Finding a short in a Gen 1
Discussion in 'Generation 1 Prius Discussion' started by Graham Hopkins, Dec 16, 2013.
  1. Graham Hopkins
    Graham Hopkins New Member
    2003 Prius
    I
    On a Gen 1, 2003 prius, dome 15 amp fuse # 17, which controls audio system, multi info disp, interion light, trunk light, power window system (which still works), and wireless remote control system has blown and continues to blow when replaced, with the car off. Any advise on the most likely suspecs?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Have you tried removing the dome light bulb and see if the fuse does not blow? Others have reported the bulb itself as the culprit.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    You'll just have to try to disconnect the components/bulbs one at a time until the fuse stops blowing. Buy a bunch of fuses.
  4. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    To do this type of electrical fuse fix, I made a circuit breaker so i did not keep busting through fuses. Radio shack 15 amp breaker with a button soldered with two wires with the ends crimped into spades. Put the two wires with spades into where the fuse would go. The button on the breaker pops out when it blows. Just push it in and start again. Works like a GFCI sort of in your house.
    TomK
    usnavystgc likes this.
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Radio Shack part numbers and links would be appreciated. :)
    SCH-I535
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Good move with the circuit breaker. Keep us posted when you find the culprit.
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    He's not the OP though. ;)
    SCH-I535
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Thanks, did not pick up on that.
  9. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I looked a bit and can't seem to find it. I have mine in front of me and it is a 20A. Manufacturer is T.S.D. P/N 131-0004. I'll keep looking.
    TomK
  10. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
  11. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    A headlamp bulb wired across where the fuse should be in the same manner as the circuit breaker. will work much better. While the fault is present the bulb will stay lit at full brightness, when the fault is cleared the bulb will go out or go dim depending on the load. This will give you a clear indication of the state of the problem while you are working. Any intermittent fault will cause the bulb to flash as the fault is cleared and returned.
    The maximum current that can be drawn under fault conditions using this method is about 5 amps "the loading of the bulb" no matter what you are doing.
    With a circuit breaker the maximum current will be between 10% and 25% over the rating of the breaker. With a fuse the current to blow the fuse can be up to 200% over that of the fuse rating.
    John (Britprius)
  12. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    I also have that John. And your info is correct. I used an old school headlamp since it had two metal prongs on the back of it. I built the circuit breaker simply since I had an issue where I needed to drive with it and the headlamp was so large. Just did not want to keep spending on the little fuses after blowing an entire box of them once.
    TomK
