First Prius...Is This A Normal Drivetrain Sound ?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by TruSound, Feb 19, 2012.
  1. TruSound
    TruSound Member
    246
    32
    The 818
    Recently purchased my first Prius, it's the v wagon.
    When accelerating from a stopped position in eco mode there's a relitivly severe drivetrain shutter/vibration for a a short period of time until I back off the throttle, almost feels like a clutch slipping with added vibration.
    It's probably a normal noise produced by this style transmission, just looking to verify if this is true so I can stop worrying about it.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Should be smooth as silk... well at least until the engine kicks in. For the first few thousand miles I couldn't even really feel that.
    I would have the dealer look at it.
  3. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    Nothing like you describe in my Prius v (wagon). I did initially notice more road vibrations coming through the gas pedal than on my trade in Lexus RX300. But raod vibration would not respond to you easing off the gas pedal. I hope we can explain this mystery, and that it does turn out to be the actual dirve train.
  4. TruSound
    TruSound Member
    246
    32
    The 818
    It's definitely not road vibration Chazz, best way I can describe it would be clutch chatter, once the transition to the ICE is complete it smooths out...I'll need to drive another one to verify its normal Prius behavior, I'm sure it is...being my first hybrid these's lots of system nuances I'm not used to, it's a very different animal.
  5. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Can you record the sound or do a Video to see if we can hear it? You might want to narrate also what you might be doing at the time.
  6. rjparker
    rjparker Tu Humilde Sirviente
    7,979
    4,724
    Texas Hill Country
    Not normal. Prius V has one of the smoothest takeoffs of any car. Even the transition to the gas engine is usually only heard (sometimes) but not felt.
  7. TruSound
    TruSound Member
    246
    32
    The 818
    Let me be a bit more specific as to when this happens...
    When taking off very slowly in EV mode...throttle position is just off idle, like when in 5mph bumper to bumper traffic on the 405, no chatter, vibration or anything else...just smooth and quiet.
    What I'm experiencing happens under moderate acceleration from a stand still, I would say 1/2 throttle, the car is in eco or pwr mode and the gas engine isn't running.
    Based on RJ's feedback my v has a problem, take off is definitely not quiet or smooth under load...apparently driving another is going to be necessary, some say normal, some say not.
    All feedback is appreciated...
  8. Chazz8
    Chazz8 Gadget Lover
    744
    234
    61
    Central New York
    How long does the vibration last?
    Under the conditions you describe I would expect the one of the electric motors to spin up ICE to proper RPMs before injecting fuel. I would guess that it takes less than a second to do that. I have on occasion felt a minor shudder when the ICE comes to life. I can't tell if it's the spin up or the start of combustion, but it does not sound like what you are feeling in your Prius.
    Let us know when you when you test drive other Prius v's to compare the vibrations.
    Have you shown your dealer yet? If it is really obviously wrong, I'd think they would want to make it right.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Are we sure the OP isn't describing ICE start? That produces a small shudder.
    Tom
  10. Keiichi
    808
    79
    Goleta
    But he does say the following:
    While I feel a vibration when my car switches to the engine, it isn't 'severe' as he says. I feel a minor vibration when it kicks in. But again, not severe. It suggests that he is noticing it a lot, where as I sometimes notice it, sometimes not.
  11. TruSound
    TruSound Member
    246
    32
    The 818
    Being my first Prius I'm hypersensitive to any noise this thing makes, I guess describing it as severe might be a little over the top, I suspect it's just the transition from full electric to ICE...to be continued. Thanks guys.
  12. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    You might try going back to your dealer and "test drive" another V, if it feels the same...
  13. TruSound
    TruSound Member
    246
    32
    The 818
    That's exactly what I'm gonna do Gurple, then I can put the worry beads away and just enjoy the ride.
  14. rjparker
    7,979
    4,724
    Texas Hill Country
    Be sure you are using a good 87 octane gas with no more than 10% ethanol. Shell is reliable around here, others have been known to cheat on the octane.
  15. TruSound
    TruSound Member
    246
    32
    The 818
    Good to know RJ, my 3 faves are Shell, Union 76 and Mobil, I'll check their ethanol ratio.
    Thanks
  16. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    I think I know what TruSound is observing. I'm a new hybrid owner too and noticed something similar and it is indeed in my case for me the transition to the ICE. I'm hypersensitive as well learning a new set of normal experiences.
    I remember on the test drive thinking we had a problem when the ICE shut down at a traffic light. :doh:
    So far I really like the car. Getting used to the fuel gauge not moving is a little strange but welcome. Let us know TS what you learn. W
  17. TruSound
    TruSound Member
    246
    32
    The 818
    I'm going with ICE startup, getting accustomed to it now and just enjoying the vehicle.
  18. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    When I accelerate from a stop my little energy monitor doesn't stay in Eco mode. I usually get right into power mode, up to about 15 - 20 mph, then back off the gas pedal a little. That lets me keep up with traffic and doesn't tax the battery with the hardest job the car ever faces - starting from a stop. So far it hasn't hurt the mpgs I've been getting, which are equivalent to what I was getting with a 2009 Touring Prius.
  19. bisco
    49,501
    i don't have a v, but when i accellerate from a standstill using about 1/2 throttle, the ice fires right up and is fairly noisy. but one man's drum roll is another's whisper.
  20. Keiichi
    808
    79
    Goleta
    Well, also, it depends on how you drive, literally. I mean, for me, I'm playing music at Vol 20-25, for instance. I feel the subtle vibration when the engine kicks in, but I don't hear the sound of the engine. Now unless I push harder, I do hear the engine, but I am also used to the sound of the engine from the days when I drove my old car. I don't know what it was like for the rest of you, but didn't seem 'out of the ordinary' for me.
