First Prius. How'd I do?
Discussion in 'Newbie Forum' started by Banksy, Feb 29, 2020.
  1. Banksy
    Banksy Active Member
    415
    133
    Lancaster Pennsylvania
    So I bought a 2008 Prius and it's been my pet project for the last month. The car had cosmetic issues and still has scratches on the doors I need to correct.
    250k on the clock, new HV battery.
    I paid 1900 for it along with 130 for a new fender and 120 for tires. Along with some misc supplies.
    Zero rust, looks to have been taken care of by it's previous owner.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Looks like a good deal to me:).
    Now that the battery is sorted, the next major things are the brake actuator and just keep an eye on the oil level;).
    Good luck with your new to you Prius(y).
    #2 Raytheeagle, Feb 29, 2020
    edthefox5 likes this.
  3. Banksy
    415
    133
    What are the symptoms of that?
  4. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    For the brake actuator, you'll hear it more;).
    There will also be dash lights telling you about the issue(y).
  5. PriusCamper
    PriusCamper Senior Member
    13,472
    5,439
    Pacific Northwest, USA
    Nice looking Prius you got there... Once you cover up the Patriots logo, it'll probably be good to go for a long time, unlike the Patriots.... :) Go Eagles!
    hyp3rmil3r and Raytheeagle like this.
  6. Banksy
    415
    133
    The irony of this is I live in Pennsylvania.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Welcome to PriusChat!
    Looks like a keeper! PriusChat is the perfect place to learn all you'll ever need to know about the amazing Prius! Find out all you can about Prolong Grid Charging (Hybrid Automotive). Nice colour! Looks like a great car! Congratulations! :);)
  8. ETC(SS)
    7,572
    NEEDS a different front license plate.....
  9. Banksy
    415
    133
    Nevahh
    ETC(SS) and Jon Bloom like this.
  10. Jon Bloom
    Jon Bloom Member
    77
    78
    Connecticut
    Tailgating at Gillette with my PP. Just sayin'
    Burna J likes this.
  11. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Not sure if you noticed it yet, it is kinda like a long low electrical moan.
    Some say barking etc.
    If you are sitting in P hit the brake and should hear it cycle.
    Not sure the norms for gen2 but gen3 is maybe 2-5 seconds
    Somewhat hard to hear if you are actually driving and such.
    Gen3 will also cycle when you first open the drivers door.
    Congrats on that heck of a deal with new HV batt!
  12. Banksy
    415
    133
    When i open the door or before I start the car I'll hear like a clicking noise but other than that nothing at all when breaking
  13. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Yeah you would need a trained ear for it. Very hard to distinguish the sound.
    Maybe it is just quiet.
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Like Ray says the brake actuator is the abs pump. Brakes need vacuum to work vacuum comes from the engine and engine not always on unlike a regular car so actuator creates vacuum when engine not on. Abs failure is that pump leaks and constantly cycles.
    If you open the door or with engine off just push the brake a few times that pump will cycle. Sounds like a rattle snake. You will hear that come on now and then quite often. Only runs for about 2 seconds.
    A failed abs actuator will cycle constantly even when not pushing the brake pedal.and the brakes will be affected.
    Also Most high mileage g2 engines use oil. You need to find out how much.
    In the morning before starting the car check engine oil every few days till your u see how much loss there is. Keep oil at the full line.
    #14 edthefox5, Mar 1, 2020
    Banksy and Raytheeagle like this.
  15. Banksy
    415
    133
  16. Banksy
    415
    133
  17. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Banksy stop quoting posts and then adding onto them. Just start a new post and reply to previous post like you did in #12 post its easier to understand.
  18. Banksy
    415
    133
    My bad!
  19. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Sounds normal.
    Dont worry too much, it would be running long time, or constant or throw code if shot.
    @Raytheeagle was just pointing out some known problems with your year.
    Also, dont forget that he mentioned to keep an eye on the oil on the dipstick :sneaky:;);)
    Raytheeagle likes this.
  20. Banksy
    415
    133
    Having owned three Saturn SL2s I know all to well the pains and importance of checking oil consumption.
    I had a SL2 once that burnt a qt every 400 miles.
    Was a nightmare.
