Fire Sale
Discussion in 'Gen 2 Prius Main Forum' started by DGH, Mar 10, 2014.
  1. DGH
    DGH Thread Terminator
    365
    94
    Wales, WI
    Woke up to the smell of burning plastic and found this in the garage.
    I think the block heater caused it.
    So much for waiting on the GenIV.
    Anyone need some parts, the tires are almost new.
    Dan
    [​IMG]How do I attach a pic..anyone?
  2. JC91006
    16,936
    8,647
    all those people looking for a HV battery, seems to be one available now.
    PriusGuy32 likes this.
  3. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    If it was professionally installed, then I think they owe you a new car...
    cwerdna likes this.
  4. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    the most important thing is the family is safe... the house did not burn down... Let the insurance companies fight over it.. as a stop gap you could always get a another genII with the money and not be out of pocket much if anything and get the Gen IV in a couple years...
    non_nahs likes this.
  5. DGH
    365
    94
    Wales, WI
    Yep all okay, I did the block heater eight years ago.
    Off to pick up my rental.
    Thanks,
    Dan
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    The most important thing is that no one got hurt. The Prius can be replaced, but human life is another story.
    Glad to hear no one got hurt.
  7. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    This.
    I have a few questions though... and this raises important questions in my head, as Ive read here at least once, maybe more - about a Prius catching fire with suspicion pointing to the fire originating from the engine block heater :eek:
    I surmise this is because the Prius EBH isnt installed into the cooling jacket like most other engines, where its submerged and coolant surrounds the element. Ours is a metal rod that gets inserted into the cylinder head, most likely right next to, but not submerged in, the coolant jacket.
    Once I wanted to see if my EBH was working. So I put the Prius up on ramps, plugged in the EBH and got on my back. I reached my head up near the area of the EBH and didnt feel much, so I touched the metal (Darwin moment forthcoming) lol. It was ridiculously hot and I nearly burned my finger off. It had just been plugged in for ~5 minutes. This is very different than all my other vehicles with EBH's that were submerged in coolant. You could not touch the area and get burned. It would be hot but not scorching-melt your skin- hot. Anyways, I digress..... I can easily see if something was up near that area (leaves, rodent nest, etc....) it could easily catch fire.
    So my first question is, does anybody think:
    * Should Prius owners who have installed an EBH be removing the heating element and replacing the heat transfer grease maybe every couple years?
    * Should Prius owners who use their EBH often, replace the whole assy on some kind of interval to prevent a potential short/fire? (We already know the cords are the weak spot).
    My next question to the OP:
    * How long would you leave your EBH plugged in for?
    This is for my own information, as I leave mine on a HD timer for 4 hours before I drive off to work in the morning.
    * Do you use the EBH year round, or just during the cold months?
    * Have you ever had any problems with your EBH cord?
    After just 14 months, I had to repair a piece of my EBH cord.
    Thats it. Im curious. No agenda.
  8. DGH
    365
    94
    Wales, WI
    EBH is on timer, was on for less than a hour out of about a four hour timed period.
    I use it mostly during the winter.
    The cord has been a problem, so a couple of years ago I installed a short maybe two foot store bought "extension" to eliminate the constant flex-use of the EBH cord.
    Thanks,
    Dan
  9. DGH
    365
    94
    Wales, WI
    Already received an email about it.
  10. JC91006
    16,936
    8,647
    I can't believe those people took me seriously......
  11. bisco
    52,849
    yikes!:eek: good to hear all else is okay, enjoy your new car!(y)
  12. ursle
    ursle Gas miser
    1,049
    192
    NH
    Well, I really hate that this happened, I remember inserting one in my '06, the wires just sit on the block(coming out of the hole), no sort of rubber grommet or gasket around them, and it's 120v, was wondering if they would wear through and short, 120v's sparking, now I have to look and see if I surrounded the wires with electricians tape and if not, it's a to do;)
  13. DGH
    365
    94
    Wales, WI
    I am OK with it, hopefully we can work out a deal.
    It will be up to the adjuster.
  14. DGH
    365
    94
    Wales, WI
    I would do the short extension cord thing to eliminate the stresses on the EBH cord.
    Then again......
  15. PriusGuy32
    1,417
    514
    Agree. The rest of us that use the Prius EBH frequently should view this as a gentle reminder that the EBH needs at least annual (or more) inspection of the cord, the EBH area, and maybe some kind of preventative action if we see something amiss. Im very glad that nothing worse happened to the OP such as a house fire or loss of life. Like I said, my cord shorted out last week and Ive only been using the block heater for 1.5 winters.
    DadofHedgehog likes this.
  16. JC91006
    16,936
    8,647
    Well if you were not a very ethical person.....nobody will know if you swapped the good battery for one that is not good.
  17. PriusGuy32
    1,417
    514
    With my luck, I'd swap the batteries, then the insurance company would fix the fire damage and return the car to me :LOL:
    JC91006 likes this.
  18. DGH
    365
    94
    Wales, WI
    I will take the high road whatever I do.
    aaroncv3, salguod and JC91006 like this.
  19. DGH
    365
    94
    Wales, WI
    Me thinks I am done with block heaters.
  20. PriusGuy32
    1,417
    514
    Yeah now Im seriously freaked out. o_O
