First Timer: Got 15.8 Miles on Battery
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Slavatheshrimp, Jul 1, 2020.
  1. Slavatheshrimp
    116
    73
    Mather
    I recently got my 2015 PIP all taken care of and managed to get it charged at work. On the way back, I tested how far it would go.
    It's hot in California so AC was working as well. I was doing about 75-80MPH the whole way home and got a suprising 15.8 miles on the battery before it kicked in the engine.
    That's more than advertised!
    Is that normal?
    Tideland Prius likes this.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    NOT NORMAL. Be glad!
  3. Tideland Prius
    16,680
    Wow! That's great! That is more than rated. I think Toyota was targeting around 12 miles? But the EPA was 6/11 (6 miles all-electric, 11 miles blended).
    52,848
    Downhill? :cool:
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Not close to normal. How do you go 75-80 mph in EV mode when the PiP will only do about 64 mph before the engine kicks in. 171697_HeadScratchingEmoji.jpg
  6. bisco
    52,848
    :whistle:
    willyag likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Maybe my dude's PIP is a marvel:p.
    But something does seem awry:whistle:.
    willyag likes this.
  8. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    The engine can still start while in EV mode, if you have the MFD on "Hybrid System Indicator" the "EV" symbol will go blank when this happens. Since you were going over the 60 MPH EV mode speed limit, the ICE had undoubtedly started, and EV driving would only be occurring below this speed.
    Depending on certain driving conditions, the car can use significant EV power over 60 MPH (although the ICE is still running too). Some refer to this as "EV Boost". Normally the EV range won't go down much when driving at these speeds. I've seen it happen a couple of times but I don't really understand how it works, or if it's even an intended mode of operation.
    Not sure what "all taken care of" means, did you just get the car?
    jerrymildred and willyag like this.
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    Yeah, I played with that with my PiP. It was pretty cool getting close to 100 mpg at 70 mph. Used up battery fairly fast, but not as fast as at 60 mph without the ICE. I was hoping the Prime would do something like that in EV auto. But alas ...
    Edit to add: I should have mentioned before that just because the PiP is in EV mode doesn't mean the ICE isn't running.
    hill likes this.
