First 5 minutes MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by Fin, Jul 17, 2020.
  1. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    And the rest of the year, you have everything else. Me? I have a/c loads most of the year so no real big ups and down but my Energi would fire up the ICE anytime I used the windshield defogger during cooler weather. But those exceptions don't make the norm as that plug-in eliminated thousands upon thousands of unnecessary and inefficient ICE starts the rest of the time on my watch and achieving an 84mpg (indicated) lifetime.
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    NO. Not when it is just sitting there doing nothing it won't.
  3. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Hmm..that's not what I read. Time to call in the gurus.
    @Raytheeagle So...if you turn on a Prius Prime and use the heater under 14F...does the engine turn on?
    Raytheeagle likes this.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    We don't have 14 F temps out here :).
    But that's the thresh hold;).
    @john1701a can confirm and has seen it first hand (y).
  5. Tideland Prius
    16,675
    Yes but only if you use the engine immediately after unplugging the block heater. Otherwise, it’ll cool down and negate the advantages of plugging in the EBH in the first place.
    The Prime does have active grille shutters to aid in warming up but note it doesn’t completely close in sub-freezing temps to reduce the risk of ice buildup on the shutters and the potential of them breaking when the grille shutters are moved.
    farmecologist likes this.
  6. fuzzy1
    10,691
    Don't forget that "plug-ins" include vehicles with no block in which to put a block heater. Tesla makes zillions of them.
    As for the plug-in vehicles that do have an engine block, those really cold temperatures are somewhat of a corner case to this issue. Most of the time, that temperature threshold is not crossed.
    #26 fuzzy1, Jul 18, 2020
  7. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Someone used to make oil dipsticks that heated up. I never saw one though.
  8. Mendel Leisk
    42,310
    There's a heating pad you can glue to the underside of sump. Never tried it though.
  9. sam spade 2
    7,035
    2,804
    2017 Prius c
    What we have here is a failure to communicate.
    IF.....it is "turned on", it is NOT just setting there doing nothing.
  10. farmecologist
    1,960
    1,801
    Southern MN
    Well..then I read too much into your response...and your initial response was even dumber that I thought...unless you were "joking". :whistle:
    Sheesh..I see why you don't have the best reputation around here...
  11. farmecologist
    1,960
    1,801
    Southern MN
    C'mon folks...we all know we are discussing plugin hybrids here ( NOT TESLA!! )..hence the engine block heater discussion.. (y)
    Trust me...for places like MN, this isn't just a corner issue. If I purchase a Prius Prime and I'm expecting the engine to stay off when in 'EV mode', and it doesn't under 14 degrees F...I want to know why.
  12. farmecologist
    1,960
    1,801
    Southern MN
    Yes.,..but "using the engine" means "using the heater" in temp below 14 degrees F. That is the only point I'm trying to make...I swear! (y)
    Tideland Prius likes this.
  13. fuzzy1
    10,691
    No, "we all" don't know that. I saw it as a more broad comment that included pure electrics, which best achieve that particular goal:
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    No joking here.
    Just because you don't understand what I am saying does NOT make it "dumb".
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    You got that answer a long time ago.
    It is because it is designed to do that......to prevent the engine from trying to propel the car when it is STONE COLD.
    Come on......yourself.
  16. Ed Beaty
    Ed Beaty Active Member
    334
    311
    Salt Lake City
    "Just because you don't understand what I am saying does NOT make it "dumb"."
    Mostly sir, it's the WAY you say it that renders it "dumb".
    farmecologist and Raytheeagle like this.
  17. Tideland Prius
    16,675
    Actually, according to the Toyota engineers we spoke to in New York, they reason that it's more efficient to burn fuel to generate heat below -10°C/14°F than to try and use the battery to generate heat.
    I mean with a small battery, that makes sense - the range is going to be "unacceptable" to the general consumer if it was used to generate heat at those temps (and we're assuming the general consumer isn't making efforts to be efficient and just heating up as if they were in their previous car)
    fuzzy1 and Raytheeagle like this.
  18. ASRDogman
    8,055
    4,083
    Remember what I told Walt, "If you can't say nothin nice, don't say nothin at all!"
    burebista likes this.
  19. Mendel Leisk
    42,310
    I've read, and it seems likely from what I've observed, when you start a regular 3rd gen, cold, the engine starts and fast idles, but is typically NOT propelling the car for those first few minutes; it's just the hybrid battery providing the energy. You can see evidence that bears that out: as you accelerate the sound of the engine doesn't change. I'd suspect if the hybrid battery was low state of charge, then the engine might get called on for propulsion. Could be the engine is also charging the hybrid battery too, in those first few minutes? I haven't really paid attention.
    fuzzy1 and farmecologist like this.
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    Sure. Come on.
    We need more people to pile on.
    And further waste everybody's time.
