Finally started my modification journey...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CosbyComedy, Aug 14, 2016.
  1. CosbyComedy
    CosbyComedy Junior Member
    46
    52
    Columbus Ohio
    Today I started my recovering pf door panels and arm rest with synthetic leather. I also cleaned up some wires in the center console and put the Syn-Leather inside the console cause, why not.
    I installed a dash cam too, pix later on that.
    Tomorrow I'll do another door, maybe two.
    The hardest part is getting those plastic rivets sheared off.
    Thank you to the entire Priuschat community. I feel like I've found my second home!
  2. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    before you do the other doors, can you do some in-progress shots of your process? I wanted to upholster the doors myself last year, but when I removed the door panel, I couldn't for the life of me be gentle to remove the felt.Were you able to remove it or just glue the leather on top?
    The fabric has been sitting in my desk cabinet for a year now. any help is appreciated.
    ps: welcome to PC :)
    orenji likes this.
  3. CosbyComedy
    46
    52
    Columbus Ohio
    I'll post the pictures later this morning. It's not as difficult as I thought it would be, yet it does require patience. 1st door to several hours. Last door took, 30 minutes. I did make the biggest error on the last door by drilling a hole through it. It's tiny, but...
    Starbrand likes this.
  4. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Very nice. Would love to do this in my C.
    iPhone ?
  5. CosbyComedy
    46
    52
    Columbus Ohio
    MY GOD! YOUR PRI IS DOPE!!! I learned so much looking at your build over time! I can't believe you haven't done this yet?!?!?
    Montgomery and Starbrand like this.
  6. CosbyComedy
    46
    52
    Columbus Ohio
    I'm not exactly sure how good these pictures describe the process but basically: The key to getting the cloth panel off is to sheer off the tops of the plastic rivets. You can use a wood chisel or a sharp metal scraper (must be heavy duty) I used a razor blade on the last 3 doors. Used the same blade and got better with it. Even after sheering a decent amount of pressure is required to pop it free. Its sturdy and not likely to break but the handle area seems more fragile.
    there is an overlap issue where the interior door handle pins to the same rivet as the panel you're trying to remove. It just requires a little more force to lift it free and also putting it back. I did remove all the door fixtures but it wasn't exactly easier in the end.
    The adhesive I used sets up fast! Keep the cloth attached as it adds a minimal amount of padding. If you're covering with something extra thick then you may need to remover the original cloth just to make the seal.
    To your concern of the felt. I pinned it back some doors, others I removed it completely then lightly spray glued it back when I was done.
    on a scale of 1:10 I'd rate this about a 5. It's very simple but not a rush job. I'm confident I could redo the entire car in about 2 hours or less. Mostly because the screws are much easier to work with. I used #8 1/4 inch & #8 1/2 inch metal screws. I recommend an equal variety of sizes and types (flat top and rounded tops appx 20/ door) they penetrate at different depths. Also WASHERS!!!! This is the key to not piercing the door. Mostly 1 will do. sometimes 2 and once I needed 3. Seems to depend of the cleanliness of the sheering.
    Montgomery, Starbrand and Dylan Doxey like this.
  7. CosbyComedy
    46
    52
    Columbus Ohio
    I applied glue to the backside too. This allowed the cover to be pulled and stick to the panel. It sets fast! Get the large part flattened 1st then work the arm rest. Cut slits in the edges that curl around to get your "pull" just right and avoid wrinkles.
  8. Starbrand
    493
    1,502
    Westmont, IL
    these pics help out tremendously. thank you so much. Hope to change mine when I get around to it :)
    CosbyComedy likes this.
  9. CosbyComedy
    46
    52
    Columbus Ohio
    I've done so much so fast to my Prius that it almost seems like I did nothing at all?!?
    So far:
    -Replaced factory CD player with full Android head unit
    -Also added back up camera(relay required)
    -added dash cam
    - re covered armrest and door fabric (deep jumanji gunmetal) matches dark gray perfectly
    -tint strip on front window
    -added BT OBD2 & Torque App
    -suede dash mat cover
    -karma wifi hub (removable)
    -Lower center console cup holder
    -4$ worth of knockouts at Lowe's for center caps. Best bang for buck EVER!
    This is what I did this week...
    I'll try to take pics of all these mods/add-on's tomorrow.
    I'll be back on the road the next two weeks so if you're in Albany NY or Toledo Ohio come out to the funnybone! We'll #priuschat
    saulbassfan and Burna J like this.
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,234
    Orange County, CA
    Crap-o-la! ! You need to do a mod party us all!! Going to be doing this next
  11. CosbyComedy
    46
    52
    Columbus Ohio
    Here's some photos of Phase 1. With 213,000 Miles my ride has some severe road rash on the front end but still cleans up nice. I'd like to add the Clazzio seat covers but can't seem to pull the trigger. This is less than $400 in add on's with about $300 of them being stereo related.
    If i go into a phase 2 it will be a front end replacement. Hood, Bumper cover, and 2 fenders. My mouth waters and head aches simultaneously over this quandary.
    -TIP! You only need 1 - 1.5 yards of material to cover all your doors. 1 if you're meticulous 1.5 if you're not.
    Montgomery, Starbrand and Burna J like this.
  12. Montgomery
    2,254
    2,234
    Orange County, CA
    I'm really digging your doors!! That is on my "do or die trying list"
  13. CosbyComedy
    46
    52
    Columbus Ohio
    On a whim... Already wired all I need to do is hook it up... I'll let ya know! 1471981086324.jpg
    HelloHybrid likes this.
  14. Montgomery
    2,254
    2,234
    Orange County, CA
  15. Montgomery
    2,254
    2,234
    Orange County, CA
  16. CosbyComedy
    46
    52
    Columbus Ohio
    Its an all-in-one 8"sub with a 200w RMS amp built in. It's amazingly small yet not easily mounted to the back of the seat like I hoped.
  17. CosbyComedy
    46
    52
    Columbus Ohio
    Here is the"stealth" subwoofer mounted. It sounds great for the size. I'll be honest I want a little more thump but for just one 8"woofer I'm pretty impressed. I think I'll order another one next week. Mounting to the back of the seat improved the overall bass response. 1472069960086.jpg 1472069969059.jpg
    HelloHybrid and Johnsk93 like this.
  18. CosbyComedy
    46
    52
    Columbus Ohio
    Maybe I'm going to deep into detail with these but I've always hated the exposed bolts on the seat mounts. So I did this... 1472499491008.jpg 1472499506563.jpg
    I googled "seat bolt covers" & $11 later I had these 4 plastic caps that fit with double sided tape. #worthit
    Johnsk93, saulbassfan and HelloHybrid like this.
  19. Montgomery
    2,254
    2,234
    Orange County, CA
    I'm still recovering from the wonderful job you did on the doors!!
  20. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    So far, I love what you've done. Keep up the good work.
