First Road Trip Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by kevin54, Jan 14, 2017.
  1. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    Okay, here she is with all the road salt from yesterday washed off!
    priuscatprimeguy, RJ Primw and bisco like this.
    52,849
    gorgeous! great write up, thanks! (y) how did you feel about hatch storage vs your previous prius for a road trip?
  3. huskers
    huskers Senior Member
    2,549
    2,488
    Nebraska
    Sharp looking. Silver?
  4. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    Thanks! I was a little concerned with the raised platform, but actually there is still plenty of room for our bags and all my camera gear on a trip. I sort of like the cheaper cover on the Premium cause it's flexible enough that if you close the hatch, the cover will still cover the contents but will be raised a bit. The lack of third seat in the back was of no concern to me. 99% of the time it's just me or one other, rarely we'll drive another couple to dinner, and never have we ever driven 3 people. I also feel the back seats are much more comfortable and there seems to be more room, leg and head. Usually in our other Prius we were more tired after having driven 550+ miles, but not so with this one - maybe it's the seating comfort. BTW, we've had 2 Gen2 Prius' (2005 and 2006) and 2 Gen 3 (2011 and 2012). Now we have this and a Honda CRV.
    Yes, it's the Silver with black interior. I also like the white but that wasn't available. I lucked out cause this was on the lot and we just happened to see it while driving by, and it was a Premium and equipped pretty much like I wanted.
    I'mJp and bisco like this.
  5. huskers
    2,549
    2,488
    Nebraska
    Not many people fall into that kind of luck.
  6. kevin54
    kevin54 Member
    57
    65
    New Hope, PA
    I know! I had read a bit about the Primes but had never seen one and wasn't really in the market for one, at least not yet. When we went by the dealer and saw it, we went in on a whim. I bought it that day! Now I see they're not that easy to get. I haven't seen any dealers in PA with them. I bought it in N.J.
  7. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    That's the color combo I've got on order.
    kevin54 likes this.
  8. bwilson4web
    16,533
    I found dynamic cruise control in our BMW i3-REx really helps on long distance travel. It isn't obvious until you experience it. The constant attention to speed control is fatiguing. Offload the driver and the drive becomes more 'sit in a comfy chair' and enjoy the music.
  9. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    correct, if auto climate is set to off you should not see any pulses coming from the battery to the fan icon, I could be wrong but with no pulses your EV range is at the highest range.
  10. Tim R
    Tim R Member
    St. Louis, MO
    We picked up our Prime in Buffalo and drove the 750 miles back to STL on New Years Eve. I must agree with your comments. Superb road handling. Of course we had a 25 MPH head-wind all the way due to storms so we didn't get stunning gas milage, but good still.
    One of the fun messages is the coffee cup with "Isn't it time to take a break?" I guess its sway warning, but cannot find it in the manual... anywhere.
    I notice in the manual that for extended highway driving they recommend turning off the EV setting and running HV. Seems to make some sense. Why run the battery down in the first 25 miles? ... but we didn't see that until we were home.
    Also note that you can get the engine to charge the battery by press/hold the EV/HV switch for about 2 seconds. Manual says that this uses more gas. Still, if you are on a long incline and gas engine running already, then might make sense?
  11. Gen 3 for me
    Gen 3 for me Member
    198
    81
    Illinois
    Does anyone know if you purposely turn on the ICE by pressing the EV/HV switch for 2 seconds how long will the ICE run?
    Does the ICE continue to run until the driver pushes the EV or EV Auto button?
    I am hoping that the driver has control over keeping the ICE running, since if the ICE turns on for the first time during any day and I only have a short distance remaining to drive, I would prefer the ICE to be able to continue to run to properly warm the ICE and not get water condensing in the oil due to the short run time.
  12. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Until the battery is at 80%.
  13. Trollbait
    12,825
    Whenever the ICE comes on for the first time in a day, it will go through a warm up cycle. There is also an oil maintenance cycle that will use the ICE if the car has gone 200 miles since the last ICE use.
  14. bisco
    52,849
    gas maintenance cycle?
  15. jcburns
    jcburns Junior Member
    Atlanta
    #35 jcburns, Jan 16, 2017
    MNdriver, kevin54 and taigebu like this.
  16. Trollbait
    12,825
    I'm not sure what Toyota calls it, or if they have different cycles.
    I know the Volt has an engine maintenance mode to circulate the oil and boil off moisture, and a separate fuel maintenance mode for when the car has gone a year without getting a fill.
