First Trip in new PIP = 27mpg (my '11 Prius 2 gets 60+mpg for same trip)
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mclayrob, Dec 3, 2012.
  1. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Logical. The wealth of knowledge of PC members is intoxicating.
    Looks fine in desktop. Upside down on my iPod.
  2. El Dobro
    El Dobro A Member
    7,079
    3,259
    From what I've read about the Volt, it has a pump that can create either vacuum or pressure in the tank, depending on which is needed. That's why the car tell you when it's ready to be filled. The PIP is probably using a similar system.
  3. LenP
    LenP Member
    257
    69
    Morris County, NJ
    If your driving short trips with your PIP and the engine should come on it can really impact your mileage. The best way to avoid this on short trips is keep your temperature set to low; this keeps the ICE from firing up on colder days. Don’t do jack rabbit starts, this is a guarantee the ICE will fire up. Once it does it will keep running until the catalytic converter reaches temperature. On a short trip it’s a real mileage killer. As for your trip from the dealer I think you may have read the readout wrong. You made the right mover going with the PIP. There’s no way the regular Prius can compare with the mileage you’ll enjoy with this vehicle… Congratulations and enjoy.
  4. lensovet
    2,615
    496
    Burlington, NJ
    OP has already stated that he inserted a decimal point where there wasn't any.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I think the lesson here, is don't jump to conclusions about your vehicle based on your first drive home from the lot. Along with know how to read your gauges.
    But it was good for a laugh.
    Yep, 270 mpg...that's a real gas guzzler you've got there.
