First Gen 5 2023 Toyota Prius cars show up at the dealers!
Discussion in 'Gen 5 Prius Main Forum' started by Gokhan, Jan 20, 2023.
  1. The Turtle
    The Turtle New Member
    Simi valley
    Thousand Oaks Toyota. Paperwork already signed, no dealer add ons except the Cat shield, which I requested.
    bisco and Gokhan like this.
  2. Gokhan
    Gokhan Senior Member
    6,152
    2,432
    Paramount CA
    By the way, we have never seen any photographs of the LE and SE models yet, except for one Japanese-spec model in a video. I am looking forward to see how the LE and SE models actually look like.
  3. Gokhan
    6,152
    2,432
    Paramount CA
    On the Toyota inventory, it is showing as in the build phase. See my post below.
    #203 Gokhan, Feb 19, 2023
  4. Gokhan
    6,152
    2,432
    Paramount CA
    Toyota Logistics Services at the Port of Long Beach is apparently where the new Toyotas are arriving at and having their accessories installed.
    https://www.lionakis.com/projects/toyota-logistics-services/
    So, then the build phase probably means that the vehicle has arrived at the port and waiting for the OEM accessories to be installed and the window sticker to be attached.
    In transit probably means that the accessories have been installed at the port and the vehicle is in queue for getting on a truck.
    Google Maps
    #204 Gokhan, Feb 19, 2023
    Todd Bonzalez likes this.
  5. bisco
    51,845
    Or probably not
  6. Gokhan
    6,152
    2,432
    Paramount CA
    • Vehicle in build phase: Vehicle arrived at the Toyota Logistics Services at the Port of Long Beach and was logged; now waiting to be processed, for the OEM accessories to be installed, and its window sticker to be attached
      • ETA to the dealer: 1 month
    • Vehicle in transit: Vehicle processed at the Toyota Logistics Services at the Port of Long Beach, its OEM accessories installed and its window sticker attached; now waiting in queue to be loaded on a truck or train or already loaded on a truck or train
      • ETA to the dealer: 2 weeks
  7. bisco
    51,845
    looks good when you type it, but is that from an official source?
  8. dctalk523
    dctalk523 Member
    The OC
  9. bisco
    51,845
    Where is that?
  10. Dester243
    Dester243 New Member
    Kansas city, mo
    2022 Prius
    LE AWD-e
    Dealer in GA got theirs today.
    Gokhan likes this.
  11. Mendel Leisk
    41,334
  12. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    I only got two questions:
    1. Did they actually get rid of the engine cover?
    2. What does the wheel look like under the cover?
  13. someoneinva
    someoneinva New Member
    VA
    2023 Prius
    Same question.. what does the wheel look under the cover?
  14. Mendel Leisk
    41,334
    The wheel cover looks kinda clunky/cheap? And it needs to be pulled off for lug nut (or bolt??) access. Not a big fan of the black plastic trim 'round the wheel well either, the CUV look.
  15. Gokhan
    6,152
    2,432
    Paramount CA
    @bisco et al., it has happened!
    I see that on the LE they use matte external rubber trim on the bumpers and wheel wells as opposed to shiny black trim on higher trims. That is kinda cheapo-looking unfortunately.
    Guardian gray seems to be a bluish medium gray. It is not as bad as some other wet-cement-like colors on the road today.
    As I said, "in build phase" means the vehicle has been logged at Port of Long Beach with an ETA to the dealer of 1 month or less, and "in transit" means the accessories have been installed at the port and the vehicle is in queue to be put on a truck or train, with an ETA to the dealer of 2 weeks or less. This means that by mid-March, the dealers will be packed with 2023 Priuses. 2023 Prius Primes should pack the dealers in mid-June.
  16. hill
    8,794
    once our 2011 Leaf arrived at the stealership - it was another couple weeks until they got around to checking it in and doing what ever inspection they do for new cars. Hopefully others don't do like nissan.
  17. Gokhan
    6,152
    2,432
    Paramount CA
    They need to install the plugs in the transportation holes etc. and go through the whole preparation checklist, but it shouldn't take that long.
  18. uga
    uga Junior Member
    So, does the LE have push button start ?
  19. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    #219 dbstoo, Feb 21, 2023
  20. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Just to clarify Gokhan's point a little. I've had Toyotas since the early 1980s and every one of them has had at least one keyed lock. In recent years the shift has been towards having only one keyed lock, and that's on the driver's door. You should examine your key-fob if If you have a keyless entry system. The fob should have a hidden key that pops up when you press in the right spot. The key is trimmed down to a minimalist design so that the key fob does not clutter your pocket too much.
