First few minutes mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by gazz, Mar 4, 2010.
  1. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    OK, I see.
    So, you were driving in "D" at 20 mph vs in "N" at 30 mph.
    That's why you saw 20 mpg vs 40 mpg.
    We know the warming up fuel becomes very thin in "N", then it causes to delay finishing (postponement) the warming up process.
    It is not important to see better instantaneous mpg at a moment, but it is important to see better average mpg at a goal point.
    Do you see any difference on the average mpg when you finish driving?
    Ken@Japan
  2. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Ken you seemed to have studied this as much or more than anyone else. I have a number of short trips that bring my milage down. They are 1-3 miles with cold engine, and I'm wondering if you have speed/wait suggestions. The trips have numerous steep hills, often with stop signs or lights at the bottom of hills. Speed limit is 35mph, but I can go slow. I noticed my bad milage when I fill up on the weekend and do these trips (and linking trips doesn't really work). I tried slowly accelerating to 25mph and get about 30mpg, I think i was getting slightly better milage accellerating fast to the speed limit and braking. Given all the down hills and braking if I have a warm engine, I go to ev mode and it definitely helps. So is it go slow for s1a till the first stop sign, then accelerate briskly?
    I'm happy with my milage on the highway and longer trips.
    Thanks.
  3. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    1-3 miles short trips, that's a worst scenario. :eek:
    I think there will be not so much difference by changing your driving style.
    The special magic to improve your short trip mpg will be...
    A ) use an engine block heater
    B ) use a thermistor hack
    Or, ride a bike, an electric bike or a NEV (Neighborhood Electric Vehicle) :)
    Ken@Japan
  4. austingreen
    13,714
    4,232
    Austin, TX, USA
    That's what I thought. There are 8, two mile trips a week (4 round trips) to go on runs, now that its warming up I can ride a bike to those, the others will just keep pulling down my average. One reason for the prius is that I was getting about 16mpg in the city in the previous vehicle (much worse than epa). So this is much improved. It gets very hot here in the summer, so I expect that even these bad trips will improve soon.
    The thermistor hack looks promising, but maybe I'll try it next winter after we get some feedback on whether it causes any problems. I have a neighbor that rides a motorcycle in nice weather to save fuel, but he gets worse fuel economy than I do. We may try building a hybrid motorcycle as a experimental project.
    Thanks for all the technical information on the stages.
  5. gazz
    gazz Member
    216
    Coventry, UK
    I will do a bit more testing, although I put it into "N" I still believe that during the "D" part when I run at about 1700rpm I still seem to get a better mpg that thee 1280rpm and I don't run the battery down so much.
    When at 1280rpm the ignition is about -6 but if run at 1700rpm the ignition stays at +10 approx. suppose was wondering if a negative ignition is very inefficient.
    I am probable just putting of stage 1.
    Thanks
  6. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    Thx. Ok, I see that the ignition timing is normal after S1a. But is S2 better to start driving? What is the approximate time between S1a and S2 (where the 'Prius acts normal")?
    Even if fuel efficiency improves when driving after S1a, what about the conventional wisdom to warm-up cars in extremely cold temps just so the parts/components are lubed up decently before one starts driving? I am sure this is still valid?
  7. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    conventional wisdom == military intelligence (no offense soldiers, it is just a cliche).
    0W-20 and S1a warmup is the most you need to get modern cars lubed, unless you are in a racing or other high-performance situation.
    With thinner oil, absent the anomaly of S1a retarded timing, modern cars just need a second to develop oil pressure and off you go. I love watching the 0W20 going in my filler hole, because it is the slickest looking substance I think I ever saw.
    In extreme cold, you need to avoid hard driving because even if you warm up for an hour, only the ICE is warmed, not the steering linkages, etc.
  8. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    cool. thx.
  9. nyty-nyt
    nyty-nyt Member
    139
    Ontario
    I had a block heater on my G II and it allowed me to go to stage 3 only 400 meters sooner on my commute, (6.4 km versus 7.0 km without plugging it in), all conditions equal.
    They cost a lot to have installed, and I didn't take the option on my new Gen III Prius, because I thought it was a waste of time, money and electricity.
  10. gazz
    gazz Member
    216
    Coventry, UK
    Re: First few minutes mpg with picture now.
    I have finally gone and took some pictures of what I see. To recap what I find is that if driving slowly at 1280 rpm I get lower mpg than if I force the engine to run faster at about 1600rpm for the first few minutes (the warm up stage with neg ign)
    1280rpm(2).jpg 1280 rpm first 2 mins under 25 mpg
    1280rpm(1).jpg 1280 rpm
    1600rpm(1).jpg 1600 rpm first 2 mins over 25 mpg
    1600rmp(2).jpg 1600rpm
    My theroy is that the engine is very inefficient at the 1280 rpm and is only there to make sure you warm the cat, run faster at a more efficient speed and the engine does not need to enter this inefficient phase as the cat is warmed by the faster engine.
    Any thoughts
  11. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    I wrote as follows;
    Your data is...
    (1) 1280 rpm first 2 mins under 25 mpg -> 4.5 miles 52.1 mpg
    (2) 1280 rpm -> 4.5 miles 41.0 mpg
    (3) 1600 rpm first 2 mins over 25 mpg -> 4.5 miles 50.5 mpg
    (4) 1600rpm -> 26.3 miles 54.5 mpg (can't count this because different goal point)
    I think it is hard to judge which method is more efficient from your data now.
    We need more data to judge them.
    Ken@Japan
  12. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    Of course, a thermistor hack user has to be very careful in mind to know what's going on the ICE.
    My recommendation is...
    • let the ICE run during the first 1 minutes (S1a) warming up
    • after the 1 minutes, use the hack as needed
    • when you pulse, the hack is not needed
    • when you glide or engage the EV switch, the hack helps a lot
    I introduced it since 2007 for the Gen2, and no one found any problems since then.
    I installed the hack for following person's Gen2 on January 21st, 2007.
    Since then (95,000 km odometer), his mpg number is increasing and the Prius odometer is now over 185,000 km (115k miles).
    CNN Video - hybrid hackers
    Ken@Japan
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    with trips that short, its tough to get any real conclusion unless you measure data over several trips. for short ones like that, i would have to take at least 10 measurements. i tracked my commute to work, going and coming (7 miles) which is also relatively short trip. i had variances of 10 mpg on some trips with no real explanation. temps, weather, etc about the same until i started tracking my SOC with it. then i noticed that just starting with a few less bars than the normal 6 would cost me 3-4 mpg.
    if i were you, track 10 trips on each, toss out the high and low and average the remaining 8 and see what happens
  14. gazz
    gazz Member
    216
    Coventry, UK
    Thanks for looking at my data.
    I will continue to experiment, its just seeing higher mpg for the first 2 mins makes me think. Also the SOC is higher for the rest of the trip. With the warmer weather coming I suppose it will all change. Looking forward to my first 80mpg(UK) trip to work, best was 79mpg in my PriusII.
    Thanks ken.
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Your 4th min MPG suffers if you go up to 1600 RPM. First 2 mins looks better but you pay it back on the 4th min.
  16. gazz
    gazz Member
    216
    Coventry, UK
    Yes I see what you mean, problem is because you are driving at different speeds the mpg profile is not like for like (you are at different points on the road), but I see you point.
    Need to do lots more testing.
    Thanks
