First EU navigation update available
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by KMO, Jul 15, 2024.
  1. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Seems like the first update for the European on-board navigation is available.
    You might be able to find it via the "e-store" in your country's Toyota site, but you can also get it from the Toyota-Tech site at https://www.toyota-tech.eu/Navigation/base if you make a free login there.
    My July production car came with "2023-2024 Ver. 1" - the one currently on the site is 6 months newer (Ver. 2). And I think the next one should be due quite soon.
    You install via USB - need a 32GB FAT32 memory stick, as it's over 20GB of data.
    Updates are free for 7 years, as required by the EU speed limit regulations. To get the free update you need to enter some numbers from your navigation unit, the site generates a license code, and you type that into the car as you start the update.
    I haven't tried it yet - will be having a go tomorrow. Got my USB stick ready.
    #1 KMO, Jul 15, 2024
  2. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    And the update process worked. Not driven anywhere with it yet, but it's reporting the new version at least.
    Took maybe 40 minutes.
    Only troublesome part contrary to the documentation is that the update didn't actually start immediately - instead it said it was ready for update and going to start the update on the next power on. A few attempts to turn the car off and back on that looked like they were shutting down the multimedia system didn't make it proceed, but after a long press of the volume/power knob to reset the head unit, it started.
  3. Hammersmith
    Hammersmith Senior Member
    2,363
    2,417
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I think your problem was that the head unit goes into standby mode after shutdown and stays that way for some number of minutes before shutting down completely. So what you were doing was switching the head unit in and out of standby, not actually restarting it.
    I suspect the reason for the standby period is to prevent errors from occurring if the car is restarted while the head unit is shutting down at the same time. It's basically a computer, after all. We all know modern computers take a few moments to close out all the software before powering down. And we also know that forcing a computer to restart in the middle of that process would be a bad idea. People don't think that way about cars yet(even though they're really a set of computers), so a car owner has no problem shutting a car off then immediately turning it back on again. By having the head unit go into standby at shutoff, it protects the system from a quick restart. But if the car stays turned off for maybe five minutes, the car knows that it's probably safe to start the full software shutdown without being interrupted during the process.
  4. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    May be partly that - an associated thing is the Safe Exit Assist - I understand that has some verbal indication which is provided with the help of the head unit, and the system is held on for a while to provide that. The timeout is indicated by a dash message about it no longer being active.
    I thought actually getting out of the car and locking it would be sufficient to get it shut down immediately, but apparently not.
    No obvious difference in the start-up time between holding the button for reset and short cycles just to the screen off state, so no obvious "only standby" cues.
    Drove around a bit - confirmed at least one road nearby that was out-of-date in 2023v1 is now correct in 2023v2. So it's not a fake update. :)
    Still waiting for a correction to a nearby motorway junction sign that I think I reported back in September - too late for 2023v2, but could have made it into 2024v1.
    #4 KMO, Jul 17, 2024
  5. AndersOne
    AndersOne Active Member
    344
    199
    Europe
    2023 Prius Prime
    Would it be this one? Seems still very olld. Im not really able to find a proper place to download maps besides the toyota-tech mentioned from you.
    EDIT: Another page
    Toyota Map Updates
    seems to have only outdated navis
  6. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Yes, that's the one. A huge lag from map data to actually being available is normal.
    Although at this point we really should be due for the next 2024 Ver.1 update with 2023Q2 data very soon, as the 2023 Ver.2 (2022Q4 map data) is only 6 months newer than what the car was delivered with, and the car was built 13 months ago.
    I don't know how much lag there is from nav being used in production to being available for download - I don't know when that 2023 Ver.2 went up there.
    #6 KMO, Aug 23, 2024
    AndersOne likes this.
  7. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    It looks like the MM21 system is lagging - all the older systems you can download USB updates for on toyota-tech.eu seem to have 2023Q2 data already.
  8. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    Not that I've ever done an update or inserted a different / newer microSD , but I'd think there should be some doc for the official way to run the procedure, somewhere.
    What's actually wrong with the the nav that came with , from factory? It's old? Not up to date? New construction not included? Get the Update now?
  9. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    I might wait for that to make it worth it- if it ever comes. Of course my dealership did not update anything when they prepared the car so I still have the old version you had as well.
  10. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Update is now online:
    "Spring 2024 update for Map database of TOYOTA SMART CONNECT Plus"
    "12-24-06[2023-11-6] (V24.00.06 data)"
    Maxwell61 and AndersOne like this.
  11. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Nothing to report yet - extracted it to a USB stick today, taking about 10 hours, then I realised I needed a USB-A to USB-C adapter and don't have one with me. Sigh.
    Maxwell61 likes this.
  12. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    I realized my 64 GB USB Stick is old and not properly performing so I had to order a new one for now. Toyota gave me actually one as gift with the car but of course it has only 16 GB - they gave me a universal USB-A charging cable too btw :/
  13. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Okay, updated smoothly. Took 35 minutes. Now announces itself as "2024-2025 Ver. 1" as expected.
  14. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    I finally did it as well. I didnt dare to touch the car while updating but it seems you could just drive around while doing it.
    #14 AndersOne, Sep 13, 2024
  15. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Yeah, I imagine you could. You'd get lost though.
  16. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Interestingly since I last looked, there's a new update for "Toyota SMART CONNECT" (not "Plus", not "(EU)").
    That's only 6GB rather than 21GB. I'm a bit puzzled by that, as I thought the non-Plus version was the version without the built-in navigation.
    But then it does say "Spring 2024 Speed Limit Database update" while the Plus says "Spring 2024 Map Database update".
    So maybe that version just has a reduced built-in map that can manage the speed limits, but not the full navigation UI.
    I had assumed that we got the "Plus" in the Prius with the built-in navigation because that was their way of complying with the speed limit rules, but looks like they've got a cheaper option.
  17. AndersOne
    344
    199
    Europe
    2023 Prius Prime
    What would be the target group? At least in the german e-store (which works now) they only offer the bigger plus/eu version.
  18. KMO
    KMO Senior Member
    2,015
    742
    Finland
    2023 Prius Prime
    Browsing through some brochures I found that the Aygo X can come with basic Smart Connect. Looks like below that is now Toyota Touch 3 in various lower model trims, which also has a speed database update available.
  19. poleup
    poleup Junior Member
    US
    2013 Prius Alpha
    If the version without Plus does have limited navigation features, it may not be a bad option for those who just want the basic features without the extra cost.
  20. Maxwell61
    Maxwell61 Active Member
    393
    242
    Italy
    2024 Prius Prime
    XSE Premium
    I've tried a USB memory type C 128 Gb brand new, just to find that the car (User manual) doesn't read more than 32 GB sticks..
