first oil change: report
Discussion in 'Gen 5 Prius Technical Discussion' started by peternumber2, Jan 10, 2025.
  1. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    I just got my prius phev back from the dealer for the first year maintenance, here is what they did:
    1) oil change (0W20):
    2) oil filter
    3) HVAC filter
    4) HVAC disinfection
    5) adding fuel additives foro injectors
    questions:
    1) shouldn't it be 0w15??
    1) level is (1cm) above max in the stick.
    5) why do they do that? Moreover, the tank was almost empty, will i need to fill it before the next ICE start?
    Aren't they supposed to replace the ICE air filter as well?
    thanks
  2. Prodigyplace
    12,720
    11,852
    Central Virginia
    1. The user manual you received with your car would tell you the proper oil viscosity. I know my 2025 Camry HEV says 0W8 but some people use 0W15, claiming prolonged engine life. Other people are changing oil at 5K miles instead of 10K mile intervals.
  3. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Preferred oil is 0W-16. European manual says
    "SAE 0W-16 is filled into your Toyota vehicle at manufacturing, and the best choice for good fuel economy and good starting in cold weather.
    "If SAE 0W-16 oil is not available, SAE 0W-20 oil may be used. However, it should be replaced with SAE 0W-16 at the next oil change."
    Engine air filter is not on the first service.
    Prodigyplace likes this.
  4. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    Should I complain?
    what about the oil level? I heard it can be harmful.
  5. Mendel Leisk
    42,369
    This is was at what 10k miles? Way early for cabin filter. Way early for all that nonsense. OW20 is fine. OW16 is spec'd IIRC, but nothing wrong with 0W20.
    What tank is this, the gas tank, lol?
    No offense, but you seriously need to start doing some reading yourself, starting with the Toyota maintenance schedule, explained in the Warranty and Maintenance Booklet that should be in the glove box.
    #5 Mendel Leisk, Jan 10, 2025
    douglasjre and Prodigyplace like this.
  6. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Cabin filter is scheduled for change every 10,000.
  7. Mendel Leisk
    42,369
    Nortrh American Warranty and Maintenance Booklet shows first cabin filter change at 30k miles.
    Even that, I would say just inspect, replace IF needed. Would never pay a mechanic labour charge to replace that.
    Templeton likes this.
  8. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Show the 10,000 mile page - that's what we're talking about.
  9. Mendel Leisk
    42,369
  10. Mendel Leisk
    42,369
    I've not done a 5th gen conversion to table format, but looks to be very similar to 4th gen:
    purplePriii likes this.
  11. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    I'm almost inclined to think that's an error. I couldn't get the US Prius Toyota book, but other US Toyota models and a third-party Prius 2024 schedule matched the Europe every-10,000 schedule.
    I've long been somewhat of the impression that the minor 10,000 service includes the cabin filter just to give them something to do other than changing the oil - help it justify being called a service.
  12. Prodigyplace
    12,720
    11,852
    Central Virginia
    FYI, the 2025 Camry manual shows cabin filter replacement every 10K miles for normal. & special operating conditions.. They are using a different, less convenient but more compact format in that manual.
    The 2023 Prius is every 30K miles though. I figured out this link to the guide.
    https://www.toyota.com/content/dam/toyota/brochures/pdf/2023/T-MMS-23Prius.pdf
    Same with the 2023 Prius Prime
    https://www.toyota.com/content/dam/toyota/brochures/pdf/2023/T-MMS-23PriusPrime.pdf
    #12 Prodigyplace, Jan 10, 2025
  13. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    The correct viscosity is SAE 0W-16, but SAE 0W-20 will mostly hurt the fuel economy and be OK otherwise. I don’t like thicker oils in Priuses because the engine is on only half the time and the oil hardly ever warms up.
    Overfilling the oil would cause foaming (aeration) if the oil in the pan touches the bearings, which would in turn result in engine damage due to insufficient lubrication because of the air bubbles in the oil. Nevertheless, only 1-cm-too-high should be OK, as there is a good safety margin between the top of the oil in the oil pan and the bearings. If you are too concerned about it, you can buy a manually operated vacuum pump and suck the oil out of the dipstick.
    As for the cabin air filter, it is very expensive, and doing it every 10,000 miles is an overkill unless you are driving on very dusty roads. As long as your windshield does not fog, doing it every 30,000 miles as in the US maintenance manual is OK.
  14. Trollbait
    12,832
    The 10k mile for the cabin filter is probably to get fresh carbon in there to avoid smell issues.
  15. Prodigyplace
    12,720
    11,852
    Central Virginia
    I thought it was for dealer service to upsell you and reclaim some profit lost by only selling hybrid Camrys.
    PrimeDan likes this.
  16. Hammersmith
    Hammersmith Senior Member
    2,497
    2,559
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Air filters(both cabin and engine) only need to be replaced if they're dirty. It's a waste of money to replace them on a set schedule.
    The only exception is if you use activated charcoal cabin air filters. Those have to be replaced once a year because the activated charcoal has a shelf life. An activated charcoal filter will continue to filter the air just fine after a year, it just won't have the odor removing qualities that a fresh filter does.
    (to my knowledge)The Prius comes with a standard cabin air filter, so there's no need to automatically replace it after one year.
    The HVAC disinfection was also a scam addon unless the owner complained about bad odors when they brought it in for the service.
    And the fuel additive was a scam.
    I'd be shopping around for a new dealership for the servicing. (I'm assuming they charged extra for the filters, additives, and services.)
  17. Mendel Leisk
    42,369
    2-3 decades back there were no cabin filters, however did we cope? ;)
    I finally changed both cabin and engine on our ‘10, at 90k kms: cabin filter was getting there, engine filter looked practically new still. Just figured better do it once in the car’s lifetime. To be fair: we’re west coast BC, not as dusty I think.
    again, paying professional mechanics to do this is nuts. They scare owners with the “maintain complete service record” script, pile on all the BS services Toyota says nothing about, and omit the ones that are difficult, not cost effective (easy) for them, and/or expensive for owners. Brake maintenance in particular is neglected, dealerships and owners dislike dealing with it.
    #17 Mendel Leisk, Jan 11, 2025
  18. Prodigyplace
    12,720
    11,852
    Central Virginia
    I am surprised city pollution did not clog filters up.
    Here in rural Virginia I definitely keep a check & change the engine air filter regularly. I do not check the cabin air filter as much but I have had to change it due to rodents building a winter nest on it,
    #18 Prodigyplace, Jan 11, 2025
    daisy555 and Mendel Leisk like this.
  19. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    on top of that, they rised the pressure to 2.7 bar...while the sticker on the driver's door says less...maybe to counterbalance the additional oil viscosity??;)
  20. peternumber2
    peternumber2 Member
    134
    36
    Rome
    2023 Prius Prime
    Yes they did charged such extras....though they told me before leaving the car what the service was going to include. I should have opted some services out.
