first taste of driving Prius in below zero
Discussion in 'Gen 2 Prius Fuel Economy' started by chuckyjean, Dec 16, 2010.
  1. chuckyjean
    chuckyjean New Member
    Wisconsin
    Last two mornings have been 20 below zero. Brrrrr. Got a first taste of driving Prius in that cold temperture. Car started right up (car has electric start correct), even after 30 miles of driving, I could get very much heat in the car, it was a very cold ride into work those mornings. Fuel mpg not the greatest in extreme cold, only about 35 mpg.
    48,994
  3. jordanr
    jordanr Member
    180
    NorCal
    Wow that's cold! It's good to know the mpg is still in the 30s in that kind of weather.
    iPhone ?
  4. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    Time for major grill block, if you have not yet done it!
  5. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    With all the electrical power than can be generated by the two MG units, it's a shame the don't make a 1000-1500W or so electric heater an option. It would use a little extra fuel but I would gladly pay the price if I lived in East Snowshow Montana or the GWN.
    Instant defrost heat and cabin comfort in short order. It would only take roughly 1/4 gallon of fuel an hour to generate that much electricity. That would be partially (not much) offset by the fact that the engine would warm up faster with the extra load so would be out of warm-up mode sooner.
  6. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I'll say it again, Block your grill. The car will be much more comfortable for you.H
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Electric heat isn't an option; it comes standard with all Prius. Perhaps you would like to have bigger electric heaters.
    Tom
  8. theshark
    theshark Member
    164
    Martinsburg, WV
    What do you mean block the grill? How do you do this?
    Thanks
  9. AkustaVirtaa
    AkustaVirtaa Sähköistäjä
    198
    Finland EU
  10. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
  11. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    You may want to consider installing an Engine Block Heater as well. Plug it in (or turn it on, or set an electric timer) a few hours before your typical morning commute. You'll get heat from the engine sooner, and your MPG will improve.
  12. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi All,
    ChuckyJean is driving a 2005 . So, the 2010 Grill Blocking stategies do not apply. Block everything up, except for a small sliver on left hand side of the driver's side of the lower grill for below zero short trip driving.
    I remember my Saturn SL2 got about 20 mpg in -5 to +5 days. That was down about 40 percent for sumertime no-a/c mileage. 50 / 1.4 is 35.7 mpg, so that is a very similar difference.
  13. DetPrius
    545
    92
    Southeast Michigan
    Tom, do you know the parameters which will trigger the electric heating elements? I was looking for it a few days ago, found some information, but could not force the heaters to come on. I do remember last year smelling them once but I can't figure out how to trigger them at will.
  14. qbee42
    18,058
    3,073
    Northern Michigan
    Max heat will force them to run. Otherwise it's some combination of inside and outside factors which I can never remember.
    Tom
  15. LarryC568
    LarryC568 New Member
    St. Louis, MO
    I've got a 2005 Prius, and since it got cold here in St. Louis (15-30 deg.), my MPG has been around 29-34 MPG. Is that normal for cold weather?
    Larry C
    [email protected]
  16. john1701a
    john1701a Prius Guru
    12,749
    5,243
    57
    For short trips (3 miles), that is. The emissions-system requires heat for cleansing. Running the engine is how it gets that heat.
    Driving further, you'll notice MPG goes up. My commute with the Iconic model (gen-2) throughout the winter here in Minnesota average low to mid 40's. Being 33 miles round-trip contributed to that.
    Think about the other hybrids that don't bother to deliver a PZEV emission-rating. They favor MPG rather than being cleaner, yet Prius trumps them on efficiency anyway...
  17. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    My last tank got a brutal 32 mpg (US). I have lots of short trips, but yeah, cold well below freezing is murder on the Prius gas mileage. I average around 42 mpg (US) during the summer but boy does it go down in the cold.... block the grille and use the block-heater. That's about the best you can do.
  18. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    It's nice to own a car where 32 mpg is brutally low.:D
    2 people like this.
  19. Bob.H
    Bob.H Junior Member
    38
    Findlay, Ohio
    20 degrees, defrost and heat on and making all short trips of 4 miles or less for 150 miles we got 36 MPG. Our old Detroit ride got 12 in this weather. We suffered the 4 buck a gallon gas with that beast before the Prius. Never again!
  20. 13Plug
    581
    104
    2013 Prius Plug-in
    Ya know, I've had the Prius so long that that is an embarrassing number. There's no way I could own a gas pig anymore (as my main vehicle.... I still have a Hemi Dodge Ram for summer camper towing).
