Finding source of a little drag
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pasadena_commut, Apr 5, 2025.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,998
    931
    Southern California
  2. Leadfoot J. McCoalroller
    8,264
    7,768
    Pennsylvania
    2018 Prius c
    Interesting, but I'm not sure what to do with the information. Bad link in their database? Timken repackaging genuine Koyo parts?
    I like rock auto in general, but in a situation like this where it is difficult to determine provenance and confidence, I'd skip them and use a local brick & mortar supplier.
  3. pasadena_commut
    2,998
    931
    Southern California
    Apparently Timken is Koyo, or the other way around, at least most of the time. See this discussion:
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    A couple of questions.
    Are the TPMS sensors in the wheels working properly?
    Via Techstream, they allow you to see the difference in pressure and temperature readings in the tire.
    Also, via Techstream, it records the rotation speed of the wheels.
    All four wheels. The fifth wheel has the speed of the car by default.
    Was any diagnostic tool used other than a finger and forehead?
    All data recorded by diagnostic devices either confirms or refutes all thoughts.
      File size:
      117.1 KB
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    6°F is statistically insignificant. Only a slight increase (differential) in heat after driving at any reasonable speed is the result of a TINY difference in drag.
    IMO the time and money needed to try and "find the cause" at this time exceeds any possible benefits.
    The most I would do is periodically monitor TPMS temperatures as suggested. If there is any increase then chase things.
    Brian1954 likes this.
  6. pasadena_commut
    2,998
    931
    Southern California
    TPMS is working and in any case all the pressures have been checked a couple of times with a gauge. Faster and easier to get the pressures that way than hauling out a laptop and cable. This isn't a low pressure issue. The tire shop obtained 3 of the tires from one source and the last one from another. They all have the same manufacturing date. The tire on the wheel which is a little hot is probably the odd one out, because it was (a little) dirty, while the others were clean. Never heard of a tire which runs hot at normal pressures though, but I suppose it's possible.
    6F between tires may not be functionally significant but it is statistically significant. That is many standard deviations from the mean of the other three temperatures. Those temps were always really close, a fraction of a degree separating them, and the meter probably isn't even accurate to those small differences.
  7. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    During movement, any tire heats up. This is a physical process from the friction of the tire on the road surface.
  8. pasadena_commut
    2,998
    931
    Southern California
    Agreed. But identical tires under nearly identical conditions should heat up the same amount.
    The two front tires are each carrying very nearly the same weight, are at 35 PSI, and travel nearly identical paths, yet the one on the left is heating up more than the one on the right. The one on the right is heating up the same amount as the two on the back, and those are carrying less weight, at 33 PSI, and still traveling nearly the same paths. I can imagine a defective tire running hotter than the others, but think it more likely to be a wheel bearing or brake issue. This weekend I will try to swap the front wheels, which will either indicate a tire level problem or rule it out after the next long drive.
  9. pasadena_commut
    2,998
    931
    Southern California
    The difference in temperature seems to be slowly going up. This past Saturday it was a full 10F between that wheel and the other. Didn't have a chance to swap the front tires until today, then took it for a 20 minute drive. It was cloudy, so no direct sun to heat up one side or the other. Measured these temps right after coming off the highway:
    location (spoke near hub) (on rotor through spokes)
    D Front 82.4 87.2
    P Front 71.6 70.8
    D Rear 70.3 NA
    P Rear 74.4 NA
    So it stays in the corner and doesn't move with the tire. It would have been really peculiar if it had.
    When the car was up on jack stands the front passenger side wheel rotated more freely than did the front driver side wheel. Odd that either would turn at all since it was in Park, but maybe that's how it works when the axles are hanging? I looked closely at the brakes and didn't see scoring or anything jammed between the shield and the brake. The pads on both sides looked about the same, both in their thickness and their position on the rotor (that is, they both seemed to be right on the rotor, but no way that I could see a tiny gap which was present on one and not the other.) I'm thinking slightly dragging brake rather than bad bearing, since the rotor was hotter than the wheel on one side, and the same or other way around on the other. Questionable logic since the hub and the rotor are bolted together.
    The 3.1 degree F difference in back suggests that maybe it is time to empty the dust out of the drums again. Or that might be just statistics - those 3 lower values have a mean of 72.1 and a std deviation of 1.71.
    #29 pasadena_commut, Apr 17, 2025
  10. Leadfoot J. McCoalroller
    8,264
    7,768
    Pennsylvania
    2018 Prius c
    The parking pawl only locks the sum of the differential.
    With both drive wheels in the air, you can always spin either because the diff will just force the other wheel to spin in the opposite direction while the input remains locked.
    This isn't a Prius thing, every 2WD differential drive system with a park-locking transmission (aka most street legal cars) works this way.
  11. pasadena_commut
    2,998
    931
    Southern California
    Have been making a point of not checking the hub temperatures. However, since it has been roughly a year since the last test, I felt the driver's front yesterday (on a spoke about 1" out from the lug nut) after a short freeway run and it was way more than 10F warmer than the other wheels (which were, as always, about the same as each other.) Not hot enough to burn a hand or anything, but hot rather than warm. So today grabbed the IR thermometer and went for a highway drive of 16.9 miles and 20 minutes (path and duration resulting from trying to avoid very low speed parts of the "freeway"), which is 50.7 mph average. Measured the temperature (all in degrees Fahrenheit) as before, and also on the rear drums this time (2025 data copied from post 29):
    position | 2026 | 2025
    D Front | 90.6 98.6 | 82.4 87.2
    P Front | 77.9 81.8 | 71.6 70.8
    D Rear_ | 75.7 77.7 | 70.3 NA
    P Rear_ | 79.5 82.9 | 74.4 NA
    Which is pretty much the same, albeit a little hotter everywhere because of different drive, air temperature, or whatever. Nothing here to suggest a significant change, although the front driver side might have gone up slightly. Interesting that even with the uncontrolled variables the measured temperature of the wheels are in the same order hottest to coldest: DF, PR, PF, DR. Makes me think the temperatures really do result from drag in the wheel bearings, with the 3 original OEM ones being lower friction than the replacement Moog bearing.
    Wheel spoke Delta D - P is
    D-P front | 12.7 | 10.7
    D-P rear_ | -3.8 | -4.1
    By feel the wheel spoke near the hub was cooler today then yesterday. Pretty sure the hot vs. warm temps are a speed thing, because the highway was wide open yesterday and the drive was over 70 mph the whole way, but the highways were more congested and I couldn't go that fast, rarely above 60.
    #31 pasadena_commut, May 15, 2026
  12. pasadena_commut
    2,998
    931
    Southern California
    My wife and son reported today that they can hear a high pitched noise from the driver's front corner when the car is over 35 mph. I can't, but since I can't hear pretty much anything over 3 kHz that is not surprising. My wife says that it makes the noise almost continuously, but that it does drop out for "a second" at long irregular intervals (in a straight line, no braking or turning to account for it). I played some ABS sounds for her and she said it wasn't that, much higher pitched. Probably the #$#$#$ Moog bearing.
  13. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Have you checked that "squealers" are not contacting the rotor in that corner?
  14. pasadena_commut
    2,998
    931
    Southern California
    That is on the list. The pads were changed at the same time as that bearing, they really shouldn't be very worn. Will take off that wheel and get a good look at the pads, probably this weekend. We watched several videos with brake pad indicators making contact and I could hear that sound in every one, but I cannot hear this one. My son said this frequency is much higher, and also much quieter than a pad indicator.
    I had to drive him somewhere today and during that ride ruled out that the sound had anything to do with the ICE, since that could start/stop with gas pedal pressure, the speed stayed very close to 35 mph, and he said the sound didn't change. Pressing the brakes pretty hard did not cause the sound to appear at low speeds, which I would have expected it to do with a wear indicator. One thing that did change it was a long sweeping right hand turn at around 25 mph (which is below the speed he can normally hear it), during the turn he could hear the sound, and before and after he couldn't. That is consistent with a bad driver's side front bearing, albeit not usually at this frequency range. Son says it gets louder as the speed increases above 30 mph, again consistent with a bearing, and this held up to 45 mph, which was the fastest we could manage on this route today.
  15. pasadena_commut
    2,998
    931
    Southern California
    Empty wide street today at around 40 mph, drove it in an oscillating left/right path down the middle. Son said it was loud when curving to the right and quiet when curving to the left, every time. Just like a wheel bearing. Just strange it is so high pitched. Once again, I couldn't hear it.
