Fire in back
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tpirsig, Dec 5, 2017.
  1. tpirsig
    tpirsig Junior Member
    2005 Gen II, 225k miles: This just happened to my girlfriend, she said smoke was coming out so she pulled over and doused it with water. She's a couple hours from home. Is the car safe to drive? What are these components? We've had a ton of rain lately and I'm guessing there was an electrical short (water leaks into the rear hatch area).
  2. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
  3. JC91006
    16,474
    8,393
    Hazardous guess here.....but NO, it's not safe to drive. It caught FIRE
  4. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Ouch. Never worked on a 2nd Gen so not familiar with the item/system burned up. At minimum, a fuse or two should have popped to identify. IF there is no longer power to the component and this system is not mandatory for safe driving...she should be OK to drive it home. However with all the unknowns and it being a week day, I would have it towed after doing a once over myself first.
    scona likes this.
  5. JC91006
    16,474
    8,393
    There's nothing under that burnt area......closest thing to it is the HV BATTERY interlock switch and SKS sensor.
    If somehow water built up under the trunk tray, it could have shorted out some things. You can see if there's a pool of water there.....and the pool would be pretty big
    #5 JC91006, Dec 5, 2017
    m.wynn likes this.
  6. scona
    scona Active Member
    225
    206
    2013 Prius v wagon
    Difficult to tell from that picture but it could be in the area of the high voltage battery. If so she would be ill-advised to drive it without proper advice from a Toyota dealer. Best to be safe, the voltage of that battery is extremely high.
  7. tpirsig
    Thanks all for answers so far. It's near the HV battery but not part of it, and not part of the battery HV switch. There was a relay of some type there -- I know because when recently replacing the rear struts I noticed it had a corroded base and so I cleaned that up. The car is still running and all signals / horn / wiper etc still work.
  8. Mendel Leisk
    38,644
    Levity is likely the last thing on your mind right now, sorry, but this popped into my head:
  9. tpirsig
    Here are the wires leading to that relay (which incinerated). The car appears to run fine without it. Sure wish I knew what the relay was. It was a silver box mounted on a small L-shaped stand.
    m.wynn likes this.
  10. JC91006
    16,474
    8,393
    It's the SKS sensor. It's either for keyless start or keyless entry. I haven't figured out that part yet.
    Good thing to bring up to Toyota, that it caught fire. We might get some type of recall out of this
    #10 JC91006, Dec 5, 2017
  11. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Does she have any other alternatives for getting home? If there were water leaks to start with, which caused the electrical short and fire, pouring more water in to douse the fire will only make it less safe to drive. That HV battery is still capable of causing an even larger fire.
  12. tpirsig
    Thank you! Just to confirm, this is what we're talking about:
    Raytheeagle likes this.
  13. JC91006
    16,474
    8,393
    yes. Good thing is those things are a dime a dozen at junkyards
    m.wynn and tpirsig like this.
  14. tpirsig
    Update: I had her test drive the car a short distance, check for heat or any hot wires, and there's none. So she's on her way.
    m.wynn likes this.
  15. tpirsig
    No other water in car / water that she poured didn't go into HV area. Thanks for your concern. At this point I'm no longer thinking it was water back there that started the fire -- the water collects in very low areas, not at all up high where this is.
  16. frodoz737
    4,297
    2,348
    33
    You were definitely cooking back there. You might get lucky with component/plug/wire replacement, but the harness it attaches to looks cooked too and really needs to be unwrapped and checked further. Pick your Wife up at the Dealership and have them do a thorough check out.
    davecook89t likes this.
  17. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
  18. tpirsig
    Further update: She made it home fine, after 3 hours of driving. Looks like just the SKS sensor was affected (adjacent wiring did not get scorched), plus of course the melted plastic in the rear cargo tray.
    m.wynn and davecook89t like this.
  19. JC91006
    16,474
    8,393
    Still should let Toyota know there's a fire. It shouldn't catch fire.
    You probably want to get to the bottom of the cause, before repairing it
    frodoz737 likes this.
  20. bisco
    49,371
    is this the first time we've seen a fire in the back?
