Firebrid: The Prius v Powered Hybrid Convertible
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Jul 4, 2017.
  1. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    It's on my son's wish list...
    Prodigyplace likes this.
  2. Prodigyplace
    12,425
    11,687
    Central Virginia
    He doesn't want the Firebrid or he figures you will wear it out again?? :eek:
    Bill the Engineer likes this.
  3. Bill the Engineer
    1,048
    2,278
    467
    Everything on the body and chassis are cleaned up and ready to go to strip some paint. However the weather is alternating every 20 minutes between downpours and steam bath today. The garage door is open - closed - open - closed... I can't get good ventilation consistently in the garage for the paint stripping. Very frustrating.
    Tomorrow's weather is supposed to be better. (Fingers crossed.)
    Bill the Engineer
  4. Bill the Engineer
    1,048
    2,278
    467
    I can now see that chemical paint stripping is going to take more time than I thought. I might be out in the garage every nice night this week...
    A couple hours later now and the garage still stinks.
    Bill the Engineer
    #44 Bill the Engineer, Aug 20, 2017
    breakfast and Prodigyplace like this.
  5. Bill the Engineer
    1,048
    2,278
    467
    Day #1 of body and chassis sanding.
    The chemical stripper was an almost complete failure. The Prius v paint just laughed at it. Only the top layer of the Firebird body's paint got softened, and not everywhere at that.
    The palm sander and 80 grit paper is going to be a slow process. I have already found some body filler on the Firebird body. I'll only use the grinder on really rusty areas. The sand blaster is too much of a mess maker to use while the body is still off of the chassis inside the garage.
    More sanding tomorrow, and Monday, and...
    Bill the Engineer
    #45 Bill the Engineer, Aug 26, 2017
  6. Bill the Engineer
    1,048
    2,278
    467
    Day #2 of sanding. This is definitely going to take a lot of time and effort...
    Bill the Engineer
  7. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    That is a lot of surface area to sand and prep:(.
    No one around to help assist:whistle:?
    Good thing a 3 day holiday weekend is around the corner(y).
  8. Bill the Engineer
    1,048
    2,278
    467
    1. Oh yeah.
    2. Nope. I'm a geographic orphan. Nobody else in the house likes to get their hands dirty.
    3. Yup!
    Bill the Engineer
  9. gafortiby
    gafortiby Member
    74
    45
    Colorado
    Bill, did you consider sending it out to a body repair shop for paint stripping? It will cost money but unlike other parts of your project paint stripping is one of those jobs that you don't absolutely have to do yourself and would save a lot of time.
  10. Prodigyplace
    12,425
    11,687
    Central Virginia
    He would have to trailer the chassis (driving while sitting on a stacking chair is frowned upon.). Loading and unloading the body from a trailer would be a tricky ordeal too.
    Bill is invested on doing a top notch job on this project. Hired businesses are not as dedicated and would likely try to "cut corners" on job quality.
  11. Prodigyplace
    12,425
    11,687
    Central Virginia
    Here is what I was referring to. This is the Prius v chassis that could be driven .
  12. Bill the Engineer
    1,048
    2,278
    467
    Day #3 of sanding, grinding and drilling. I took the day off from work to have two 3-day weekends in a row.
    The Firebird body's rocker panels are stripped and ready for when the body goes back on the chassis.
    Then I moved to the body's rear wheel wells and quickly got reminded why I cut the bottom out of the car. Both rear quarters are rotted behind the opening and will require new metal to be purchased. I just hope they make the proper patch panels rather than the whole fender skin. Oh what fun to peek behind the bondo...
    I also found previously unknown collision damage only visible from the inside of the fender. That should be interesting when I strip the paint...
    Bill the Engineer
    #52 Bill the Engineer, Aug 28, 2017
  13. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    just weld in new quarters.. makes life a lot easier
  14. Bill the Engineer
    1,048
    2,278
    467
    That will need to wait until AFTER the body is welded to the chassis. Those fenders are holding the rear end on the body at the moment...
    Bill the Engineer
    Raytheeagle likes this.
  15. Bill the Engineer
    1,048
    2,278
    467
    Having computer problems. I'll post updates when I can.
    Bill the Engineer
  16. Bill the Engineer
    1,048
    2,278
    467
    The old Laptop is dead. Setting up the new one is taking time...
    Not much to report that is photogenic this weekend. Spent much of my time grinding / scraping / sanding layers of undercoating off of the rear wheel wells of the body. Dirty job, even with power tools. Not even finished one side yet. Then there is also the rot that needs to be dealt with...
    Just think of the arm strength I am building though.
    Bill the Engineer
  17. Bill the Engineer
    1,048
    2,278
    467
    This was the weekend to work on the Firebrid cowl in preparation for the body drop later in the fall.
    Saturday was spent roughing up the surfaces so that primer would adhere, then using Eastwood Prep to clean the surfaces. Porous edges received masking tape to fill holes.
    Sunday was used to apply the first coat of seam sealer on the side of the seams opposite the tape. I applied a generous amount since I don't want my feet wet when I am driving the car. It is curing overnight before I remove the tape, although in some areas I was able to start on the second side before nightfall.
    I'm taking a day off tomorrow since the weather should be nice. I'll post an update tomorrow night. The goal is to get primer on any bare metal once it is watertight.
    Bill the Engineer
  18. Bill the Engineer
    1,048
    2,278
    467
    Seam sealer completed on the cowl and weld-thru primer applied. I also found a location where the PREVIOUS owner had drilled a hole and caused a leak into the interior. That puppy got sealed up too!
    Next weekend on to another location on the body or chassis.
    Bill the Engineer
  19. Beachbummm
    1,160
    392
    we have primer, that's the home stretch!
    next some color then duct tape the body on and itsa good to goa
  20. Bill the Engineer
    1,048
    2,278
    467
    If only...
    Not much photogenic from this weekend. Nothing is so exciting as scraping 1/4 inch thick undecoating from a 50 year old wheel well.:confused:
    Hey, at least it's progress...
    Bill the Engineer
    #60 Bill the Engineer, Sep 17, 2017
