First fill-up, 47.33MPG
Discussion in 'Gen 2 Prius Main Forum' started by tundrwd, Oct 26, 2008.
  1. tundrwd
    tundrwd Member
    111
    "South Central" KS
    Just filled up my '09 last Fri nite. Got 47.33 on the first tank. "GeeWhiz" display showed 49.1MPG, so it's a tad optimistic. Anyway, filled up about the same time (332 miles) as I would have in my previous car ('05 Hyundai Tucson), and used less than half of what it would have.
    I don't think it's too bad for a 60 mile, 2-way commute, most of it highway at 60 or 65MPH.
  2. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    That's very good for a brand new Prius. Usually new owners take a few months to get to EPA values. Hope it keeps getting better for you.
    BTW, that's only one fillup, so you can't really be sure of the mileage calculated, mainly because you don't know how full the car was when you started, and you can't be sure how full you got it (all due to the bladder and the stealer, er dealer).
    Wait until you get 3-5 fillups and average out over that to get a more accurate idea.
  3. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Just curious what tire pressures you are running. Increased pressure will make an instant boost to fuel economy. I don't run 42/40 now. I might try it someday, although 38/36 lets me feel the bumps more than the stock 35/33 setting.
  4. sorka
    sorka Active Member
    1,004
    196
    Merced, CA
    2019 Prius
    I got 54 MPG on my first tank a few weeks ago in my new touring but I was running 41/39 tire pressures from day one.
  5. tundrwd
    tundrwd Member
    111
    "South Central" KS
    I'm running the stock 35/33 right now. I've got some gravel roads to contend with, and wanted to make sure I got a "feel" for what it's "supposed" to be like before messing around with various settings.
    I want to establish a good baseline before doing anything, so I can see what does what for my driving style and route, etc.
    Probably 2-3 more tanks before messing around with tire pressure, etc. And I probably won't increase it that much, since I have a bit of gravel to deal with.
  6. lovemygreys
    lovemygreys New Member
    57
    Piedmont, SC
    We picked up our Prius last Friday and drove it quite a bit this weekend...had 47.2 at our first fill up - A lot of highway driving at 65.
