First DIY oil change -- can't undo oil filter housing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Oct 30, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    For the first year that we had our 2015 Prius we had the servicing done under warranty by the (non-Toyota) dealer from whom we bought it. Now it's 5K miles since the last time they serviced it (total coming up to 35K), and I was planning to change my own oil and filter this time (and install an oil drain valve). The oil drain plug was not easy to remove, and the filter housing has so far resisted all attempts to loosen it: I have a solid steel Toyota-style tool, but I cannot move that thing at all. There is no room to use a long breaker bar, and if I lie on my back and use my foot on the shorter wrench handle the whole thing -- tool and wrench twist off the filter housing. BTW, the "lug" I can see on the filter housing seems somewhat beat up; maybe the other one is as well.
    I saw a YouTube video where the guy resorted to a 300 lb.-ft. impact wrench to drive the Toyota-style tool, and even then it took a lot to get that thing moving.
    What if I refill it with oil and just leave the filter on for another 5K?
    Or what if I refill it with oil and then get an impact wrench? How much of that new oil would I lose by removing the old filter? -- or I suppose I could try to save as much as possible of the oil that drains out.
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
    Don't use an impact wrench. Use a cheater pipe on a 1/2 square drive ratchet. That would allow you to adjust the length of the "lever arm" to the space available.
    SFO and jerrymildred like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I did oil changes at 10 k miles, so you’ll be fine if you wait;).
    You’ll need to deal with the oil filter though :cool:.
    Some have converted to the spin in style, like @Rebound and @RightOnTime :).
    So there are options if it is too stubborn to move(y).
    SFO and Montgomery like this.
  4. Georgina Rudkus
    3,576
    2,604
    Taylors, SC
    Montgomery likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Have a hammer? Give the bar a good few whacks...
    moto g(7) power ?
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Check if there’s a metal clip pin that you can pull out from the housing. The pin prevents the filter from unscrewing while driving. The pin may not be in your line of sight depending on your viewing angle, once removed you should be able to turn it.
  7. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    The clip does not inhibit rotating the cap. I leave it on and instructions (Toyota) say not to remove it. I believe it is there if the threads fail and the cap pushes straight outwards, to prevent catastrophic loss...
    moto g(7) power ?
  8. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Toyota also said they don't know about clogged EGRs leading to blown headgaskets, no need to change lifetime ATF & etc.
    iskoos, Tim Jones and dig4dirt like this.
  9. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    278
    Redwood City, California
    It sounds like your tool is not very good, or not good enough.
    Skipping on the filter at this point may be your best option, and should be fine until the next change interval.
    I'd definitely not use an impact.
    Whether you have time to do it now or some time before the next change, the best thing is to get the filter wrench fitting well on the filter housing. Lots of bad examples out there on this. I bought a $7 cast aluminum wrench on eBay and it fit horribly badly. So I spent almost half an hour sanding it so now it fits perfectly. I expect the $30 version would have saved me that 1/2 hour of my life, but maybe not such an ideal fit.
    Then with the filter wrench on there, fitting in all the notches properly, etc. a breaker bar should get it. If no, you can try using a floor jack to push up on the breaker bar. That is pretty much guaranteed to do something.
  10. ChapmanF
    19,038
    Ok, but in this case we're talking about something lots of us have been doing multiple times a year and noticing that the filter cap spins off just fine without any need to molest the clip, just like Toyota says.
    When it's hard to spin off, in my experience it typically seems that the big O ring has just become really stubborn.
    I can lube up the new O ring real nice, spin it on to exactly 18 ft lbf, no more, and the next time I go to take it off, it's always hard to get started.
    Never as hard as it was the first time after I bought the car though.
    Mendel Leisk and Montgomery like this.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Going 20,000 miles on a oem filter? :cool:
  12. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Sounds like OP is concerned about going up to 10k miles.
    moto g(7) power ?
    Raytheeagle likes this.
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Raytheeagle and Georgina Rudkus like this.
  14. Montgomery
    2,254
    2,244
    Orange County, CA
    I was doing the same thing. Really oiling up the O ring. But as my changes came on, it got harder and harder to remove the darn thing. Plus, you had to put in in fairly tight or it would leak. After the conversion, its "spin on - spin off". No leaks and no worries.
    Georgina Rudkus likes this.
  15. Georgina Rudkus
    3,576
    2,604
    Taylors, SC
    Toyota, as I did recognized that the Nylon 6-6 35% glass filled plastic housing swelled in several years time. I go tired of hammering on the factory authorized cap wrench and removing it with Vise Grips.
    Accordingly, Toyota eventually went back to the spin on filter on later Prius models.
  16. NewHybridOwner
    607
    283
    W. Michigan
    The tool does seem to fit OK, but the wrench obviously applies a twisting force as well as a rotating force. An impact wrench's force would be entirely a rotating force.
    My 3/8-in handle is short, and I don't at present have a pipe that will fit over it to give me more leverage. My 1/2-in handle is too long: the end is touching the floor so I can't move it.
  17. NewHybridOwner
    607
    283
    W. Michigan
    No: assuming that the folks at the place I bought the car did change the filter (as they claimed) when they serviced it 6 months and a little less than 5K miles ago, the filter should have done less than 5K miles, so to run it for another 5K miles should be fine.
  18. NewHybridOwner
    607
    283
    W. Michigan
    The guy on YouTube who used the impact wrench said there's a metal one that was used on Lexuses: 15620-31040. That shouldn't swell.
    One of the comments on that video reported a case where it took two guys with a 5-ft. breaker bar to loosen one of those filter housings!!!
  19. Siward
    Siward Active Member
    314
    128
    Toronto
    On my very first newbie oil change, I turned the oil filter the wrong way to tighten it. I hope you are turning it the right direction.
    1) I normally use a small socket extension (3 inch) with 3/8" drive on my oil filter wrench
    2) As for a breaker bar, my filter wrench has large hex outside which allows you put a 1/2" drive deep socket. You can also use a short socket extension for the extra clearance.
  20. NewHybridOwner
    607
    283
    W. Michigan
    Looks exactly like mine. I don't have a socket the right size, so I've used a 3/8" drive ratchet, but it's rather short.
