Firebrid: The Prius v Powered Hybrid Convertible
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Jul 4, 2017.
  1. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    The 3D Printer has arrived! Time to make some 3D printed parts!
  2. vvillovv
    vvillovv Senior Member
    4,321
    1,510
    NY
    How did the printer setup go? Is it user friendly, comparatively speaking? Some of um are well how do I put this, complicated just taking them out of the box.
  3. Bill the Engineer
    1,048
    2,278
    467
    Waiting for a replacement cable to arrive. One of the cables was damaged (by me) during assembly. I'll provide an update as soon as it is running.
    Montgomery and vvillovv like this.
  4. Bill the Engineer
    1,048
    2,278
    467
    First part started on the 3D Printer!
  5. Bill the Engineer
    1,048
    2,278
    467
    The completed part. It is the prototype for the steering column adapter bracket to fit the Prius V steering column into the Firebird dash mount. If I like the way it fits, then I'll use this as the foundry pattern to have the part made from cast metal.
  6. ChapmanF
    18,248
    Cast what kinda metal?
    I had an old Ford Bronco II where the steering column mount was some kinda pot-metal casting. I had a tendency to lean on the wheel when getting in and out. One day it just busted right off.
    A friend had the cast aluminum step fitting on her sailboat mast bust one day when things went a bit sideways while stepping the mast.
    She had a local machine shop copy the dimensions and mill one, which probably won't bust the same way (though I suppose that could mean it just tears up the deck instead).
    Bill the Engineer likes this.
  7. Bill the Engineer
    1,048
    2,278
    467
    Material TBD. Let's get there first!
  8. Bill the Engineer
    1,048
    2,278
    467
    Second 3D printed part is a snap-fit adapter (white part) for the Firebird center A/C Duct (black part) to connect to the air hose going to the Prius V A/C unit. It snapped right on.
    vvillovv and xliderider like this.
  9. vvillovv
    4,321
    1,510
    NY
    Looks like you have your printer all squared away. Your printed parts look great,already. Does it take much effort to spec out the designs?
  10. Bill the Engineer
    1,048
    2,278
    467
    I have the unfair advantage of having access to the Solidworks 3D CAD software, since I teach it at Del Tech. I was also a design and development engineer for over 40 years. Designing these parts is like zen therapy for me. I take whatever measurements I need on the car, then design the part, then dump it into the translation program for the 3D printer. I can usually turn out a new part that way about every 2 to 3 days.
  11. vvillovv
    4,321
    1,510
    NY
    Experience, having the right tools and knowing how to use those tools makes short work of what would otherwise be an exercise in frustration and redesign cycles..
  12. Bill the Engineer
    1,048
    2,278
    467
    vvillovv likes this.
  13. Bill the Engineer
    1,048
    2,278
    467
    The latest three 3D printed parts snapped right together on the first try. (Adapter frame, right duct, left duct.) Onward!
    Air_Boss and xliderider like this.
  14. Air_Boss
    Air_Boss Senior Member
    4,200
    1,184
    New Yawk
    Large scale 3DP parts!
  15. Bill the Engineer
    1,048
    2,278
    467
    Three steps in the 3D printing process.
    1. 3D CAD model creation.
    2. 3D Slicing program model.
    3. Final 3D printed part.
    (This is FUN! I'm having a blast doing this!)
    This part is the right a/c duct extension behind the glove box area.
    vvillovv, Montgomery and Air_Boss like this.
  16. Bill the Engineer
    1,048
    2,278
    467
    First five parts fitted together.
  17. Bill the Engineer
    1,048
    2,278
    467
    The adapter is mounted on top of the a/c unit. Now on to the connecting ductwork.
    vvillovv and Montgomery like this.
  18. mikefocke
    4,005
    1,808
    Sanford, NC
    Haven't owned a v for years but check back here to check on your progress. Impressive.
  19. Bill the Engineer
    1,048
    2,278
    467
    Before and after photos of the latest 3D Printed duct added to the Firebrid a/c system. The previous design was going to run into the wiper motor, thus the change. Step-by-step I'm getting closer to my goal...
  20. mikefocke
    4,005
    1,808
    Sanford, NC
    Hope you and your project are doing OK.
