First DIY oil change -- can't undo oil filter housing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Oct 30, 2019.
  1. Mendel Leisk
    41,515
    The clip has a wee tang that I believe rides up-and-over a protrusion on the oil filter cap, very gentle and easy.
    But yeah: I use the ratchet wrench to unscrew that thing, all the way till the O-ring exits the cylinder it's in, and it puts up moderate resistance all the way.
  2. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    Replacing my butchered original filter housing by the updated one (unknown difference from the original -- maybe, just maybe easier to remove) would be about $40 with shipping.
  3. Mendel Leisk
    41,515
    Torqued to 18 foot pound you'll be ok. (y)
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,435
    Taylors, SC
    If you are so worried about the metal "cans" of oil filters going to landfills, you can still get a tool that cuts them open to recycle the metal can.
  5. ChapmanF
    18,249
    So ...
    I can go pay money to buy a cartridge-to-spin-on retrofit kit ...
    ... and take my car apart, and change the filter housing to the retrofit kit ...
    ... and buy filters with cans ...
    ... and buy a special can opener ...
    ... and cut up my old filters ...
    ... and recycle the cans.
    Or I can leave my car the way they built it, and not have cans. (y)
  6. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    There is a reason why Toyota quietly switched back to the spin on cartridge oil filter.
    There are many horror stories all over Priuschat and elsewhere on "stuck on" plastic cartridges and some that leak out all the oil out of the sump.
    A $10k -30k plus car is worth the cheap $100 or so investment to avoid all of those issues.
    scona likes this.
  7. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    Could be that it was revised to avoid the "swelling" of the housing with age. A redesign of either the material compound or physical design would do that. But only time and history of installed units will tell if it was a good redesign.
    On that account, I'd spend a little extra and get the "spin on" filter conversion.
  8. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    It's been more than a year since I did it. It was absolutely easy to do. I bought the o rings but didn't use them. The original ones were fine. The last oil change I did in August told me the conversion was definitely worth it.
    scona and Montgomery like this.
  9. ChapmanF
    18,249
    Maybe it's that I do my own changes ... I think I would notice if I busted the cap. or if it were leaking oil when I was done.
    Tande and Grit like this.
  10. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    I still prefer the spin on oil filter system that has been used since the early 1960's. My old retired friend tell me of remembers the old cartridge types with the perforated cans that preceded the spin ons. He thought that Toyota and others went backwards with the cartridges.
    He, too, converted his 2015 Prius to the spin on.
  11. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    After reading most of the threads here, it just boils down to a personal preference. If one wants to invest in the spin type, so be it. If one doesn't so be it. For me, it was getting harder and harder with each change to get the original filter out and I chose to invest in the switch.
    scona, ASRDogman and Georgina Rudkus like this.
  12. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    The conversion is so easy that all you need is a 3/8 drive ratchet with a 12mm socket to remove and install the 12mm hex head M8x1.25x35mm long J.I.S. bolts.. If you don't have a 12mm Allen wrench for the socket, you can easily use a bolt with a 12mm hex head as I did held b clamping the threads in a Vise-Grip locking plier. It added no more than 15 minutes to the oil change.
    Montgomery likes this.
  13. ASRDogman
    ASRDogman Senior Member
    7,607
    3,915
    Yes, it seems very easy and simple. Please feel free to purchase the kit and send it to me. :)
    But it's NOT worth over $100, TO ME. For some, yes.
    But as Montgomery wrote..."...it just boils down to a personal preference. If one wants to invest in the spin type, so be it. If one doesn't so be it. "
    jerrymildred likes this.
  14. ChapmanF
    18,249
    Black Friday's right around the corner....
  15. NewHybridOwner
    607
    283
    W. Michigan
    Still the same basic kind of filter through the 2018 models of Prius.
  16. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    As I recall, Toyota switched to the spin-on filter sometime in the 2018 model.
    Mendel Leisk and Montgomery like this.
  17. Georgina Rudkus
    3,468
    2,435
    Taylors, SC
    I like your dog. Maybe, we can work something out.
  18. RRxing
    RRxing Senior Member
    2,546
    1,822
    NEPA
    I believe the switch came in the late 2017 models. Mine still has the cartridge.
  19. Mendel Leisk
    41,515
  20. NewHybridOwner
    607
    283
    W. Michigan
    BUT
    (a) The list of parts and prices on the right has no entry for item 19 that looks like the filter housing used on the Gen3 vehicles.
    (b) When you click on item 20, which looks like our "naked" paper (or whatever) filter element and o-ring, you get a picture of a spin-on cartridge filter.
    I have a theory: Toyota used the "naked" filter elements because they generated less waste (no steel can), but they had not reckoned with impact-wrench-happy Western mechanics and had to revert to the more-polluting kind.
