First time owner. Is this normal?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by HalfPacked, May 19, 2026.
  1. HalfPacked
    HalfPacked New Member
    2014 Prius v wagon
    I just purchased a 2014 Prius V, and I suspect it's not running quite right.
    It seems like the gas engine is always running unless I'm stopped, going downhill, or moving very slowly through a parking lot. Like 15 mph.
    It also engages as soon as I start moving from a stop, even if I'm accelerating gently.
    Additionally, I took about 5 minutes after starting the car to get myself situated before pulling out. In that time the battery indicator on the dash went from full to about 1/3. The air conditioner was running and my phone was charging, but it's still a faster drain than I would've expected.
    I plugged in an OBD2 scanner and it came back with no codes. Is this expected behavior or should I get it looked at?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,957
    6,873
    Texas Hill Country
    Normal. Its not much of an ev only car.
    The key factors when normal are the battery charges most of the way only when driving. It will not fully charge while motionless in Ready. Second a good high voltage battery will allow the engine to stop at lights without forcing it to start.
    Hybrid AC compressors run on high voltage battery power which gives you ac when in Ready regardless if the engine is running. However it will discharge the battery fairly quickly if not moving, forcing the engine on. But normally not at a traffic light if the battery has good capacity.
    Brian1954 and Air_Boss like this.
  3. PriusCamper
    PriusCamper Senior Member
    13,380
    5,407
    Pacific Northwest, USA
    How many miles on the car? Sounds like your hybrid battery has lost its capacity and you can restore capacity through doing three successively deeper discharges and recharges with a high voltage trickle charger and some light bulbs for the discharge. You can build this gear yourself, or buy an adjustable DC power supply that can do 250volts and 1/3rd amp. Or buy a Prolong or Maxx Volt products.
    Or just upgrade to a new Sodium-Ion pack to get better all round performance than even when the car was brand new.
    Also if you let us know where in the US you live, someone on here might live near you and can do the work for you.
    52,749
    welcome!
    sounds normal for an old prius
  5. ChapmanF
    18,936
    Have you driven any Prius before? Sometimes people come to the car with distorted expectations.
    The car has a small battery, which is enough to recover a little energy that would otherwise be wasted in some circumstances, and give the engine a little extra boost in other circumstances, and do little of either, most of the time.
    The car's most efficient operation is when it is doing little of either. The efficiency of capturing energy into the battery and getting it back out is better than older cars just wasting it, but not better than just getting the right amount of power from the engine in real time and using that.
    So that's what the car does—most of the time.
    A big part of the car's efficiency just comes from being able to use a smaller engine with a more-efficient combustion cycle, so it is right-sized for most of your driving, and a brief boost from the battery comes in at those higher-demand moments that most cars have to upsize their engines for.
  6. HalfPacked
    2014 Prius v wagon
    Yeah, I test drove a 2020 Prius Prime. It had considerably more pickup, but that's a newer battery and (I think) a more powerful electric motor and engine.
    I thought that it should at least be able to drive a few miles in EV mode, albeit not fast or uphill or anything. But it can't get all the way from one end of the parking lot at work to the other without having to kick in the gas engine. That might just be normal for all I know, though, especially for an older battery.
    The car has a bit over 90,000 miles on it.
  7. rjparker
    10,957
    6,873
    Texas Hill Country
    A Prime is a plug in hybrid designed to drive 20-50 miles at highway speeds on battery alone. It has a much bigger battery. You have a standard hybrid that "might" ev a mile on flat land at 25 mph. It is specifically designed not to fully discharge the hybrid battery in an effort to make it last ten years.
  8. ChapmanF
    18,936
    I played with that too when I got my first Prius. I guess most people can't help having to try it out. For me the distance could be a city block or three, on flat ground at a low speed.
    Eventually you get over wanting to play like that.
    Even if you could cover the distance without having to kick in the gas engine, you're better off having it kick in, because that's when the (non-Prime) car's most efficient.
  9. bisco
    52,749
    if you are cruising along, and let off the gas, the engine doesn't shut down?
    you may not be using a prius aware scanner for the trouble codes
  10. PriusV17
    PriusV17 Active Member
    434
    206
    CA
    2017 Prius v wagon
    Your car was running on EV mode for 5 mins with the AC running. That's not bad. Instead you shouldn't situate yourself for 5 mins. Just run and go so you can maximize mpg and EV mode. If you turn off the AC you should still get a good mile or more of EV mode (below 25mph) if the bars are full. At 1/3 full your engine will struggle the whole time trying to power the AC and trying to charge the HV battery and trying to power EV motor all at the same time from a tiny 1.3kwh battery. Tesla has 60kwh+ battery. That's a big difference.
    Also in PWR and EV mode below 25mph you will experience more EV mode and better regen braking.
  11. PriusV17
    434
    206
    CA
    2017 Prius v wagon
    Actually you don't want to stay on EV mode for too long. Draining the HV battery will get you back to the same situation of running mostly on gas engine again. The best is when the HV battery operates between that 60-80% range to get the best of both worlds. AC will drain it but if you have to use it then you have to use it. Also consider fresh air vs recirculated since fresh air cools the HV batteries better over the life the car. More cooler fresh air passing through the HV battery modules is a good thing.
  12. Mendel Leisk
    42,233
    With a 2010 Prius (not plug-in) I only use EV (if and when available) for driveway shuffle stuff. Typically that'd be when the engine's warmed up. If you've got a stone-cold engine: you do also get about 15 seconds of EV, which can also be employed for driveway shuffle. Start the car, quickly shift gear, get it moving, while counting seconds. Shut down when you reach ten, to play it safe, restart and do again, as needed.
