First Gen 1 Prius Plug-In w/ Blown Head Gasket?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Tracksyde, Mar 23, 2017.
  1. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Just an update.. I picked up the car Saturday morning (they called around 6pm Friday saying it was ready). Anyhow, aside from missing a few bars from my gas gauge, things seem to be fine. The engine is super clean now (mechanic took a power washer to it while the car was on, by the way). I'll drive to work tomorrow on gas to see how it does.
    I pulled about 2 hours of footage from my dashcam. I'll update tomorrow with the time line of events while my car was at the dealer. :D
  2. Mendel Leisk
    41,486
    That sounds good. So no engine swap involved, they removed cylinder head and replaced head gasket? Did they by any chance tell you what this would have cost, going this route without help from Toyota?
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    On the invoice there are charges for a head gasket kit ($288.39 / $1685.10), coolant ($127.19 / $211.56), 5 qts synthetic oil ($10.70 / $32.55), filter ($3.24 / $5.41)
    The two $ values fall under the columns "cost" and "sale". Cost looks like cost of parts only and Sale looks like cost of parts + labor.
    Total for parts $442.48, Grand total $1956.18
    But judging by the cost of 5 quarts of Toyota synthetic at $10.70, this all seems like dealer cost and "warranty book hours". I never talked $ figures with the dealer. I was scared to, hahah. But someone in another head gasket threaded mentioned $4500?
    Edit: uploaded a copy of the invoice
    #43 Tracksyde, Apr 2, 2017
    QuantumFireball likes this.
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Ok, skimmed all the video and here's how everything went down as told by the dashcam:
    3/22 751AM - Car moved to the back, in line waiting for service bay
    3/22 849AM - Car moved into service bay
    3/22 855-908AM - Car turned on/started 3 times
    3/22 148PM - Car pushed out of service bay and parked
    3/30 1110AM - Car started and moved to service bay
    3/31 251PM - Car started in service bay, still engine still vibrating/shaking
    3/31 252-226PM - Car started 7 times, engine shakes only at idle, smooth under throttle - 3 techs discussing
    3/31 328PM - Tech diagnosed bad spark plug. There is celebration/cheering.
    3/31 337PM - Car idling smoothly now, I hear the tech say he checked coil, used camera (to check for coolant in cylinder again?), and spark plug
    3/31 342PM - Checking for leaks, car up in the air/lifted
    3/31 357PM - Car lowered back down to ground, car has been on/running since 337PM
    3/31 417PM - Tech pressure washed engine bay while car was running
    3/31 419-441PM - Test drive, about 9 miles.
    3/31 545PM - Quick test drive, car parked in service parking area
    3/31 604PM - Valet moves car to car wash area queue
    3/31 622PM - Car exits car wash and is parked in service parking lot
    3/31 946PM - Car re-parked in service parking lot
    4/1 825AM - Tech moved car from parking area to service bay
    4/1 830AM - Car moved from service bay and re-parked in service parking lot
    4/1 948AM - Valet moves car to customer pick up area
    4/1 953AM - Car goes home
    When I first watched the videos, I was thinking maybe it was a spark plug all along. But (1) I can hear the techs discussing that after replacing the head gasket, the engine vibration/roughness was only at idle, which is different than before and (2) that they did try using the camera (I assume borescope) before diagnosing the bad spark plug.. so they must have used a borescope when they found the coolant in cylinder 4. I also heard one of them say they thought the spark plug went bad from coolant fouling.
    Anyway, I had a chance to drive it last night, about 25 miles worth, and I drove it to work this morning without a charge. I'm positive the car runs smoother than before. The engine start up when cold is definitely much smoother. I'm not saying the car is running any better than it should.. rather that maybe I'm just experiencing the smooth ICE and EV/HV transition in a way I've never experienced? Or it could just all be in my head. :D
    It kind of had me wondering that this problem may have been around for a while and its possible that it didnt really show its more major symptoms until the spark plug eventually fouled up. I have no idea how much coolant I lost over 5 years since I never checked it, never thought I needed to.
    Anyway, things seem to be OK. I'll start monitoring the coolant level and checking the oil for excessive consumption. But hopefully, the car is better than new and it stays that way for a long time.
  5. Mendel Leisk
    41,486
    Wow, another reason for dash cams. I especially liked this bit:
  6. Imaginex20
    Imaginex20 Active Member
    140
    243
    Bay Area, CA
    2014 Prius Plug-in
    Makes sense now, I wouldn't have thought the head gasket would have gone bad so early on
  7. bisco
    51,969
    i guess there wouldn't have been coolant in cylinder 4 if it was just a bad plug.
  8. Mendel Leisk
    41,486
    Which cylinder is #4? Is it on the right side or left side, as you stand at the front of engine facing engine bay? Anyone know definitely?
    A cursory look through Repair Manual didn't reveal anything. Reading online, I think it goes left to right, 1 through 4.
    So cylinder #4 is at the right end, nearest the EGR intake, fwiw. Maybe no connection. Did anyone see any obvious damage on the head gasket, photograph it?
    Probably nothing, especially if they've replace head gasket (a monumental undertaking), and problem has gone away.
  9. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Yeah, its the cylinder on the driver's side, next to the EGR. They did replace the EGR and the pipe. There was a TSB for it. So when they said they couldnt reproduce the problem (in late Feb when I took it in the first time), they just did the EGR and thought the problem would go away (which it kind of did, for about 3-4 weeks).
    Something else which I couldnt find any info on was that when they replaced the EGR valve and pipe, another line item on the invoice was a "software update". I havent been able to find much info about it. But I wonder if it was a software update related to the EGR? or was it a software update related to my early PiP?
    I didnt ask for pictures and I didnt see anyone take pictures (on the dashcam), but I imagine they wouldnt share them anyway? I did ask if they knew why the HG failed and the service rep just said "no reason, it just failed".
  10. bisco
    51,969
    the tab is interesting. i wonder if i should mention it when i go for the airbag recall. haven't heard about a software update either.
  11. Mendel Leisk
    41,486
    I'm guessing they replaced just the EGR valve. It's pointless to replace the "pipe", it is literally just a short pipe, easy to clean. And I'd suspect they didn't replace the "cooler". The latter is at the beginning of the EGR circuit, and is the most clog-prone I think. It's difficult to access and has four coolant lines attached.
    EGR valve highlighted in yellow:
  12. bisco
    51,969
    i wonder if low use could cause clogging?
    Raytheeagle likes this.
  13. Mendel Leisk
    41,486
    Someone was theorizing that a lot of short trips could promote clogging, not sure. Seem to happen a lot somewhere around 150K miles.
    Raytheeagle and bisco like this.
  14. bisco
    51,969
    i don't do many short trips with the engine. usually only need it for longer trips. i just wondered if only 18,000 miles in hv over 5 years might not be good. i have had the idle hiccups every now and again, but sometimes, i think it's just the nature of the beast.
  15. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    That's a little scary. Now that it's gotten hot here in North America's armpit and I have to run the A/C on the way home from work, I come up about a mile short of having enough EV range. Guess I'd better find a longer route home. LOL!
  16. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I feel Anytime the engine is not run for a good period and is not up to operating conditions could cause fouling. But other factors such as gas quality play into the fray.
    Since the recycle is taken off before the cat, it opens up the possibilities more. I believe the gen 4 recycle is after the cat. That seems like a better solution.
    m.wynn, bisco and Mendel Leisk like this.
  17. Mendel Leisk
    41,486
    Maybe too if the engine is burning oil, at least with 3rd gen. The product of that combustion getting sucked back into EGR.
    #57 Mendel Leisk, Apr 4, 2017
    m.wynn, bisco and Raytheeagle like this.
  18. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Any hydrocarbons not destroyed in combustion will recirculate back. The problem may get worse if there is an oil burning problem. As the cat clogs due to oil on the surfaces , the exhaust will take path of least resistance, which could be through the egr system. Then the fins on that radiator begin to accumulate deposits .
    A nasty cycle IMO:(.
    m.wynn and Mendel Leisk like this.
  19. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    You know there's one way to find out the status of your egr system:whistle:.
    But that might mean a trip down the street to your trusty mechanic;).
    But it would be a good data point for the forum given your stated conditions (y).
  20. bisco
    51,969
    there's probably no one else out there with my circumstances. i would try it myself if it's easy. i can change the air filter.:cool:
