First Three Weeks of Driving
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by J.R. Fisher, Jan 15, 2013.
  1. J.R. Fisher
    J.R. Fisher Junior Member
    27
    Attached is a picture of my driving ratio screen. This is what I have done in the first 3 weeks. This is in West Virginia and it has been cold and wife does preheat it in the mornings before school. This also included a 250 mile trip back from picking it up at the dealer though the mountains. And the driving ratio has not been reset since it was new included whatever the dealer did with it. Maybe someone can help me calculate my real MPGe.
    cost of KWH here is .10 per KHW, gas is about 3.50 per gallon here average.
    JMD and JamesBurke like this.
  2. give dinosaurs a break
    Here is my interpretation of wikipedia
    46.51 = [(156+755) miles x 34.02 kwh/gallon gas ]/[18 gallons x 34.02 kwh /gallon + 47 kwh x 1.15 wall efficiency ]
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Electricity efficiency:
    47 kWh x 1.15 (charging loss) = 54.05 kWh from the wall
    54.05 kWh / 156 EV miles = 0.3465 kWh/mi
    33.7 kWh (gallon equiv) / 0.3465 kWh/mi = 97.3 MPGe
    Gas efficiency:
    755 miles / 18 gallons = 41.9 MPG
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    A few tips...
    Do not preheat it. It'll use gas to warm up the cabin air temp is very inefficient. Instead, use the electric heaters embedded in the front seats. It takes less than a minute for the seat to get hot (at HIGH).
    There are two EV Driving Ratio screens. You can reset one to keep it fresh and start from your normal routine. Check back in a month or so. :) I am sure others will have more tips.
  5. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    Check out grill blocking and pump up your tires. You can find threads on both of these topics.
  6. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    Howdy!
    I too have had my PIP a little over 3 weeks. A couple days ago I got around to check the air pressure in the tires. They were down to 20 lbs each. Got them up to a couple pounds above the recommendation. I have also used all the other suggestions on this forum, and now the ICE doesn't fire up until I am down to less than .1 mile of EV left.
    I live in the Finger Lakes Region of NYS, lots of hills and it has been very cold out. Still averaging close to 70mpg in all my driving. I normally can do about 50% of my driving with the electric alone. The last month I have been doing a lot more trips due to some circumstances (only about 18% on electric alone), but I still love the car.
    BTW, where the heck is the clutch? Always had one of them in all the other cars and trucks I have had over the past 50 years... :D
    lensovet and JMD like this.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    You lost it! Thats what happens when you get old! :p
  8. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Clutches disconnect the driver from the road. PiP has none so we have 100% connection to the road. :D
  9. SLOW_RR
    SLOW_RR Member
    155
    84
    You mean I don't have to stomp my left foot on the floor every time I put it in gear??? What fun is that? Actually I have owned one automatic transmission truck back a couple decades ago. I hated it with a passion! I didn't feel I had any control over what it was doing. Every time I went up a hill with a trailer, it was: Shift, shift, shift, shift.... Went back to my good old 5 speed after about of year of putting up with it.
    Oddly enough the PIP gives me the feel that I am actually in charge of what it is doing most of the time (even though I know the computer does everything). I got used to it very quickly and love it.
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
  11. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Yep the good old days when you interacted with your car.
  12. retired4999
    2,652
    627
    Eau Claire, Wi.
    We don't intereact with the car any more. We are one with the car! :rolleyes:
  13. JMD
    3,779
    1,282
    When I get in my Prius I say "May the Force be with you" and " Ahead Warp factor 3".
  14. JMD
    3,779
    1,282
    Hey the good news it is a Prius and not a Boeing 787.
  15. retired4999
    2,652
    627
    Eau Claire, Wi.
    When I get in my Prius I say "may the Force be with you" and " warp factor 3". (y)
    Hey the good news it is a Prius and not a Boeing 787. :eek:
    JMD likes this.
  16. CharlesH
    2,798
    1,166
    Roseville, CA
    Apparently Toyota did a bit better design work on LiIon batteries than did Boeing. :) Haven't heard of any PiP batteries catching on fire/leaking/melting.
    JMD likes this.
  17. Zimmy 1
    Zimmy 1 Junior Member
    61
    Smithtown NY
    AND WE SET THE POINT GAP WITH A MATCH BOOK COVER
  18. retired4999
    2,652
    627
    Eau Claire, Wi.
    Been there, done that, thanks for the memories! :D
  19. JMD
    3,779
    1,282
    Looks like that Boeing Dreamliner's Traction battery got a little too hot and leaked some coolant also, in Japan. Wonder if they have the same warranty as the Prius does? LOL
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I think it is an aux battery for the Dreamliner. The same issue happened with Volt after the crash test. Battery coolant leaked and shorted out the electronics then the entire pack burst into flame. PiP has air con battery cooling system.
    JMD likes this.
