First Time Disappointment w/Toyota
Discussion in 'Gen 2 Prius Main Forum' started by aubergaz, Dec 23, 2008.
  1. aubergaz
    aubergaz New Member
    28
    Phoenix, Arizona
    I've had my first disappointment with a Toyota response to a problem.
    I've had my 06 since April of that year. I'm used to its temperment. Like many my fuel gauge drops slowly. When I'm down half full I've normally gone about 275 miles (I know I'm not going to get 550 off the tank). When I'm down to one bar I'll normally fill up and take about 10-10.5 gallons.
    After an aux battery failure, that initially corrected itself, I noticed my gauge was acting a little strange. After replacing the battery it still seemed to be acting unusually.
    When I went to fill it up, after about 300 miles or so, it only took about 7 gallons. The gauge was a full 10 bars. The gauge started to go down after about 70 miles, rather than the 120 or so it normally took. Once again when I was down to about a bar, it only took just over 7 gallons again.
    I talked to my dealership which said they had a service bulletin indicating that in 'cold' weather, there could be fluctuations in what the bladder would hold. I live in Phoenix. Cold for us is low 40's in the middle of the night. I was filling up during the day when temps were 55-60 degrees. If that is cold, what do you folks in Minnesota, Wisconsin, N Dakota get?
    My mileage is still running 46.5 to about 51. The gauge 'fills' and just seems to go down faster.
    My dealership said to open a 'report' with Toyota which I did. My rep, someone named 'Brittany' I believe, merely is reciting the service bulletin, but hasn't quite understood that this is my 3rd winter with the car. Why hasn't this happened before? And why when I was at Bryce Canyon with tempatures around 18-20 degrees did this problem not occur.
    She steadfastly said noone from Toyota would address the issue until the dealership identified a specific problem. That's NOT good customer service. I'm telling them there is a problem. Their service bulletin just speaks to 'cold' weather, but gives no definition of what 'cold' is. I sure don't think that 55-60 degrees is 'cold'. It may be cold to us in Phoenix, but I know the vehicle operates in much colder climates than this!
    If anyone has had similar problem that has been identified by their dealership with a resolution, please let me know.
  2. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    if you don't get as much gas in, the gauge will definitely start to drop sooner. as for the connection between the new aux battery and the gas fill problem, there's no feasible way that a new 12v can cause a change in the gas tank.
    personally, it's extremely uncommon for me to get much more than 8 gallons in the tank. i usually run it until the last bar is blinking. really, i wouldn't get too worried about it.
  3. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    Mine consistently blinks around the 8-gallon level all year long. Of course, I never push it or top off. That probably helps.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    So are you saying that your Prius doesn't take as much gas as it used to? That's a common complaint when the weather gets cooler, and yes, your weather is cooler. It is even more pronounced with our cold winter weather.
    Tom
  5. Tideland Prius
    16,155
    Ugh I barely got 7.5 gal in at 23F weather. In the summer, it's closer to 10 gal.
  6. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    At one pip I've only been able to get 8.9 gallons in, max (summer or winter.) Usually it is less than 8 gallons. I wish I could get 10. Effectively, I have no more than an 8 gallon tank at present and that isn't satisfactory.
  7. Bob64
    1,540
    92
    Virginia
    I can barely squeeze in 5 gallons :p
  8. swi66
    swi66 Member
    193
    Gasport, NY
    Yes........
    Thought this was strange myself.
    Regularly below freezing here at this time, but at one bar 7-8 gallons then full.
    I'm afraid to let it go below that one bar...........
  9. spitinuri
    spitinuri Member
    317
    Same here. The best I've been able to get in is around 8 gal.. I have read here about people still going 100 miles after the blink. I don't think that I would try it though.
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Do I see a market for Australian tanks without a bladder?
