First DIY Prius oil change this weekend
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GreenGene, Jul 13, 2006.
  1. maestro8
    maestro8 Nouveau Member
    471
    108
    nor cal
    In the time you spend looking for your fancy oil filter wrenches, I'll have two oil changes done.
    The filter should come off by hand, otherwise you put it on too tight before!
    If it's too tight, just hammer a screwdriver through the filter and use that to turn it. Job's done in about a minute, no fancy tools required.
Loading...
