FIRE! no start P3006 - P3016 - P3030 - parts & install ECU + Wire Harness to Traction Batt
Discussion in 'Generation 1 Prius Discussion' started by lovemy02prius, Sep 1, 2014.
  1. lovemy02prius
    lovemy02prius Member
    127
    ferndale
    2002 Prius
    How do you conduct ahr test??
    Not sure if you read my post earlier...bus bars off etc but did not remove the cells..
    we are charging the cells one at a time w the smart charger letting it go up to a charge volt of 8v which brings the cell volt to the 7v range.
    If we have to pair a weak cell w a strong one how do you remove the cells...do you have a tutorials link??
  2. ChapmanF
    18,195
    Don't have much idea what's in throttle-body cleaner but it usually makes pretty short work of carbon coatings. (Use outdoors. Breathe Real Airâ„¢.)
    -Chap
  3. lovemy02prius
    127
    ferndale
    2002 Prius
  4. lovemy02prius
    127
    ferndale
    2002 Prius
  5. bwilson4web
    16,215
    Based upon what I understand of the protocol used:
    mod rest V status
    1 1 7.77
    2 2 7.43
    3 3 7.31
    4 4 6.73
    5 5 6.9
    6 6 6.86
    7 7 7.21
    8 8 6.42
    9 9 6.57
    10 10 6.75
    11 11 6.5
    12 12 6.22
    13 13 6.11 at risk
    14 14 5.11 bad
    15 15 3.75 bad
    16 16 7.76 at risk
    17 17 7.28
    18 18 7.16
    19 19 7.07
    20 20 6.55
    21 21 6.97
    22 22 6.89
    23 23 6.66 at risk
    24 24 5.12 bad
    25 25 7.01 at risk
    26 26 4.52 bad
    27 27 5.41 bad
    28 28 5.26 bad
    29 29 7.3 at risk
    30 30 7.29
    31 31 7.8
    32 32 7.02
    33 33 7.5
    34 33 7.5
    35 34 7.91
    36 35 7.72
    37 36 7.77
    38 37 7.93
    39 38 7.73
    • Charged to +7V
    • Left no-load for an hour or so
    • Above are reported voltages found
    Any module that drops below 6.0-5.8V should be considered bad. Even without a load, it is not holding a voltage which means it is not holding a charge. But resting voltage, self-discharge, is not a true test of the Amp hour (Ahr.)
    Any brief load, say a parking or dome light, briefly touched to the terminals will trigger an almost immediate drop in voltage and the light will go out. But a good module will keep the light burning as it discharges. It is the rapid, in seconds, drop of voltage that is the mark of a failed module.
    So what is the make and model of the "smart charger?" My MRC 989 has both a controlled charge and discharge and records the Ahr of both. The charge is nice to know but the true metric is the discharge Ahr.
    The Amp hour is a measure of how many amps are provided over an hour. So a 1 amp load over 6 hours is the same as a 6 amp load over 1 hour. So you can make a reasonable Ahr test by having a low resistance, power resistor, a voltmeter, and a watch. Extreme accuracy is less important than have a relative Ahr so you can tell if any of these modules are serviceable. For example:
    • 100 ohm, 2 watt resistor
    • jumpers
    • VOM
    Protocol:
    1. Charge module to 7.5-8.0 V
    2. Monitor voltage across the 100 ohm resistor
    3. Connect it to module and write down starting voltage, Vhigh
    4. Disconnect when voltage reaches 6 V, Vlow
    5. (Vhigh + Vlow) / 2 ~= Va average voltage (*)
    6. Va / 100 ohms ~= average_amps
    7. average_amps * time_in_hours ~= Amp hour
    My experience is a bad module will have a time measured in seconds. Potentially serviceable ones will run for +6 minutes. But a good battery charge/discharge unit will actually do the hard work and display the Ahr or milli-Ahr. Still, the resistor, voltmeter, watch is what humans did 200 years ago. <grins>
    * - There are non-linear discharge characteristics that could be modeled in excel to give a more accurate metric. However, a human is measuring the voltage and time and such degree of precision is below the precision of an exact math model. In engineering, we call this 'good enough.'
    #85 bwilson4web, Sep 13, 2014
  6. lovemy02prius
    127
    ferndale
    2002 Prius
    Bob: So what is the make and model of the "smart charger?" My MRC 989 has both a controlled charge and discharge and records the Ahr of both. The charge is nice to know but the true metric is the discharge Ahr.
    M: I'll post the name/model of the smart charger when i get to the shop this morning.
    It does have a "discharge" feature and a state of the art display and screen & menu lol
    and can read Ahr of charge and discharge (i just dont know how to use that feature, ill look at it when i get there)
    Bob: My experience is a bad module will have a time measured in seconds. Potentially serviceable ones will run for +6 minutes. But a good one will actually do the hard work and display the Ahr or milli-Ahr. Still, the resistor, voltmeter, watch is what humans did 200 years ago. <grins>
    M: a good what?? smart charger? so i can use the smart charger to run the test & read the results? As far as the Ahr test its a "Load Test" right??? can i use the "discharge feature" of the smart charger as a "resistor"? any simple lay-mans instructions of using the smart charger to run the test would be helpful (lol sorry im very challenged in this area) also lay-mans items i can use that maybe laying around the shop let me know as this part is really testing my scientific abilities..lol
    ALSO
    why #14 cell "at risk" since its at 7.76 v, Is there anyway to re arrange the order to correct this risk factor?
    Finally the cells labeled BAD in the chart....are you sure they are BAD??? should i even bother to run a resistance test on them??
    The rest of the cleaning and parts swap is complete except the bus bar which im thinking of having plated or using this one and plating the one that comes in the mail and swapping it later..
    THANKS were so close
  7. ChapmanF
    18,195
    Yes, a good smart charger. :) And yes on the subsequent questions. Only I don't know what model charger you have and you're more likely to have the manual for it than I am, so the person who needs to look up the proper settings might end up being you.
    I'm confused ... haven't you already picked up your repair kit with bus assemblies in it? Is there another coming in the mail??
    I'm not sure how much sleep to lose over the plating. Dorman builds 'em that way, Toyota doesn't, and the 5% failure rate over 12 years that Consumer Reports recently calculated seems to indicate Toyota's way isn't all bad. The $50 for plating doesn't seem like a lot, it's more you having to sit there and pop 36 little copper things out of the plastic carriers and take them to the plating shop, then pop them all back in, until you find out you got 35 back and one fell off the hook and nobody wanted to dive in the electrolyte vat and find it. At least, that's the sort of thing that happens when I farm stuff out....
    -Chap
  8. lovemy02prius
    127
    ferndale
    2002 Prius
    Lol chap..
    Ok Bob the smart charger is a Triton - computer charger and dis-charger and cycler
  9. lovemy02prius
    127
    ferndale
    2002 Prius
    Just retested
    There are 17 cells under 6v
    One opinion of a battery expert her is the cells just took a surface load yesterday and should
    Charge them again (-kim he is an expert in normal batteries not hv)
    Ok I see the discharge setting on the smarty charger. I dont see a watts option so far. How many amps do we set it on to do the discharge test (aka resistance / load test)
  10. lovemy02prius
    127
    ferndale
    2002 Prius
    Heres our starting volts after 13 hours
    1. 7.7
    2. 7.3
    3. 6.5
    4. 6.05
    5. 6.09
    6. 5.79
    7. 6.17
    8. 5.2
    9. 5.76
    10. 5.9
    11. 5.09
    12. 3.837
    13. 4.42
    14. 3.943
    15. 2.895
    16. 7.53
    17. 6.77
    18. 6.86
    19. 6.39
    20. 3.991
    21. 5.06
    22. 5.26
    23. 4.76
    24. 3.472
    25. 5.92
    26. 3.02
    27. 3.842
    28. 3.448
    29. 6.78
    30. 6.82
    31. 7.64
    32. 6.01
    33. 7.19
    34. 7.66
    35. 7.03
    36. 6.76
    37. 7.56
    38. 7.81
  11. lovemy02prius
    127
    ferndale
    2002 Prius
    Were running a test:
    Were letting the smart charger charge #15 (the lowest v cell) and allowing it to keep charging til the sc beeps instead of stopping it at a charging v of 8
    Trying to determine if it had a surface charge and can charge & hold a higher v
  12. bwilson4web
    16,215
    I was thinking about the charge/discharge power supply when I posted a "good one" even though the paragraph was about the modules. It sounds like your smart charger might have what it takes.
    When a module fails, it runs hot. This locally heats the adjacent modules and often leads to their early failure. So we look closely at them.
    The charge/discharge function takes time. A 1 amp, it can be close to 6 hours for each charge and the subsequent discharge. But a failed or weak module will take a much shorter time.
  13. lovemy02prius
    127
    ferndale
    2002 Prius
    Ok if the charge/discharge takes up to 6 hours then did we just surface charge them? Because we charged them for no more then 7m-30min apiece
    What charges the batteries as their being used on these 01-03 prius hybrid car?? An alternator???
    can we put the battery on the car and let the car charge the batteries? lol
    will the car not function at all w one bad cell?
  14. lovemy02prius
    127
    ferndale
    2002 Prius
    Yes now im asking girl question LOL
    joke
    Actually were charging the cells reading 6.0
  15. lovemy02prius
    127
    ferndale
    2002 Prius
    Were charging up the 17 - 6.0v & under cells now...
    this is crazy....I know these cells can come back to life jejeje
  16. lovemy02prius
    127
    ferndale
    2002 Prius
    We charged up the cell you marked BAD to 6.5 v
    We put a 12v test light on it and although the light faded a bit after a minute, the test light stayed lit for 6minutes
    so what does that tell us??
    Is it possible these bad cels are usable?
    I don't want to put this hv battery on the car with out a good chance of not having to remove it anytime soon
  17. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    A fully charged module "6 cells" will have a voltage of around 8.9 volts. Charging to 6.5 volts will prove nothing as at this voltage the reading could represent 4 fully charged cells within the module and 2 faulty cells. So the lamp will stay alight but the module could be useless.
    You also need to be more specific about the 12 volt test lamp you are using. How many watts at 12 volts is it, or what is the current rating at 12 volts. Volts x amps = watts.
    You must also realize that at 6 volts a 12 volt bulb will only take approximately half of it's rated wattage or current "amps" than it does at 12 volts.
    John (Britprius)
  18. lovemy02prius
    127
    ferndale
    2002 Prius
    Test: charged #15 (which was at 2.427) @153pm to 8.36v (using the amart charger and allowing it to go up to a 9v charging rate at 1A per hour...
    monitoring it
    How long and at what mph do I have to drive the car to fully charge the battery once I install the hv
  19. lovemy02prius
    127
    ferndale
    2002 Prius
    I need to be clear on the "module" is it ONE of the 38 silver cases which is ruffly 10" length x 4 1/8" height 5/8" width. Ill jist call the modules from now on..
    If the "cells" are in the module then there out of my range of conversation as I cant do anything to repair anything inside the module.
    #99 lovemy02prius, Sep 13, 2014
  20. Britprius
    5,194
    1,921
    Leaving the car in D with the engine running "feet on the accelerator and brake without moving the car" will force charge the battery in about 5 minutes to 80% of full charge. At that point the Prius will no longer charge the battery as it's designed to run in the 40% to 80% range.
    John (Britprius)
