First Oil Change...Wait 10K Miles?
Discussion in 'Prius c Technical Discussion' started by Oldwolf, May 18, 2012.
  1. Oldwolf
    Oldwolf Prius Enthusiast
    816
    106
    NC
    2016 Prius v wagon
    I looked all through the forums for this subject. I will ask my dealer this question too when I pick up my C next week.
    Maybe I am still too old school but on the few new cars I have bought, I would change the oil at something like 1000 miles the first time just to get rid of any shavings or contaminates.
    In today's engines though, maybe the factory fill has break-in additives or something similar to help the new engine.
    Maybe just an early filter change is needed...or nothing 'til 10k?
    But then, the Toyota manual doesn't mention anything about early first oil changes, and I bet they know what is best for the engine after all.
    What did you guys do on your C's, early or wait it out?
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    my brother told me to do it at 2k so I'm in the same boat as you and i only have 600 some miles on my c
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    There you go! Every 1 year/10,000 miles. (that would be every 4 months if I had a Prius c)
    Lil' Blue likes this.
  4. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Whatever makes you feel good.
    I did mine early. Others that think every drop of oil is a precious gift from mother earth will tell you to wait as long as possible. Yet others are afraid to anything that isn't approved from Toyota. Old timers want to get the khrap out and get some clean oil in.
    Assembly lubes are for assembly. If they assisted with break in I doubt they would be needed all the way to 10k miles. They serve no purpose past assembly. That I recall there has not been anything found in analyzed factory fill oil that would indicate an break in additives in a modern oil.
    Early won't hurt. On time won't hurt. Whatever floats yer boat.
    snead_c likes this.
  5. Mike500
    Mike500 Senior Member
    2,593
    764
    I'm NOT going to say that I'm incredible (I'm just a little smarter than the average bear.) but I'm going to change the oil in my "v" at 3,000-3,500 miles, just to get the assembly lune out. 10K is just too long to wait. the oil and the filter is cheap in the long run.
    At 2,100 miles, right now, the oild is just turning a little yellow. I'll let the dealer do the next change "for free" at 10K.
  6. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    i'm waiting until 10K until my first oil change.. anything before that is really unnecessary and a waste of money.
    dellrio, schorert and ianblake like this.
  7. TruSound
    TruSound Member
    246
    32
    The 818
    In this case I'd have to agree with Squall, I'm usually the change it early guy, not with this car, I'm at 5k on my v3 and the oil has barely changed color, I see no point in changing oil that looks fresh, besides...it's not like your going to get an extra 20k out of your ICE changing it early, actually you'll impead piston ring seating if you change it to early.
  8. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    I have no issues waiting for first at 10K
    Another thing to add is my all time overall EV % is over 50%
    So reality is about 5K give or take.
    I know this doesnt have to do with the 10K Toyota recommends,
    as they have it on their non hybrids also.
    They warranty millions of the cars for 10K oil changes, so I dont think they are playing
    any foolishness here.
    bgil likes this.
  9. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    there is no doubt for us c owners. squall is the man!! ( in his own charming way):)
  10. El Dobro
    El Dobro A Member
    6,978
    3,213
    I changed the oil at 10,000mi.. I don't think manufacturers are even using break-in oil anymore. Don't forget, they're all under the gun to save resources. Have you noticed, there's more and more use of electrical assist power steering instead of hydraulic.
  11. Oldwolf
    816
    106
    NC
    2016 Prius v wagon
    When I picked up my new C4 this weekend my dealer said you don't need to change the oil prior to the 10k mark.
  12. priusCpilot
    priusCpilot Active Member
    631
    209
    LA
    You guys can check out the report I posted at 1k if you search here. It looked very good and no wear metal so Im also using the factory fill until 10k. I will at 5k send the oil out again for an analysis and post again.
  13. Oldwolf
    816
    106
    NC
    2016 Prius v wagon
  14. magtataho1
    magtataho1 New Member
    Delta, BC
    In BC or probably in Canada, the recommended change oil is every 8000Km or 6 months which ever comes first. The days wherein the car needs a change oil after 1000km is just a recommendation from the dealership (salesman) you bought the car from. It is another way of service dept to get something extra from the customer.
  15. priusCpilot
    631
    209
    LA
    This was why I left mine and did an oil report which looked great. The add pack is different on the factory oil for the break in just like the Honda guy posted on the site.
  16. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I just like to remind everyone during these oil change interval discussions that Toyota's change from 5k to 10k miles was not originally based on an engineering decision. When the 2010 Gen III first came out in the summer of 2009 the OCI was listed as 5k miles in the Maintenance and Warranty Manual.
    It was not until owners started complaining about the higher costs of the synthetic 0W20 oil changes and the mileage between changes remaining the same. It was pointed out again and again that the synthetic oils were capable of going up to 10k miles or more. IIRC it was not until after the first of 2010 before Toyota finally relented, changed the OCI to 10k miles and sent out revised Maintenance and Warranty Manuals. So this was more of a marketing decision dealing with disatisfied customers than it was an engineering decision.
    Of course the engineers were probably saying all along that the OCI could safely go to 10k miles but the marketing arm overrode and the OCI started out at 5k. I am sure the dealers were against this and having to give up a service opportunity. They did not change the maintenance warning on the MID and left that at 5k :) stating that you still needed a tire rotation, inspection and fluid level checks.
    SILVERCwSUN and Oldwolf like this.
  17. Britprius
    Britprius Senior Member
    5,194
    1,914
    Herefordshire England
    It does look strange when you see that in every other country apart from the US/Canada the oil change interval even on the gen 2 Prius is and always has been 10,000miles or one year.
  18. El Dobro
    El Dobro A Member
    6,978
    3,213
    Oil protection does keep getting better. Plus, cleaner fuels put less crap in the crankcase.
  19. Mendel Leisk
    38,644
    Just looking Toyota's maintenance requirement for a regular 3rd gen Prius:
    For the transaxle: leave the fluid in, forever, LOL.
    For engine oil changes, they do a flip-flop at the 49th parallel in North America: in Canada the oil change interval is 6 months or 8000 kilometers (5000~ miles).
  20. Oldwolf
    816
    106
    NC
    2016 Prius v wagon
    Elsewhere in the C forums there is a 5W40 thread. What is most interesting is the OP is from Singapore and his dealer recommends a first oil change at 1000km.
