First oil change after 1 year
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by krytron, Feb 24, 2012.
  1. krytron
    krytron Junior Member
    Richardson, TX
    Can't believe I've been driving my Prius almost for a year. Since I don't drive too much, my odo is still below 7k miles. I am wondering if I need to change the oil though it hasn't got 10k yet. Any comments?
    Also if I want to change the oil anyway, I assume it won't be covered by Toyota care. Is that right? Has anyone tried to use the 10k free oil change in advance?
    52,854
    i do about the same mileage as you and change my oil every spring. don't know about the free change.
  3. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    I think the rule is 10K OR 1 year ... Toyota should do it for you under Toyota Care.
    REV
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I never make it over 2 months before I change based on mileage, but it really is 10,000 or 1 year for you, so Toyota should agree.
  5. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    ...especially the first refill I like to do early as possible.
    After that I would procrastinate.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes the Toyota Care is 6mon/5K, 1yr/10K, 1.5y/15K and 2yr/20K whatever comes first.
  7. krytron
    Richardson, TX
    Thank you folks. Now I am reading the Toyota care brochure, but there is nothing about 1yr thing. I guess I need to call my dealer. I will post the result soon.
  8. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Read your owners manual instead. ALL service is determine by time or miles whichever occurs first.
  9. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Your maintenance coupons should indeed state 10,000 miles or one year.
  10. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    This may be counter intuitive, but driving fewer than 10,000 miles per year may call for a different set of rules where you change the oil more frequently. Oil change intervals are based upon a combination of viscosity breakdown and contaminant build up. Some contaminants like "dirt" are relatively benign, but others such as acids should not be left there to chew away at you engine. I suggest that you consult your service adviser at Toyota.
    Oil changes are rather inexpensive in the grand scheme of things, and the oil is recycled anyway.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It doesn't... our new Rolla came with Care but it wasn't until we got a mailer telling us we missed our 6 month/5K did it even mention the time interval. Slight over-site on there part.
  12. krytron
    Richardson, TX
    Update: Thank you folks! I got a free oil change (toyotacare) even with <7000 miles. I should have done this for my 5k service too.
