First DIY oil change -- can't undo oil filter housing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Oct 30, 2019.
  1. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I see that the original oil filter housing (15620-37010) has been superseded by156200T010. Does anyone know what the difference is?
  2. Mendel Leisk
    41,397
    Georgina Rudkus likes this.
  3. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    This is a very safe way of getting under a car using jack stands and rear wheel stoppers! Love the tree stump for added security. All it takes is one time and injuries can be very serious.
  4. Montgomery
    2,254
    2,241
    Orange County, CA
    Next time, invest in changing to the spin type. It is so worth it. This is where I got the info:
    The 2016+ Toyota 2zr Engine oil filter conversion - Armstrong Family Blog
    Here are the parts- Part numbers: Bracket- 15609-0T060 O-rings- 96723-24020 Union- 90904-04006 Filter- 90915-YZZF2
    Keep this for future reference.
    Sincerely,
    Lamarr
    Georgina Rudkus, Mendel Leisk and RMB like this.
  5. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    Nice job!
    OTOH, I just bought some hockey pucks from the sporting goods store to put on top of the jack and jack stands. No muss, no fuss.
  6. ASRDogman
    ASRDogman Senior Member
    7,569
    3,903
    That would be very nice, and a LOT easier. But at over $100, not worth it, at least not for me.
    That's a LOT of oil filters, and drain plug seals. :)
    Maybe someday I'll check a junk yard for a blown Corolla engine and take it off one of those??? :)
    Ed Beaty likes this.
  7. ChapmanF
    18,138
    ... but compared to the spin type, I still do enjoy just producing a little pleated paper and an O ring as waste with every oil change ....
    jerrymildred likes this.
  8. NewHybridOwner
    607
    283
    W. Michigan
    So you don't think that the spin-on one has a very similar pleated paper element inside? -- and there's a rubber ring (although not an o-ring) on the bottom of the spin-on one. And I don't think the metal part of that spin-on is going to get recycled.
  9. ChapmanF
    18,138
    I do think the spin-on has a pleated element inside, and a rubber ring. But I think I'll stick with the original cartridge design, thank you, so the waste I produce with every oil change doesn't also include that metal can.
  10. NewHybridOwner
    607
    283
    W. Michigan
    I was thinking of that too -- or from a later Prius. But did they change on the later Prius? I had had the impression that people were saying that they changed to the spin-on kind on later Priuses, but I see that the later part number filter housing (15620-0T010) fits Priuses at least through 2017 (and Corolla through 2015, and Matrix from 2009 on).
  11. NewHybridOwner
    607
    283
    W. Michigan
    That's what I meant.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Once you move up to the 4th generation Prius, you'll be right back to the metal cans taking up landfill space again.
  13. ASRDogman
    7,569
    3,903
    I "think" the 4th generation Prius' have the spin on, at least it started in a certain year. But I am not
    certain. I believe I read it in one of the post about the kit a year back or so.
    I'm sure someone here remembers, or knows.
    When I first saw the kit, I was ready to get it. I figured it would be $50 or so. Which was a bit much,
    but still half from what it is now.... so I lost interest.
    After the first time I changed the oil, the housing comes off easy for me. Because I don't tighten it to
    6 million yard pounds!!! I only snug it, and the clip helps to keep it in place.
    I think I will soak it in oil for a bit so the filter an absorb the oil so maybe the light goes out quicker.
    It's worth trying once anyways.
  14. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I got poo pooed on the other thread, they said the clip does nothing, not even restrict the filter from
    Unscrewing.
    Even though I plan to drive my prius to the ground, I still won’t put in the spin on adapter. Not that I worry about putting metal cans of filter into landfills, the filters are actually keeping oil clean so it’s doing the same job as spin ons. Also it will be an additional cost to buy the adapter kit and then the spin ons will do the same filtering job just like the insert filters.
    #74 Grit, Nov 2, 2019
  15. ASRDogman
    7,569
    3,903
    I have better things to do with $100 than that filter thingy. :)
    The "clip" have a purpose, or it wouldn't be there. WHY would they spend the expense of
    developing it, making it, and making a spot for it????
    With the removal tool I have, it will press the clip out of the way. But laying on my side, it's hard
    for me to keep it on so it keeps that out of the way. It only takes 2-3 seconds for me to remove it,
    and the same to put it back on. With it off, the tool fits easier.
    This is what works for ME. If it doesn't for someone else, then do it the way that works for "them". :)
    Grit likes this.
  16. Mendel Leisk
    41,397
    Last oil change I was hoping to reduce the waste even further, thinking I could snip along the length of a pleat, uncurve the whole thing, put it between the jaws of a vice and squeeze it almost oil-free. Sadly, that's not practical: there's plastic substance at the inside diameter, impedes things.
    Still yeah, for various reasons, I'm in the "if it's not broke" camp. For one thing, I'm reluctant to start doing serious mods to a car that'll be traded or sold in a few years. An Oil Catch Can I've done, but that is relatively easy to remove.
    I've got some ideas about that. Mostly, I think it's similar to the reserve beep: the engineers came up with something innovative, a bit quirky, then shortcomings were noted (real or imagined...), and to appease the notees, patches were applied. I've done somewhere around 18 oil changes, and I've completely forgotten about that clip, lol. It does nothing.
    #76 Mendel Leisk, Nov 2, 2019
    Grit likes this.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    THIS!!!
  18. ASRDogman
    7,569
    3,903
    Just because you "think" something does nothing, doesn't mean it doesn't.
    Maybe it just means that it's doing it's job so well, you don't notice it! :p
    mjoo likes this.
  19. Mendel Leisk
    41,397
    It's a butterfly in a tornado... :rolleyes:
    For breaking loose the filter housing I use an 18", 1/2" drive ratchet wrench and heavy stamped steel socket: that little doodah of stamped steel beside the housing is brushed aside, boohahah... :coffee:
  20. ChapmanF
    18,138
    This. It may indeed have a job. It might even be doing its job perfectly. It's just a job that has nothing to do with me changing the oil filter.
    If its job had anything to do with being in the way when I change the filter, then the repair manual would probably say "notice: remove the oil filter bracket clip when removing the oil filter cap assembly." ... instead of saying what it does say, which is:
