First Trip to Shop
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Rae Vynn, Feb 7, 2011.
  1. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    Rudy has his first appointment for service work. He's at nearly 80K miles, and has never needed anything before.
    I'm nervous.
    On the schedule:
    Coolant pump recall work
    Inverter fluid change
    PCV valve
    Alignment
    12V battery change
    When there, I'll ask them to do the "oil change" checks listed in the Maintenance booklet - inspection points
    Am I forgetting something crucial? Is there anything I should be aware of?
    Any ballpark guesses as to the cost of "Rudy's day at the spa"? :p
  2. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I'm guessing $500
    49,694
    the pump and fluid are warranty, yes? so, battery $250. tires $20. inspection points $75.? = $345. my daughters 04 has a little over 80,000. nothing but the maint. manual stuff yet. and recalls. you sound nervous about taking your baby in, all the best!
  4. direstraits71
    direstraits71 Member
    367
    64
    Central Coast California
    Did you mean inverter fluid or transaxle fluid. Probably should do transaxle fluid if you haven't already.
  5. Patrick Wong
    18,200
    6,479
    There should be no charge for the inverter coolant because draining and replacing the coolant is supposed to be part of the inverter coolant pump recall work.
    I agree that the transaxle ATF fluid should also be drained and replaced (at your cost) if that had not been previously done.
    If you add that item to your list then my guess is $600 for all of the items in your OP plus transaxle ATF.
  6. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Oh, the transaxle. That's what I meant. yes, okay... thank you!
  7. bisco
    49,694
    if you add the trans, i'll go $475.
  8. bisco
    49,694
    you're having it done at joe's corner spa, err, garage, right?
  9. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Who is Rudy?
  10. Ryanpl
    780
    158
    Brooklyn, NY
    Rudy is Rae's four doored baby.
  11. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    I'm having the work done at Toyota of Olympia.
    I called and added transaxle drain/refill to my schedule. "That isn't due until 90K." "Yes, I know." "Oh, okay then. I'll add it in." Gotta say, I appreciate when they offer info, but don't argue. :)
  12. nascrlvr
    nascrlvr nascrlvr
    1,200
    25
    Pacific Northwest
    Good luck Rae!!!! Report back after the day at the spa. Tell them to be gentle with him; it's his first time!!!
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Shoot! We should have done the battery when you were down here. I'd have done it for a mocha. :)
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    errr .... you are going to let them tell you the price *after* the work is done ? If that is the case just hand over a signed blank check and hope for the best.
  15. patsparks
    10,664
    567
    Adelaide South Australia
    I thought you were going shopping in your Prius for the first time Rene', oops.
  16. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Be prepared for a suggestion to change the engine water pump and serpentine belt. If they do, insist on a visual inspection before approving the work. If the engine water pump is bad, you will see a lot of pink crusty gunk on it. If the serpentine belt is bad, it will be riddled with cracks.
  17. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    I'm expecting to be handed a printout estimate before work starts, actually.
    Just thought it would be fun to have the challenge of guessing going on here :)
  18. Ryanpl
    780
    158
    Brooklyn, NY
    Rae, When I was a kid my family used to play a where whoever got closest to the total price paid, but for some reason dad always paid :eek:)
  19. SageBrush
    11,627
    2,531
    Southwest Colorado
    I'm not trying to bash you Rae, but if you have already invested the time to drive down to the garage and hand over your car, your willingness to say "too much" is impaired. Or at least mine would be.
    Any reason you or a friend are not taking on some of the simple DIY work at a fraction of the cost ? One other comment, access to the PCV valve is about the same as needed for spark plug replacement. I'd try to do both at the same time, and would not feel obliged to do either at 80k. Not that 80k is a bad time, but another year or two is OK too.
    Good luck :)
  20. Rae Vynn
    6,038
    707
    Tumwater, WA USA
    Well, we aren't having them do the oil change. And, they can't touch my filters... I've changed them often enough!
    I don't feel like fumbling around with the PCV valve. And, I'm going off Galaxy's list (sorta) for what should be taken care of. It's a tiny little thing in a day of big things.
