First dump from OIL CATCH CAN - how's this look? :(
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Atari, Jan 31, 2019.
  1. Atari
    Atari Member
    84
    47
    Sacramento
    I'm think going to get one of those HD inspection cameras that connect to your phone/tablet and see if I can have a peak inside the head from the oil cap - with engine off of course :)
  2. Atari
    Atari Member
    84
    47
    Sacramento
    • Seems to drop pretty quickly.
    • YES.... the oil smells.... like a solvent almost. Faintly like gasoline, but in a "burnt" non-flammable sense. If that makes sense.
    • Temp icon was on different vehicle ... the 2006. The 2006 most likely needs heater core or head gasket. Drives fine w/o heater though. Turn on heater and it'll probably overheat.
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    Has it run without coolant ever?
    If so and you missed the level being low, it may have gotten your mag drive engine water pump.
    Are there any codes on the 06? I’d suspect either the 3 way valve is bad or a bad thermostat.
  4. Atari
    Atari Member
    84
    47
    Sacramento
    - The 2010 G3 has not run without coolant that I'm aware of, but then again as mentioned - the reservoir may have been empty/very low. (no overheating though)
    - [re: the 06 Gen2 - tstat replaced. Yes! 3 way valve up next. Long story short the kid dumped Bars stop leak in there when it was having problems. Ignition coils resolved most of the problem on that one too oddly enough] - No codes now.
