent tube, but many batteries have a connector at both ends.
    S46B24R is the right size for 2004 to 2015 Prius, PHV, and v. I think the 2001 to 2003 and the c use other sizes.
