Finding a nice Water Purity system
Discussion in 'Environmental Discussion' started by hill, Aug 26, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I hope I never get dysentery to find out if I can buy yummy camel dung
    Deionized water is typically used in the semiconductor industry, and in chemical analysis labs. It must be used with special piping that is resistant to DI water
    DI water is - essentially - water with all the ions removed. This makes the DI water a damn good solvent. Bad effects for your gut
  2. hill
    9,026
    Really? Now we're talkin' !! Got any name brands in mind ?
    In the interim ... I'll get busy & see what I can find. I really bust my hump, drying my PV panels quickly so as not to leave behind any minerals.
    camel pooh? I'll pass on that
    :rolleyes:
  3. Trollbait
    12,818
    The Mr. Clean hose attachment was mentioned, I don't know of any others or how often you'll have to change the cartridge. If you don't mind rinsing the car and panels by bucket, look into DI and RO units for aquarium water. I had a small tap mounted one that cost around $30 at the time. It did the job for mixing up salt water. I don't any will dispense at a rate to allow hosing thing off.
    If you go with a ion exchange softener, get the largest resin bed in your budget and install space. Modern units measure water flow and recharge the bed based on that the incoming water's hardness. A larger bed means a longer time between recharges, and thus less energy used.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    One of the problems is that it contains few ions. Since human intestines are semi-permeable membranes, and humans are basically filled with salt water, DI water is pulled through the intestinal lining and absorbed into the blood stream by osmosis. Fluid pressures build leading to edema. If you drink enough, your lungs will fill and you will drown in your own fluids. Lesser amounts will lead to organ damage.
    Tom
  5. blackpolish
    blackpolish New Member
    24
    KY
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    Yep, not exactly pleasant stuff to chug down
    For some reason, DI water appears to make fairly decent coffee. But the coffee maker doesn't last very long
    YOu know how most cheap plastic coffee makers have a rubber/plastic tube that carries the hot water up to the dispenser into the basket? We never got more than 2-3 weeks out of a coffee maker before that tube rotted out and the coffee maker engaged in an endless cycle with the water level never changing
    That facility, the tap water was so hard, the coffee maker died almost as quickly if we used it straight from the tap. Not to mention the coffee then tasted like s***
  7. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    83
    Camas, WA
  8. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Would a handy little solar distillation unit do the trick?
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    In terms of cost and if you're patient, yes. Otherwise, the Costco unit or the Aquasana unit will work well
  10. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I found this thread via search.
    I recently purchased the below unit for using on the final rinse of my Prius, and am quite happy with it so far:
    Portable Water Deionizer
    Cleaning Tools
    Car Washing
    Car Care
    - Griot's Garage
    This wasn't out yet at the time this tread was originally created.
    This unit is better than the CR Spotless unit in terms of build quality. It also has a diverter so you can only have it filtering for the final rinse, which should make the resin last longer.
