First timer, 08, possible gas gauge issues... hopefully nothing bigger
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GCarp, Mar 6, 2018.
Tags:
  1. GCarp
    GCarp New Member
    Ohio
    Hello Prius friends! Im Grant, I am a new (used) Prius owner, just bought an 08 with a fair amount of miles (185xxx) but shes clean, one owner and all dealership maintenance... I am SUPER excited to have this car, and to be a part of this site... This will really hopefully be the car I drive for a good while...
    Unfortunately, Ive had some concerns,
    1) The on board comp says I am averaging 44 MPG which elates me, but when I ran the numbers based on gas used between fillups and miles driven... I am coming to closer to 18-19 MPG. Which is worse than the SUV I had previously. So... I have done a little homework on the site here, and found that fuel injector cleaner and fresh air filters are important and can make small difference respectively, (the air filter installed currently is fresh from the dealer a week ago, so this is not the issue)
    segue-way into concern 2
    2) When I went to fill up with the fuel injector cleaner (I had roughly 1/3 a tank remaining according to the HUD, so I SHOULD have been able to put just shy of 8ish gallons in) The pump acted as if the tank was still full and wouldn't allow me to pump more than a squirt at a time. After a gallon and a half of fighting with it I tried a different pump... Same problem after a half gallon (2 total at this point). Drove to a neighboring gas station and was able to put another ~3 gallons in there (5 total)... All the while, and the whole way home, my gas gauge made NO change from the 3 bars it was at previous to filling.
    So... I guess I end with a main question that hopefully can be at least spit-balled at... Anybody have any issues with the gas gauges beginning to read funny? That would alleviate ALL of my problems at once, as the gas mileage would not be as terrible as it looks like currently if the gas gauge was reading incorrectly, and the pump(s) not wanting to cooperate to a full tank would make more sense as well...
    Otherwise Im looking into possibly several issues right off the cuff with a car Ive had for a week.
    HELP please? :)
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Well if your calculating really bad gas mileage I’m not surprised. Usually really low gas mileage at those miles is because of a failing hybrid battery. The expensive one in the trunk. Or the engine is shot.
    Or little of both.
    Failing hybrid battery at your vintage Prius is now the #1 post on this site. Watch the battery consumption meter on the mfd, See how quickly the hybrid battery level goes into purple bars which is really low.
    If it goes into purple bars in a fast food drive through it’s time to either replace it or buy a discharge /charger system.
    If I was you I would go to Toyota.com/owners and join that forum. Have your vin handy.
    You will see every time the car has seen an authorized Toyota repair center at a dealer.
    Lots of people have seen why there car was sold.
    GCarp likes this.
  3. GCarp
    GCarp New Member
    Ohio
    Thanks for the quick reply!
    I actually havent made it down to purple battery lines yet, just the green and blue, and it gets back up to green with a seemingly reasonable amount of braking/coasting... so I feel like the battery is hopefully okay... at least for how old it is. Im just really concerned that putting ~5 gallons of gas hasnt made any move in the gauge
  4. GCarp
    GCarp New Member
    Ohio
    I will totally hit the toyota website up. Thanks!
  5. bisco
    52,878
    congrats and welcome!
    gen 2 (2004-2009) have a rubber bladder inside the gas tank, which can sometimes be finicky during fill ups. or it could be a bad gauge/sender unit, or perhaps it just needs recalibration.
    all the best!(y)
    GCarp and jerrymildred like this.
  6. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Rather than leap to conclusions not supported by the facts in evidence, I offer this.
    You may well have a gas gauge problem, if your reporting is accurate. The gas gauge will only register a change with a minimum add of 3 gals (in one go). You can force it to register the correct amount by disconnecting the 12 V battery for 30 secs then reconnecting. You will loose your radio station pre-sets, trip A/B readings, your accumulated average consumption and miles (on the consumption screen), your fuel trim values (although this is not a bad thing for a change of driver) and your auto-up/down setting on the driver's side window*. If you don't want to do this, the gauge should register the change itself eventually just driving.
    If you feel the gauge is not working correctly, you could try recalibrating the gas gauge, if you have a nice level space on which it do it. Search here in the Gen 2 forums to find the procedure.
    Are you aware of the gas tank bladder (only fitted to North American Market Prii) and the associated problems with it? Again, a search here of the Gen 2 forums will give you plenty of reading.
    PS, I'd go with the on-board consumption meter for now, although it is not 100% accurate, I'd believe its 44 MPG vs your calculated. Mind you, if the gauge has not been manually reset using the reset button on the consumption screen, then this will be the car's average since it was last reset.
    * To reset the auto-up, roll the window to half-way open. Then pull the window switch all the way up and hold it there. Once the window is in the full up position, continue to hold the switch for 3 seconds (count 1 international, 2 international, 3 international, in your head so you don't rush it). Release the up switch and now the auto-up/down should work.
    #6 dolj, Mar 6, 2018
    m.wynn, GCarp and srellim234 like this.
  7. GCarp
    GCarp New Member
    Ohio
    Thank you so much! I did a reset and it is reading full now... So I will monitor consumption again, see where we stand. Thank you for the suggested reading material, I am definitely digging through the forums. Love this site!
    srellim234 and Raytheeagle like this.
  8. VFerdman
    VFerdman Senior Member
    1,200
    1,221
    Western Massachusetts
    These cars have a flexible fuel bladder and it can be slow to expand when the tank is close to empty. This is more of a problem in cold weather. This will prevent you from filling it as much as possible. What I do is open the fuel cap before I deal with the pump's payment system. This gives the tank a chance to expand while I fiddle with the card. This usually allows me to pump 7-8 and as much as 10 gallons at a time. Also beware that the fuel gauge is not super-accurate. Especially at the low end. It is very conservative and prompts you to "Add fuel" (with last pip of the meter blinking) way early. I usually put about 7-8 gallons max when gassing up soon after the blinking begins. Given that the car has an 11+ gallon tank I'd say it's a conservative warning. Last time I gassed up I decided to push it a little further and assumed 40 MPG (which is reasonable for me these days) and ignored the blinking pip until I was close to 400 miles on that tankful. I ended up pumping about 10 gallons of gas in. I was driving on the highway the entire tank and ended up with about 38+ MPG that time. I was not driving for fuel economy, obviously.
    The best way to measure real economy is to run an average of your fill-ups and miles driven. Many of us here use Fuelly to keep track of the running average. You can see mine in my signature. It may be a bit behind the current fill ups due to the delay of the signature update, but it's close and represents my average MPG since I first bought the car last July. The MFD in my car usually reads a bit optimistic compared to what I measure at the pump, but not as far as what you are reporting. Anything under 35 MPG should be reason to be concerned. But first you must be sure your 18-20 MPG measurements are real. If they are (which I doubt), your car is badly broken. I have not heard of anyone getting that kind of mileage on a Prius.
    #8 VFerdman, Mar 7, 2018
  9. GCarp
    GCarp New Member
    Ohio
    Great advice thanks! I will look into the tracker, most assuredly easier than trying to be meticulous with my own calculations
  10. VFerdman
    1,200
    1,221
    You can set up Fuelly to accept text messages reporting your fill-ups. It then instantly calculates MPG, logs it to your account and car (you can have multiple cars on an account), calculates the running average and texts you back the results. It's very convenient and fast to use. I usually shoot a text right after I am done filling up and before I zero my Trip A and take off from the pump.
  11. GCarp
    GCarp New Member
    Ohio
    So I have set up a fuelly account, I am looking at 22.4 mpg in my first run. So, not great, but better than the 18 mpg I calculated myself... I am continuing to monitor and see where it goes, and I am trying to schedule a "check up" with my local shop.
    Another semi-related question, is there a good way to check the hybrid battery for strength/health? I am wondering, even though it seems to charge consistently if maybe, as Ed had mentioned previously, the high miles and long years on the car has been taking a bigger hold than I have feared...
  12. bisco
    52,878
    1) how many fill ups have you done?
    2) have you looked through the 'why are my mpg's so low' sticky?
    3) there are many things on a prius that can reduce mpg's such as tires/pressure, oil level, 12v health and etc.
  13. GCarp
    GCarp New Member
    Ohio
    1) 2 since I bought it from a dealer
    2) A bit, and I have done some minor trouble shooting based on what I've seen, but will continue to see if I can find anything relevant to my situation... But I am loving the site and continuing to dive deeper regularly... This update was just kind of that, an update as to the initial question
    3) Good to know, and unfortunate to know... Kind of all at once. :)
    Thanks!
  14. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    I also was freaked out about the fueling at the gas pump stopping at a low amount. I have found that on fuelly even if I feel I have filled the tank I mark it as a "partial fill-up". Then, on the next fuel stop I mark it as a full fuel-up. This makes fuelly use 2 tanks for my next recorded average. This helps smooth out the fuel bladder variability. I bought my Prius in early February and live in Michigan. My first or second fuel-up on a tank that was low stopped at 3-ish gallons! I didn't know about the bladder and thought I had an issue. Prius Chat has been a wealth of information that has helped me during my steep learning curve.
    Finally, and again if you have an Android device, you can download Hybrid Assistant. It is a wonderful app. One feature is a "HV battery check". It shows the voltage and resistance of each battery module. Another app is Dr. Hybrid (formerly Dr. Prius) that does even more battery checking. But, I believe this requires a purchase whereas Hybrid Assistant is a free app.
    Good luck with your fuel economy issue. I still have high hope that over a few fuel-ups yours will sort out nicely.
    Paul.
