First Trip in new PIP = 27mpg (my '11 Prius 2 gets 60+mpg for same trip)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mclayrob, Dec 3, 2012.
  1. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    8.3 sounds about right.. my last two fill ups (when the last bar started flashing) have been 8.65 and 8.25.
    lensovet likes this.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    Enjoy Your car! :)
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    If the increased battery capacity resides in the spare tire well plus due to change to lithium ion. Why does the PiP have a smaller gas tank than the regular Prius?
  4. El Dobro
    El Dobro A Member
    7,086
    3,263
    I believe it has to do with the Evap system. Did you notice that when you hit the fuel door release, you have to wait 'til it says it's ok to pump the gas?
    mmmodem likes this.
  5. retired4999
    2,652
    627
    Eau Claire, Wi.
    I'm not sure but it may be a couple of things. Save on extra weight of gas, also maybe needed the space for battery, between the smaller gas tank and the spare tire, weight saved is about 25 pounds, every bit helps.
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Never gave that a thought, that needs room to I guess! So many things so little room!
  7. El Dobro
    El Dobro A Member
    7,086
    3,263
    I believe I heard the Volt is the same way with the filling procedure.
  8. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Mom texted me to pick up some home cooked dishes.
    25 minutes round trip resulted in 36.9 MPG. So dissapointing. ;)
    rogerv and Tracksyde like this.
  9. lensovet
    2,615
    496
    Burlington, NJ
    what's more disappointing is attempts to view that picture lol :ROFLMAO:
  10. Adam Leibovitch
    498
    102
    Darn, you must have been so close to getting home when you ran out EV usb. How many extra miles would you have needed?
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    ICE kicked in 0.9 miles away from home. I used gas the amount about two medium eggs (0.035 gallon).
    Coolant warmed up to 132 deg F and ICE shut down when I pulled into garage.
    I took the highway and stayed under 55 mph (speed limit). Next time, I will try city route with many lights.
  12. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Does it appear upside down for you?
    I see it rightside up on my iPhone.
  13. lensovet
    2,615
    496
    Burlington, NJ
    yeah it's upside down in desktop safari here
  14. mmmodem
    2,732
    1,703
    Bay Area, CA
    So that's why it's an electric release! I was wondering why the extravagance. I never noticed the message. By the time I swiped my credit card and punched in my zip, it was probably ready. Now it makes more sense. At the risk of going more off topic, why does the PiP have an Evap system?
  15. lensovet
    2,615
    496
    Burlington, NJ
    CARB regs?
  16. lensovet
    2,615
    496
    Burlington, NJ
    What is strange, however, is that the regular Prius already has zero evaporative emissions despite using a regular pull-style lever. Not sure what's going on there.
  17. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I wouldn't count on there definitely being 2.3 gallons (or whatever value you come up with) "in reserve".
    The Gas Gauge Says Full, But That's Not Quite True: NPR | PriusChat might be insightful, even though it's a Ford engineer talking.
  18. lensovet
    2,615
    496
    Burlington, NJ
    In my personal experience (from how far one can go until you run out of gas), the low gas light in all cars comes on when you have ~2 gal of gas remaining
  19. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I wouldn't try that on a Gen 2 Prius w/its variable capacity bladder and small tank. People have found a large variance in how far they can go on a flashing pip.
  20. 3PriusMike
    3,100
    2,419
    Silicon Valley
    I think it is quite necessary to have an advnaced evaporative system in the PIP gas tank. Since many of us will drive on EV so often if it had a regular gas tank all the gas might evaporate before we got a chance to use it.
    Mike
    mmmodem and lensovet like this.
