Finding Shops OTHER than Toyota for Service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by qdllc, Mar 7, 2017.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I almost replied to that one, but thought it was too easy and must be a trick question. I don't think it would be good to mix inverter coolant and transmission oil. :eek: Bacon and chocolate, on the other hand ... :D
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    You need to start opening your own Prius shop and do these easy maintenance lol :ROFLMAO:
  3. qdllc
    qdllc Senior Member
    1,377
    400
    I did, and I might rethink it. Obviously I'd want to do it when the wheels will be off anyhow.
    Raytheeagle and jerrymildred like this.
  4. Mendel Leisk
    42,331
    Yeah I did it last fall when swapping to snow tires. There was a lot of follow up questions regarding the use of vacuum pump in that thread. It's maybe nice, but not mandatory. I just used a tube with bleed bolt connector pushed on the end, and a kilo size mayo jar to catch it.
    And for basting out the reservoir a big syringe, with short length of tube. There's one gotcha with the reservoir: it has an internal "basket" with just a narrow slit. To get a tube down near the bottom it has to be very skinny. I realized this just as I got into it, so pushed a thin vacuum tip on the end of my tubing, you can see in the pic. But a long thin tube would be better.
    When doing the fronts, watch @NutzAboutBolts video carefully. The assistant pushing the brake pedal will drop the pedal to the floor pretty quick. When you're cracking open the bleed bolt it should be very quick open/shut bursts.
    With the rears it's easier, assistant steps on brake and a pump continuously pumps fluid.
    #24 Mendel Leisk, Mar 8, 2017
  5. Mendel Leisk
    42,331
    OTOH, the quote for brake fluid change is pretty reasonable. If you go that route, caution them to test drive the vehicle afterwards, and check that they haven't lost any bleed bolt caps.
    Our last "pro" brake fluid change, on a Honda, was a bit of a gong show. Finally got it sorted, but they royally screwed up first time around: left the vehicle with one rear brake non-functional.
  6. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    Yup, brain fart.
    bisco, jerrymildred and Mendel Leisk like this.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    I think the term in polite company is "cranial flatulence." But I'm sure "brain fart" is fine here. :D
  8. qdllc
    qdllc Senior Member
    1,377
    400
    Do I really need a vacuum bleeder? I've always done brake line flushes with a plain hose, wrench and old glass jar. It doesn't look like a vacuum bleeder does much but try to pull more through in a shorter time.
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    When we do mine at month end, we will not be using a vacuum system. It will be plastic tubing with a catch can at the end.
    No need for a vacuum system. An assistant helps though(y).
  10. qdllc
    qdllc Senior Member
    1,377
    400
    Also, odd issue....
    The log in the manual for the 2013 Prius indicates Coolant changes at 100K and ATF change as never unless you're towing, then it says every 60K. You'd think they'd set a mileage interval for ATF change even if you're not towing.
  11. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    They claim it is "lifetime" fluid:whistle:.
  12. Mendel Leisk
    42,331
    Just latch onto that towing interval? Still, I'd do an early change, say at one year mark, regardless of mileage, judging from mine: it's the dirtiest in appearance.
    No. Some sort of baster, with a very slim tube to fit through the slit in the reservoir internals, is the only time you need suction.
  13. NutzAboutBolts
    1,756
    1,789
    Bay Area
    yeah, you don't need a vacuum bleeder to do the brake flush.
  14. Pijoto
    Pijoto Active Member
    200
    153
    Dallas, TX
    Can understand why you would want to change the ATF, based on all the info from this forum, but I never read a post here about changing the Inverter coolant at 50K....do that at the recommended 100K miles and save yourself the hundred bucks or two.
  15. qdllc
    qdllc Senior Member
    1,377
    400
    Well. that wasn't so bad.
    Just over 50K. Brake flush was easy peasy. ATF change wasn't that hard either. Put in just about 4 quarts, recovered just about 3 1/4 to 3 1/3. Key was to pump the stuff in SLOW. I had fluid dripping out the fill hole, but I only stopped when it became heavy and kept coming out when I removed the hose.
    Did break a couple of those plastic fastener thingys. One of the big ones and a couple of the small ones. Anyone have links on where to order replacements on the cheap?
    Raytheeagle and Mendel Leisk like this.
  16. qdllc
    qdllc Senior Member
    1,377
    400
  17. Mendel Leisk
    42,331
    Congrats on getting all that done. (y)
    This attachment has the part numbers. I've had our engine shield off (for oil change, and/or transaxle fluid change) maybe 11 times now? To the best of my recollection I've yet to lose or break any of those plastic fasteners. I think the more often you remove them, and do it carefully, and wash them out thoroughly, the less likely it is they'll break. Also, if you've had pros working under there, chances are the fasteners have been abused: they're in a rush.
    The regular size clips and larger (grey head) ones are items 3 and 5 respectively, in the attachment. Parts numbers:
    Regular: 90467-07201 (item 3)
    Larger, grey head: 90467-09227 (item 5)
    #37 Mendel Leisk, Mar 19, 2017
    jerrymildred likes this.
  18. qdllc
    qdllc Senior Member
    1,377
    400
    Both on Amazon...thanks. :D
  19. Mendel Leisk
    42,331
    Yeah I noticed the smaller ones in particular (...07201) are a good price, a 30-pack IIRC. The larger, grey-headed (...09227) a little pricier, through Dorman.
    #39 Mendel Leisk, Mar 20, 2017
  20. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    $7.88 for a pack of 20 for the smaller ones. Will be getting them for this weekend just in case ;).
